- Thank you received: 61
You've probably figured it out by now, but just in case, the machine type is defined in the .INI config file in the display param.
I will definitely check this out. I don't suppose there is a demonstration video?If you install Andy's "Lathe Macros", you get a set of canned cycles to do all the typical lathe ops, including threading with simple conversational interface. I beleive it works on most of the GUI's.
github.com/andypugh/LatheMacros
I of course use Gmoccapy as I like it modal nature.
Long is good, lots of information.Looong thread about lathe macros here
forum.linuxcnc.org/41-guis/26550-lathe-macros
