Constant loss of position
- andreabonuc
27 Sep 2024 12:04 #310883
by andreabonuc
Replied by andreabonuc on topic Constant loss of position
DIRSETUP = 6000
DIRHOLD = 4000
This?
DIRHOLD = 4000
This?
- Thank you received: 5330
27 Sep 2024 14:04 #310886
Replied by PCW on topic Constant loss of position
Yes, set those both to 20000 (for all joints)
- andreabonuc
27 Sep 2024 14:23 - 27 Sep 2024 14:35 #310890
by andreabonuc
same problem.. It didn't change anything
If I go F1000 or F10000 the error are the same...
Last edit: 27 Sep 2024 14:35 by andreabonuc.
27 Sep 2024 15:16 #310896
OK I would leave them at 20000 since is has no significant effect on performance
and eliminates a possible source of errors.
Could still be mechanical, a problem with the drive or encoder, etc.
Can you swap drives easily?
- andreabonuc
27 Sep 2024 15:31 #310899
by andreabonuc
I tried to reverse the z-axis and x-axis motors but the problem remains the same. this evening I'll try to create a new minimum configuration to test, using the 5th free exit of the mesa instead of this one. If it doesn't work, as soon as I can I'll dismantle all the components of the axle to check them. I can't think of anything else...
- andreabonuc
27 Sep 2024 21:52 #310920
by andreabonuc
I just used the free output instead of the one I used for the X by changing the parameters on the existing configuration file. The error disappeared and everything is perfect again, so I have a problem on exit 0 of the Mesa... This thing doesn't make me happy at all.
- Thank you received: 7488
27 Sep 2024 22:10 #310921
Replied by tommylight on topic Constant loss of position
Might be interference issues, use shielded cable for signaling.
27 Sep 2024 22:18 - 27 Sep 2024 22:20 #310923
Sounds like a marginal output. This could be a factory defect but
could also be caused by accidental contact of a step/dir wire
to a voltage outside the 0 to 5V range.
You can check the step/dir outputs with this script:
(You need to "chmod +x stepgens.txt" to make it executable and
possibly change the IP address in the script)
This will slowly toggle all the step/dir outputs on any Mesa ethernet
FPGA card.
They should swing from 0 to 5V
This does require the latest mesasflash:
github.com/LinuxCNC/mesaflash
FPGA card.
Last edit: 27 Sep 2024 22:20 by PCW.
The following user(s) said Thank You: andreabonuc
- andreabonuc
27 Sep 2024 22:35 #310925
by andreabonuc
the cables are all shielded, I haven't made any changes and the router has been working for almost 2 years without this problem.
- andreabonuc
27 Sep 2024 22:41 #310926
by andreabonuc
I'll try as soon as I can, but to change the output I didn't touch any wire, I simply removed and replaced the complete terminal, going from output 0 to output 4 which is exactly below.
Time to create page: 0.196 seconds
