Machine moves when you stop program in the middle
- Thank you received: 7488
- Thank you received: 2176
Also try to uncomment one of those lines at a time and see when the bug appears again.
- cakeslob
- Thank you received: 280
github.com/cakeslob/RRW_LAB/blob/main/Li.../remora-xyzRE_ts.ini
We use the same probe stuff, which I havent exactly changed either.
Anyone else wanna chime in, but the thing that stands out the most is 2.7 classic 2.7
github.com/LinuxCNC/linuxcnc/issues/579
There should be a way to use on_abort only during probing routines, and that is strictly whe it should be active.
Shooting from the hip here, but i really do not like it being in the main ini file.
- cakeslob
btvpimill try putting nothing in your abort, or even just a g4 dwell command, and see if it does the same thing
edit, tommy, there is actually a separate abort function specifically for probe abort for this easyprobe addon called probe_escape.ngc that does other stuffÂ
- btvpimill
- Thank you received: 3
I will try to get the config zipped and posted here.
I will try and test 1 line at a time to see if I can narrow it down.
github.com/LinuxCNC/linuxcnc/issues/579I found the trigger. If I use ON_ABORT_COMMAND to call a subroutine:
even an empty sub will make it fail. I got the file down to this and it still failed:
o<on_abort> sub
o<on_abort> endsub
m2
If I comment out ON_ABORT_COMMAND I can't get the fault to happen.
So removing the ON_ABORT_COMMAND from the ini file should fix this for you if you are on some earlier version.
[edit]
No need for that anymore as the bug has been identified to be in the source code of your version of linuxcnc
I am glad!
- btvpimill
- cakeslob
but the on abort stuff doesnt look like it will effect probe stuff, as it is advised to use the probe abort button on the probe panel [x] button
