Gmoccapy Toollength sensor routine stops sometimes
27 Nov 2024 14:57 #315379 by pe8art
Dear All.
I use Gmoccapy for my CNC-Router.
I use the macro below to measure my tool height.
Switching between tools it for some tools stops in the middle of traveling to the probe.
For others it doesn't, does anyone have an idea?
Best regards from The Netherlands.
Bart
o<messen> sub
#1700=2        (Wechsel X Position)
#1701=4        (Wechsel Y Position)
#1702=-10        (Wechsel Z Position)
#1800=-220        (Position sicheres Z)
#1801=38         (Position Taster X)
#1802=110        (Position Taster Y)
#1900=#<_coord_system>    (NP merken nur G54 bis G59)
o500 if [#<_current_tool> EQ #<_selected_tool>]
;(debug, Tool bereits in der Spindel)
o500 else
M5
G54
G90 G0
G53 Z#1702                    (Wechsel Z Position)
G53 X#1700 Y#1701        (Wechsel XY Position)
M6 T#<_selected_tool>
G53 X#1801 Y#1802       (Taster Position)
G53 Z#1800                (Sichere Z Position)
G43.1 Z0                (TLO reset)
G91
G38.2 Z-60  F500        (messen grob)
G1    Z1.0  F500        (frei fahren)
G38.2 Z-10  F25         (messen fein)
#2000=[#5063+#5223]     (Tastpunkt+NP Verschiebung)
#2001=[#2000-#2002+#2003](Neu - diff + alt)
#2002=[#2000]           (Tastpunkt alt merken)
#2003=[#2001]            (Offset alt merken)
G1 Z5.0 F500            (frei fahren)
G90 G0
G43.1 Z#2001            (TLO set)
;(debug, Differenz ist: #2001)
(NP wiederhestellen nur G54 bis G59)
o100 if[#1900 EQ 540]
G54
o100 endif
o101 if[#1900 EQ 550]
G55
o101 endif
o102 if[#1900 EQ 560]
G56
o102 endif
o103 if[#1900 EQ 570]
G57
o103 endif
o104 if[#1900 EQ 580]
G58
o104 endif
o500 endif
o<messen> endsub
M2
27 Nov 2024 19:37 #315405 by Aciera
Which move do you mean?
- XY move (G53 X#1801 Y#1802 )
- Z move (G53 Z#1800 )
- the actual probing move (G38.2 Z-60 F500 )
27 Nov 2024 19:52 #315409 by pe8art
It stops doing this move.
28 Nov 2024 09:48 - 28 Nov 2024 09:51 #315446 by Aciera
For testing try inserting a queue buster command to halt the read ahead until the move is finished:
M66 E0 L0 (Stop read-ahead and wait for code execution to catch up)
Also try and start your config from terminal (note the minux+letter'L') and check for messages when the routine fails.
linuxcnc -l
Last edit: 28 Nov 2024 09:51 by Aciera.
28 Nov 2024 10:21 #315453 by pe8art
I tried the command but no different effect.
The Terminal spits out " 3 2 " every time regardless if it stops in the move or not.
It seems to be stopping at a specific sequence from tool to tool.
Some of the work ok some don't.
I have tried changing diameter of the tool for to no avail.
28 Nov 2024 15:51 #315474 by Aciera
Not sure what's going on but you might want to insert some debugging statements:
(DEBUG, 1702: #1702)
(DEBUG, 1700: #1700 1701: #1701 )
Also make sure you don't have X or Y offsets in your tool table.
28 Nov 2024 19:07 #315486 by pe8art
I included the debug in the file ( and added some more to see where its stops. )
It seems to stop between :
And
https://www.dropbox.com/scl/fi/e0e86m3nybph5brtqs0gq/debug.png?rlkey=nxuc87agn0ob35qfrmbiw368k&st=20z6b974&dl=0
Tools look like this:
T1 P1 X0.0 Y0.0 Z0.0 A0.0 B0.0 C0.0 U0.0 V0.0 W0.0 D1.0 I0.0 J0.0 Q0 ;1 MM
T2 P2 X0.0 Y0.0 Z0.0 A0.0 B0.0 C0.0 U0.0 V0.0 W0.0 D20.0 I0.0 J0.0 Q0 ;2mm
29 Nov 2024 07:44 #315518 by Aciera
Oh, apologies I was looking at the wrong move.
Maybe try this:
(DEBUG, 1801: #1801 1802: #1802 )
29 Nov 2024 16:23 #315558 by pe8art
I have included your code and added some extra debug comments.Consistently it stop changing from tool 1 to 2.
The code I added is:
(DEBUG, M6: #<_selected_tool> )
(DEBUG, before Z#1800)
(DEBUG,Before G43)
(DEBUG, before G91)
G91
(DEBUG, before G38.2)
29 Nov 2024 18:20 #315565 by Aciera
Only other thing I can think of is to add 'G0' to those 'G53' lines.
Time to create page: 0.688 seconds
