Small touchscreen display 7-10' -> 14-16"
- slowpoke
- Thank you received: 28
18 Dec 2024 21:52 #316951
by slowpoke
I took you advice and ordered a Lenovo Yoga. The touchscreen is miles better than the cheap display I was planning to use with the Pi. So no more Pi, I'm going touchscreen Yoga and I also have a docking station. The Yoga presently has Windows on it however I have no desire to keep windows.
So regarding getting LinuxCNC up and running on the Yoga:
1) It's never been clear to me if the latest LinuxCNC release is hardware dependent ie. one version for a PC and a different version for say a PI?
2) A link to the correct install file for a PC?
3) A link to a "How to install" , where to get the file, and how to install including over-writing the existing Windows install etc, would be much appreciated.
Thanks in advance,
Jeff
Replied by slowpoke on topic Small touchscreen display 7-10' -> 14-16"
tommylight,Out of curiosity, how much is a RPI and a good touchscreen these days?
Wondering as i got a Lenovo X1 Carbon Yoga for 120 and a Lenovo Yoga Y370 for 220, bot work for LinuxCNC with Mesa, both have 120Hz touchscreens, very high quality ones, very good keyboards, and both do over 4-6 hours on batteries.
Thanks in advance,
Jeff
- Thank you received: 7493
18 Dec 2024 23:27 #316962
Replied by tommylight on topic Small touchscreen display 7-10' -> 14-16"
To make it easier for you, PC's are not RPI's, so stop thinking the same way about them.
PC is a standard for over 30 years, it changes a lot but everything else changes with it, mostly everything works out of the box in Linux
RPI is a good idea that went belly up very fast and made a huge mess, and nothing works as it should or without wasting huge amounts of time to fix stuff
Get the ISO from the downloads page, if you want the official version, burn to USB, boot from USB, install.
-or get the Debian 12 ISO with whatever Desktop Environment you like
-or get the Linux Mint Debian Edition 6
for last two: Burn, boot, install, reboot, then
sudo apt update
sudo apt upgrade
sudo apt install linuxcnc-uspace
sudo apt update
sudo apt upgrade
The following user(s) said Thank You: slowpoke
Time to create page: 0.075 seconds
