[SOLVED] Rigid tapping problem - tristate_bit and index-enable?
- spumco
- Thank you received: 905
09 Nov 2024 05:36 #314110
by spumco
Rigid tapping problem - tristate_bit and index-enable? was created by spumco
Wrapping up my mill rebuild and have run in to another issue.
Tried rigid tapping for the first time tonight and the spindle spun up to speed at the correct Z-height and just sat there spinning. Obviously waiting for something that didnt happen.
First thought was the spindle-at-speed signal. Nope, that signal went high at the appropriate rpm, and stayed on despite a few rpm flutter.
Next culprit I suspect is the encoder index logic. I know the encoder index signal/pin is working since spindle orient works OK.
Looking through my spindle HAL stuff, I remembered I had to use a tristate_bit pin to get orient functioning. Because my spindle motor won't reliably orient on its own, I've had to add a pneumatic shot-pin to help stop it at the right spot.
Subroutine below, but basically I have to toggle the tristate_bit on & off, then rotate the spindle a rev or two to set the index. Once that's set, shot pin is deployed and orient moves the spindle slow-ish until the shot pin drops in place.
Relevant HAL connections:
setp tristate-bit.spin_index.in 1
net SPINDLE-INDEX-TRIGGER-IN <= motion.digital-out-07
net SPINDLE-INDEX-TRIGGER-IN => tristate-bit.spin_index.enable
net SPINDLE-INDEX-ENABLE <=> tristate-bit.spin_index.out
net SPINDLE-INDEX-ENABLE => pid.s.index-enable
net SPINDLE-INDEX-ENABLE <=> spindle.0.index-enable
net SPINDLE-INDEX-ENABLE <=> [HMOT](CARD0).encoder.00.index-enable
And the spindle orient/homing g-code:
M5 M9 ; Turn off spindle
(print, orient homing test)
M65 P4 ; Retract spindle lock
M64 P7 ; Set spindle-index-enable
G4 P0.1
M65 P7 ; Turn off spindle-index enable
S250 M3 ; Start spindle, must be slow in case probe is in spindle
G4 P1 ; Rotate briefly to reset encoder index
M5 ; Stop spindle
G4 P0.25 ; Pause
M64 P4 ; Extend spindle lock
G4 P0.5 ; Wait for lock extend
M19 R0 Q2 ; Orient spindle
M66 P5 L3 Q3 ; Check spindle oriented
O100 IF [#5399 LT 0]
(abort, spindle not oriented)
O100 ENDIF
G4 P0.5
Have I somehow hijacked LCNC's ability to set index-enable for G33 commands?
Do I need an or2 component somewhere so that something in LCNC can set the index-enable pin high for synchronized spindle moves in addition to the orient sequence?
Or should I be looking elsewhere for the tapping-won't-start problem?
Warning: Spoiler!
Warning: Spoiler!
G4 P0.1
M5 ; Stop spindle
G4 P0.25 ; Pause
O100 ENDIF
G4 P0.5
- Thank you received: 2176
09 Nov 2024 11:00 - 09 Nov 2024 11:07 #314116
IIRC the spindle position must also increase by +1.00 for a single CW rotation of the spindle (although I would kind of expect that to be the case as you already have spindle orient working).
Replied by Aciera on topic Rigid tapping problem - tristate_bit and index-enable?
Last edit: 09 Nov 2024 11:07 by Aciera.
- Thank you received: 5330
09 Nov 2024 14:52 - 09 Nov 2024 14:58 #314121
Replied by PCW on topic Rigid tapping problem - tristate_bit and index-enable?
I suspect you need to only enable the tristate when orienting
otherwise your digital output 07 will control index enable
rather than the encoder hardware for G33.
EDIT: Never mind, that does look like what you are doing.
Is motion-digilat-out07 false when you try to rigid tap?
Last edit: 09 Nov 2024 14:58 by PCW.
- spumco
09 Nov 2024 16:08 - 09 Nov 2024 16:37 #314128
by spumco
I haven't set up halscope to try to catch an index pulse or other brief signal, but the index-enable signal doesn't go true when I try to rigid tap.
EDIT - Minor troubleshooting update
I disconnected tristate_bit from motion-digital-out in halshow and ran a short tapping program to see if digital-out was holding the index-enable pin/signal false.
No change in behavior - spindle just spins & waits.
While it was spinning, I manually set the SPINDLE-INDEX-ENABLE signal high and all the nn.index-enable pins went high.
pid.s.index-enable
No change in behavior.
I did discover that I don't have pid.o.index-enable connected to anything. I don't know if this is related to the tapping problem, but I wonder if it's the reason I had to do the tristate_bit gymnastics when I set this up a couple years ago. IIRC, during orient attempts the spindle would just spin and nothing was triggering the index point.
Replied by spumco on topic Rigid tapping problem - tristate_bit and index-enable?
Yes, digital-out is false when I try to rigid tap.Is motion-digilat-out07 false when you try to rigid tap?
pid.s.index-enable
Last edit: 09 Nov 2024 16:37 by spumco.
- spumco
09 Nov 2024 16:34 - 09 Nov 2024 16:36 #314130
by spumco
I think I just found the point in history where I blew past the fact that pid.o.index-enable needed to be connected to something.
forum.linuxcnc.org/24-hal-components/458...-yay?start=40#245756
Last edit: 09 Nov 2024 16:36 by spumco.
09 Nov 2024 16:54 #314131
If you manually set the index enable signal true
and is is not over-driven by some other source,
it should get cleared at the index position by the
physical index signal. If this does no happen, you may
have a hardware issue with the index signal.
- spumco
09 Nov 2024 16:58 #314132
by spumco
The index-enable is getting cleared when the index pin goes true.
Just tested that by disconnecting the tristate_bit and manually setting the index-enable signal high and running the spindle for a second.
09 Nov 2024 17:10 #314133
It should still work with the tristate bit connected, as long as the tristate enable pin is false.
- spumco
09 Nov 2024 17:35 #314134
by spumco
Shocking development: I've managed to get the spindle orienting without using the shot-pin, and without having to set index-enable true and rotate the spindle to re-find the index.
Based on Andy's advice a couple years ago, I had connected pid.o.error to pid.o.Pgain through a lincurve array. After watching things in halshow today, I discovered that Pgain wasn't changing in response to the orient error; i.e. lincurve wasn't doing anything.
Turns out I had the lincurve starting x-values set to an order of magnatude smaller than required for lincurve to adjust the output. Result was that lincurve didn't 'kick-in', ever. The shot-pin was required to lock it in place because the pid wasn't adjusting - just causing the spindle to wag back and forth.
After changing the values and connecting pid.o.index-enable the spindle now orients from any position. No shot-pin, no pre-orient spin-the-spindle index-enable dance.
Sadly, this hasn't fixed the rigid tapping failure.
Thanks, I'll reconnect it.It should still work with the tristate bit connected, as long as the tristate enable pin is false.
- spumco
09 Nov 2024 17:59 - 09 Nov 2024 18:01 #314135
by spumco
Replied by spumco on topic [SOLVED] Rigid tapping problem - tristate_bit and index-enable?
O.M.G. - I should RTFM
spindle.M.revs IN FLOAT
For correct operation of spindle synchronized moves, this signal must be hooked to the position pin of the spindle encoder.
Ignorance is NOT bliss.
Last edit: 09 Nov 2024 18:01 by spumco.
Time to create page: 0.161 seconds
