Tip on how to plan a machine
30 Nov 2024 05:27 #315606 by timo
Tip on how to plan a machine was created by timo
Hello,
i was quite fed up with undocumented components on my 2nd hand machine.
That is why I ripped it apart and decided to re-do the complete electric syste.
Now I was thinking it is a good idea to make some sort of wiring diagram, before starting the actual work.
This is to help adding more functions in the future, helps with repair. ( I want to avoid to have to reverse engineer my own installation )
From another thread I learned that this kind of plan might become also helpful to create a structured .hal and .ini file
Just to give an idea what I am up to.
A simple x-y-z mill, optional rotary axis a or c, (maybe rigid tapping, given the low torque spindle probably useless), MPG
Components that I have so far:
  • PC
  • Mesa Card
  • 3 open loop stepper drivers
  • 3 stepper motors from old system
  • 1 closed loop stepper with integrated driver (for rotary axis)
  • Power supply 80V DC
  • MPG (wires single switches, "no brain")
  • BLDC spindle with driver (from old system) 0-10V speed control (can be pluged to MESA card)
  • x-y-z proximity switches
  • Temp switch for spindle overheat
  • (optional) coolant pump
  • (optional) spindle encoder
I am not so much looking for a wiring instruction, more for some advise how to document a system like this. (pen and paper, some free software?)
Greetings Timo
30 Nov 2024 07:35 #315611 by tommylight
30 Nov 2024 08:05 #315616 by timo
Replied by timo on topic Tip on how to plan a machine
So that is basically a table first, no big graphical overview?
Control panels often look very daunting. :-)
Rule No. 1 seems to be: Panel must be twice as big as you would initially think!
30 Nov 2024 08:11 #315617 by tommylight
Replied by tommylight on topic Tip on how to plan a machine
Good rule. :)
30 Nov 2024 19:08 #315676 by rodw
Replied by rodw on topic Tip on how to plan a machine
I also use a table. I always update the table before connecting a new wire.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
The following user(s) said Thank You: timo
03 Dec 2024 13:42 #315884 by RotarySMP
Replied by RotarySMP on topic Tip on how to plan a machine
I do wiring diagrams. For my lathe I used Qelectrotech. It is pretty clunky, but works.
04 Dec 2024 05:01 #315931 by timo
I am not sure how exactly. :-) I think I will proceed with a Table 1st.
Then give the Qelectrotech a try.
Time to create page: 0.131 seconds
