Constant loss of position
28 Sep 2024 12:22 #310973 by andreabonuc
Replied by andreabonuc on topic Constant loss of position
sorry but I'm not very capable so I ask. I installed mesaflash, copied the script into the folder renaming the text file with "stepgend.txt",
From the terminal I entered mesaflash and typed "sudo mesaflash" to then call the script. I have no apparent result, if I measure the voltages on the pins they are fixed and nothing changes. the ip address of my card from linuxcnc file is 10.10.10.10. what am I doing wrong?
andrea@debian:~$ cd mesaflash
andrea@debian:~/mesaflash$ sudo mesaflash
[sudo] password di andrea:
Mesaflash version 3.5.9
Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB/SPI boards
Try 'mesaflash --help' for more information
andrea@debian:~/mesaflash$ chmod +x stepgens.txt
28 Sep 2024 15:10 #310983 by tommylight
Replied by tommylight on topic Constant loss of position
./stepgens.txt
in a terminal.
28 Sep 2024 19:13 #310995 by PCW
Replied by PCW on topic Constant loss of position
No sudo is needed with Ethernet cards.
28 Sep 2024 19:42 #310998 by andreabonuc
I tried but I get very different values
Output 0 (now no connection)
DIR+/DIR-= 4.9/0.03
STEP+/ STEP-=4.9/0.03
Output 1
DIR+/DIR-= 2.4/0.04
STEP+/ STEP-= 2.4/0.03
Output 2
DIR+/DIR-= 2.4/0.1
STEP+/ STEP-=2.48/0.048
Output 3
DIR+/DIR-= 2.3/0.048
STEP+/ STEP-=2.3/0.048
Output 4 (now use for X)
DIR+/DIR-= +3.9/-4.9         ????
STEP+/ STEP-=+3.9/-4.9    ????
28 Sep 2024 19:47 - 28 Sep 2024 19:52 #310999 by PCW
You have a damaged driver chip (U5 or U7) or incorrect wiring
(did you ground DIR+ or DIR- ?)
You can check it its a wiring error by unplugging the connectors.
If you still don't get a differential output like channel 4 (+ and -  >2.4V))
Either U5 or U7 have been damaged and its surprising channels 1,2,3
still work
Last edit: 28 Sep 2024 19:52 by PCW.
28 Sep 2024 21:42 #311003 by andreabonuc
one moment, let's try to understand each other well otherwise I'll make a mistake. should I measure between step+ and step- / dir+ and dir- or gnd - Step + / gnd- step- etc? because then I have different values. Or another way? sorry but I'm not familiar with this, if you tell me precisely what I need to measure I'll be grateful.
28 Sep 2024 21:56 - 28 Sep 2024 21:56 #311004 by PCW
Its probably best to measure between STEP+,STEP-,DIR+,DIR- and GND
You should get a positive voltage in one state and a voltage close to ground
in the other
If you measure between say STEP+ and STEP- you should get
a positive voltage in one state and a negative voltage in the other state.
(as you did on channel 4). The fact that channel 4 acted very differently
than channels 0..3 is a pretty clear indication that U5 or U7 are damaged
(and may have been marginal for a long time)
Last edit: 28 Sep 2024 21:56 by PCW.
28 Sep 2024 22:26 #311005 by andreabonuc
Now I can't go and measure, but I just measured with gnd.
outputs 1-2-3 gave the same values, 2.3v and 4.8 V,
output 0 dir- and step-    0.05 V
Output 4   5v and 4.8v
These were approximately the values ​​I found
28 Sep 2024 22:44 #311009 by PCW
Yeah, from a distance I would guess that U5 (the driver chip  for STEP-/DIR- 0 0..3)
has been damaged as it looks like all 0..3 - pins are bad.
29 Sep 2024 06:21 #311015 by andreabonuc
A cosa potrebbe essere dovuto? Cosa significano queste uscite danneggiate? Perché "sembra" che i motori facciano quello che dovrebbero fare, o almeno credo. Stai dicendo che devo comprarne uno nuovo?
Time to create page: 0.170 seconds
