rtapi_app: caught signal 11 - dumping core
- martyop
13 Nov 2024 00:26 #314353
by martyop
rtapi_app: caught signal 11 - dumping core was created by martyop
I'm installing LinuxCNC on a new old computer.
I got toe error "caught signal 11 - dumping core".
I wonder what I am doing wrong?
Here is the report that was generated.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.3
Machine configuration directory is '/home/martin/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/martin/linuxcnc/configs/my-mill/my-mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Found file(REL): ./my-mill.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
config string '0 out'
USRMOT: ERROR: command timeout
waiting for s.joints<0>, s.kinematics_type<0>
Timeout, trying kill -9
Debug file information:
iopl() failed: Operation not permitted
cannot gain I/O privileges - forgot 'sudo make setuid' or using secure boot? -parallel port access is not allowed
Note: Using POSIX realtime
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.100 units/sec 6.000 units/min
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
1441
1475
Stopping realtime threads
Unloading hal components
Waited 3 seconds for master. giving up.
pwmgen: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
stepgen: not loaded
hal_parport: not loaded
motmod: not loaded
trivkins: not loaded
homemod: not loaded
tpmod: not loaded
<commandline>:0: unloadrt failed
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Tue Nov 12 05:05:34 PM EST 2024
UTC Date: Tue Nov 12 10:05:34 PM UTC 2024
this program: /usr/bin/linuxcnc_info
uptime: 17:05:34 up 4 min, 1 user, load average: 6.46, 4.01, 1.73
lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
linuxcnc: /usr/bin/linuxcnc
pwd: /home/martin/linuxcnc/configs/my-mill
USER: martin
LOGNAME: martin
HOME: /home/martin
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1440x900 pixels (381x238 millimeters)
PATH: /usr/bin:/home/martin/linuxcnc/configs/my-mill/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.1.99-1 (2024-07-15)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.1.0-23-rt-amd64 root=UUID=768c1d10-a627-4b9d-81eb-5372172430d9 ro quiet
model name: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
cores: 4
cpu MHz: 3114.724
parport: 0000-0000 : parport0
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Debian 12.2.0-14) 12.2.0
python: Python 3.11.2
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.3
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-de 1:2.9.3 all motion controller for CNC machines and robots (German documentation)
ii linuxcnc-doc-en 1:2.9.3 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.9.3 all motion controller for CNC machines and robots (Spanish documentation)
ii linuxcnc-doc-fr 1:2.9.3 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.3 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.3 amd64 PC based motion controller for real-time Linux
If you read this far, thank you very much! What is the problem?
Thanks,
Marty
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.3
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
1441
1475
pwmgen: not loaded
stepgen: not loaded
motmod: not loaded
homemod: not loaded
tpmod: not loaded
pastebin.com
USER: martin
LOGNAME: martin
HOME: /home/martin
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 3114.724
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
Thanks,
Marty
- Thank you received: 7488
13 Nov 2024 01:18 #314358
Replied by tommylight on topic rtapi_app: caught signal 11 - dumping core
Disable "secure boot" in PC's BIOS.
- martyop
23 Nov 2024 01:23 #315073
by martyop
Replied by martyop on topic rtapi_app: caught signal 11 - dumping core
Thanks,
I will do disable secure boot and try again.
- martyop
23 Nov 2024 03:49 #315076
by martyop
Progress, turned off secure boot and now LinuxCNC runs the demo.
I get one other error, "No parport registered at 0x378. This is not always an error."
Computer has an aftermarket pci serial and parallel port card.
What's up with that?
Thanks,
marty
Thanks,
marty
23 Nov 2024 10:51 #315093
In a terminal
sudo lspci -v
See if there is a parallel port and at what address.
sudo lspci -v
- martyop
23 Nov 2024 13:09 #315100
by martyop
Here is the relevant section of the response to lspci -v
01:00.0 Serial controller: Nanjing Qinheng Microelectronics Co., Ltd. CH384 Dual Port Serial and Parallel Port Adapter (rev 10) (prog-if 05 [16850])
Subsystem: Nanjing Qinheng Microelectronics Co., Ltd. CH384 Dual Port Serial and Parallel Port Adapter
Flags: fast devsel, IRQ 16, IOMMU group 2
I/O ports at e000
Memory at df308000 (32-bit, prefetchable) [size=32K]
I/O ports at e100
Expansion ROM at df300000 [disabled] [size=32K]
Capabilities: <access denied>
Kernel driver in use: wchpciserial+
Kernel modules: parport_serial, wch, wch_pre
Thanks,
Marty
I/O ports at e000
I/O ports at e100
Thanks,
Marty
23 Nov 2024 13:17 #315101
I did type
sudo lspci -v
did i?
The port is there and working, but there is no info on capabilities as you did not use sudo.
The port address to type into the wizard is 0xe000
sudo lspci -v
did i?
- martyop
23 Nov 2024 13:38 #315104
by martyop
Yes you did type sudo lspci -v, I think I did too.
I put the address in the wizard for the parallel port.
I get the same no par port registered error but with the new address 0xe000.
Maybe I should get a new pci parallel port card.
- martyop
23 Nov 2024 13:40 #315105
by martyop
That's with sudo for sure.
I/O ports at e000
I/O ports at e100
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
I/O ports at e000
I/O ports at e100
23 Nov 2024 16:09 #315116
Last post is with sudo, the previous was not as can be seen by "permission denied" for capabilities.
Did you try setting the address and running LinuxCNC?
