Fast Hole EDM from Hacked Parts
- IronManDylan
- Thank you received: 22
27 Dec 2024 22:09 #317512
by IronManDylan
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
PCW,
Thank you.
Okay, as best I can tell I am running 2.9.0 (that is what is show at the top of my axis gui and what I see when I use linuxcnc -v). You reminded me that Peter said something about needing 2.10.. Do you know if I need 2.10?
Can I update linuxCNC? Do I have to wipe the entire machine or can I just update? Will I loose any system configuration data if I do this or will that all be stored in my machine folder?
Best,
-Dylan
Thank you.
Best,
-Dylan
- Thank you received: 5316
27 Dec 2024 22:24 #317513
Replied by PCW on topic Fast Hole EDM from Hacked Parts
It might be supported by 2.9.3 if not then you must use 2.10
You should be able to upgrade to 2.9.3 with the package manager
if you are running s normal Debian LinuxCNC release
- IronManDylan
27 Dec 2024 23:09 #317516
by IronManDylan
PCW,
Okay, I am trying to start with 2.9.3 but am having some trouble, is this just done through the terminal? Do you happen to know the commands to do it? Do I need to find 2.9.3 and install the package on my machine first?
If it is not too much trouble I could go straight to 2.10. But I have found zero info on how to do that..
I am running bookworm. I know that I tried to download whatever was best and most recommended when I set this machine up.
Thank you.
Best,
-Dylan
Thank you.
Best,
-Dylan
27 Dec 2024 23:53 #317518
There's some generic information here:
linuxcnc.org/docs/html/getting-started/u...e_to_the_new_version
But it might be better to just ask here on the forum with an appropriate topic, like
"How do I update LinuxCNC to the latest"
etc
etc
- IronManDylan
28 Dec 2024 01:20 #317529
by IronManDylan
PCW,
I was about to post a reply. But I did so in a new thread per your suggestion www.forum.linuxcnc.org/38-general-linuxc...-do-i-update-to-2-10
Best,
-Dylan
Best,
-Dylan
- IronManDylan
28 Dec 2024 20:51 #317568
by IronManDylan
Hi PCW,
I was able to get 2.10 installed which I have posted about on the other post. The output of periodm pins is as follows (just copied and pasted and I tried to clean up some):
38 u32 I/O 0x00000001 hm2_7i96s.0.periodm.00.averages
38 float OUT 59.1607 hm2_7i96s.0.periodm.00.duty_cycle
38 float IN 0 hm2_7i96s.0.periodm.00.duty_cycle_offset
38 float IN 100 hm2_7i96s.0.periodm.00.duty_cycle_scale
38 float IN 1 hm2_7i96s.0.periodm.00.filtertc_us
38 float OUT 102354.1 hm2_7i96s.0.periodm.00.frequency
38 bit OUT TRUE hm2_7i96s.0.periodm.00.input_status
38 bit I/O FALSE hm2_7i96s.0.periodm.00.invert
38 float IN 1 hm2_7i96s.0.periodm.00.minimum_frequency
38 float OUT 9.77 hm2_7i96s.0.periodm.00.period_us
38 bit OUT TRUE hm2_7i96s.0.periodm.00.valid
38 float OUT 5.78 hm2_7i96s.0.periodm.00.width_us
I think the pin I am looking for is 'hm2_7i96s.0.periodm.00.duty_cycle'. This should let me read the duty cycle of the input PWM cycle into pin 29 (which is actually TB2 Pin 13,14 as the naming convention is not complex enough here...). Do you agree with the assessment?
Best,
-Dylan
Best,
-Dylan
- IronManDylan
29 Dec 2024 06:19 #317592
by IronManDylan
Here is an update. I have plugged the positive from my EDM power supply into pin 13 TB2 and the negative into pin 14 TB2 on the Mesa. I then evaluated pin hm2_7i96s.0.periodm.00.duty_cycle using hal meter. The number is jumping around like crazy. It got a little better when I remembered to change the jumpers to TTL. Now it fluctuates only on the low end.
I have tried shielded cable. I have tried a RC filter with a .1 uF capacitor and a 3.3 kOhm resistor. I tried switching the red and black cables around. I tried tying the black to ground. The signal becomes 0 if either the red or black wire is removed from the mesa pin 13,14. But I cannot get a signal that makes sense. The signal jumps around even when the EDM supply is turned off and remains unchanged even when the EDM is cutting.
I currently think that maybe the problem lies in the sampling rate. Or perhaps it has something to do with the pin. I think the issue is in the Linux side but I could be wrong. I will try using the oscilloscope more tomorrow.
If anyone has ideas please let me know.
Best,
-Dylan
Best,
-Dylan
- IronManDylan
30 Dec 2024 00:04 #317647
by IronManDylan
Another update. It seemed that I didn't have the Mesa tied to ground properly. It is now tied to earth ground (I also tied the shielding into earth ground). The jittering all went away and now the 'hm2_7i96s.0.periodm.00.duty_cycle' is sitting at 0 even when the EDM is running. Anyone have any ideas?
Is 'hm2_7i96s.0.periodm.00.duty_cycle' the correct pin?
30 Dec 2024 02:35 - 30 Dec 2024 15:08 #317650
Yes, duty cycle is the correct pin.
Is the frequency reasonable and the valid bit set?
It sounds like the EDM output is single ended which means:
1. The EDM duty cycle output should connect to TB2 pin 13 (IDX+)
2. The EDM signal ground should connect to TB2 pin 15 (7I96S ground)
3. The 7I96S IDX input should be jumpered for TTL mode (W1 left)
4. 7I96S IDX- (TB2 pin 14) must be left unconnected
Note the if you connected the inputs to TB2 pins 13 and 14 without a ground
and ran the EDM system you may have damaged the EDM output or
7I96S input.
7I96S input.
Last edit: 30 Dec 2024 15:08 by PCW.
- IronManDylan
30 Dec 2024 17:20 #317680
by IronManDylan
PCW,
I did that, why would it damage anything? Could a high voltage be carried through the ground wire to pin 14? This is the only thing that would make sense to me since the + wire is supposed to only be 3.3v..
Can you please explain what you mean by "Is the frequency reasonable and the valid bit set?"
Best,
-Dylan
Best,
-Dylan
Time to create page: 0.319 seconds
