[SOLVED] Rigid tapping problem - tristate_bit and index-enable?
- Thank you received: 7488
09 Nov 2024 18:43 #314136
Replied by tommylight on topic [SOLVED] Rigid tapping problem - tristate_bit and index-enable?
Was this on another topic a while back, or is it another setup/machine?
- spumco
- Thank you received: 905
09 Nov 2024 22:28 #314150
by spumco
Replied by spumco on topic [SOLVED] Rigid tapping problem - tristate_bit and index-enable?
@Tommy,
This is the same mill I've been trying to sort out ever since I started fiddling with LCNC. Like 4 years since it's worked properly.
I had a minor ATC crash late summer 2023 as I was about finished with the rebuild due to some issues with carousel.comp and my config. And before I could get back in to troubleshooting the mill, I got a long-term, complicated paying project that took priority until we delivered the machines last May.
And the CNC lathe I'm building has been waiting on some parts to be machined by a friend since May 2023. Those were mostly done as of a week or two ago.
So priority 1 is finish the mill. And then finish the lathe.
09 Nov 2024 22:50 #314152
I recall you (i think it was you) having issues with carousel component and/or orient, not sure exactly, so if this is the same thing here it would be nice to also update that topic, if not = i will retreat in my comfy chair and continue reading/watching.
- spumco
10 Nov 2024 01:17 #314166
by spumco
Soon as everything is working, of course.
What I'll do is go back and update all the 500 or so threads I started and point to a single 'Show Your Stuff' post with updated config and pics.I recall you (i think it was you) having issues with carousel component and/or orient, not sure exactly, so if this is the same thing here it would be nice to also update that topic, if not = i will retreat in my comfy chair and continue reading/watching.
Time to create page: 0.087 seconds
