rtapi_app: caught signal 11 - dumping core
24 Nov 2024 01:22 #315149 by martyop
Replied by martyop on topic rtapi_app: caught signal 11 - dumping core
You are correct.  I forgot to sudo the first time.
I did try to run LinuxCNC with the new address.
I got the same error with the new address.
The demo runs.  Computer is not connected to the mill so I don't know if signals are going to the port.
Thanks for your assistance.
24 Nov 2024 01:34 #315150 by tommylight
Replied by tommylight on topic rtapi_app: caught signal 11 - dumping core
It is not an error as noted on the warning, well not always, so you do need to test on a machine or use a DVM to check the output pins on the parallel port connector.
The following user(s) said Thank You: martyop
Time to create page: 0.170 seconds
