LinuxCNC 32 BITS
1 year 8 months ago #320562 by tommylight
Replied by tommylight on topic LinuxCNC 32 BITS
USB to parallel port adapters do not work with LinuxCNC.
Also, not VGA cable, that should be serial port with 9 pins and 3 thin wires, whereas VGA has 15 pins, but they do have the same outside dimensions.
1 year 8 months ago #320564 by unknown
Replied by unknown on topic LinuxCNC 32 BITS
VGA 3 rows of pins
9 & 25 Pin serial 2 rows of pins.
VGA will fit into a serial port, hammer, lube & wire cutters required to remove pins, guaranteed to not work.
1 year 8 months ago #321275 by Toribio1898
Replied by Toribio1898 on topic LinuxCNC 32 BITS
Hello JT, I hope to be able to respond promptly to your email. Why don't you use LinuxCNC?
Will I be able to see your machine online, running with your Ubuntu?
I think, LinuxCNC 32 Bits, isn't it more complete than your Ubuntu with LinuxCNC? I made a small mess of talk, because I wanted to use my 32-bit HP Mini, but it does not offer me a parallel port, and it is the one that distorts my image when booting LinuxCNC 32, it did boot Ubuntu correctly and hence my talk.
But I have forgotten the parallel port that the School's LinuxCNC 32-bit cpu offers me, which I have installed on the old 32-bit cpus, with 512 megabytes of ram, IDE mechanical disk, and I loved how fast they were, fluid, that I even installed games on them, to stimulate my students. So, if the 512 megabytes of ram work very well in your Ubuntu, in the 32-bit LinuxCNC, do they also work well? Or do you need more hardware? Thank you very much!... Congratulations!...
1 week 5 days ago #350353 by Toribio1898
Hola, después de mucho tiempo. Finalmente he armado esa pc, bien antigua, hoy con 1024 megas de ram ddr, su procesador 32 bits, y por fin su ssd. Descargué el Ubuntu propuesto, lo instale, re bien, sin internet, pero cuando probé su latencia, dió unos valores altísimos , probé, probé y luego volví a instalarle Linuxcnc 2.7.14, pero al realizar su latencia, iguaklmente muy alto los valores, por ende no me sirve para utilizarlo. Sería tan amable de compartirme su hardware tiene en su Ubuntu usado por años, sin problemas?, sigo insistiendo que me tiene que servir ñeste viejo cpu, pero los valores no acompañan para nada. Muchisimas Gracias!...
1 week 5 days ago #350368 by tommylight
forum.linuxcnc.org/27-driver-boards/5366...xcnc?start=10#310352
forum.linuxcnc.org/18-computer/38838-har...pc-s?start=20#171723
Did you try running the machine with it?
Did you try running the included PARPORT/AXIS/AXIS_MM config ? Does this report warnings when running?
Make a config for your machine, set the base period to 100000, everything else at default, try running it and see if it complains about latency.
1 week 2 days ago #350421 by Toribio1898
Muchisimas Gracias, de todas maneras, comparto lo que tengo Placa Intel D865DKD, procesador Intel Celeron 2.53Hz )1 cpu lógico), 998MB RAM, kernel 3.4.9-rtai-686.pae. Test de latencia: Max Jitter servo 1ms us a 405us, con wifi apagado y BIOS con APM desactivado. ¿Con período de base de 100000 ( 100 us), en Stepconf, se queja de latencia?. Que hardware maneja usted?, Aún me gustaría saber lo de JT, quien me confirmó, que usaba ese Ubuntu hacías años, sin problemas. Muchas Gracias por haberme respondido y su paciencia. Me encantaría que ésta viejita de cpu, me anduviera bien....
Time to create page: 0.072 seconds
