Gmoccapy Toollength sensor routine stops sometimes
29 Nov 2024 19:01 #315572 by pe8art
Unfortunately that did not work either.
I tried pulling apart the X and Y movement.
It stops at the X movement.
If I put Y first it completes that command but than stops at X.
02 Dec 2024 18:02 #315815 by pe8art
I just tried it with Axis, and that works like a charm.
So it seems to be only in combination with Gmoccapy.
Anyone any ideas?
12 Jan 2025 14:06 #318777 by zz912
You can try remove AUTOMATIC_G43 from gmoccapy.py:
github.com/LinuxCNC/linuxcnc/pull/3113/f...89eab9bcc7a6913808a9
Time to create page: 0.137 seconds
