7i92t 7i77 problem
1 year 10 months ago #317616 by RK
Replied by RK on topic 7i92t 7i77 problem
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.129 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.165 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.534 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.144 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.564 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.583 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.570 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.544 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.549 ms
64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=0.542 ms
64 bytes from 10.10.10.10: icmp_seq=11 ttl=64 time=0.161 ms
64 bytes from 10.10.10.10: icmp_seq=12 ttl=64 time=0.543 ms
64 bytes from 10.10.10.10: icmp_seq=13 ttl=64 time=0.401 ms
64 bytes from 10.10.10.10: icmp_seq=14 ttl=64 time=0.439 ms
64 bytes from 10.10.10.10: icmp_seq=15 ttl=64 time=0.547 ms
64 bytes from 10.10.10.10: icmp_seq=16 ttl=64 time=0.153 ms
64 bytes from 10.10.10.10: icmp_seq=17 ttl=64 time=0.175 ms
^C
--- 10.10.10.10 ping statistics ---
17 packets transmitted, 17 received, 0% packet loss, time 16378ms
rtt min/avg/max/mdev = 0.129/0.396/0.583/0.184 ms
1 year 10 months ago #317617 by PCW
Replied by PCW on topic 7i92t 7i77 problem
OK that's curious. How did you get the pinout information if not via mesaflash?
1 year 10 months ago #317618 by RK
~$ mesaflash --addr 10.10.10.10 --device=ETHER --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 180.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P1
1 17 IOPort SSerial 0 TXEn5 (Out)
14 18 IOPort SSerial 0 TXData5 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData4 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData3 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
1 year 10 months ago #317620 by PCW
In that case
mesaflash --addr 10.10.10.10 --device=ETHER --rpo 0x1000
should work
(with 7I77 disconnected)
1 year 10 months ago #317622 by RK
I tried something different here with the following result.
~$ mesaflash --addr 10.10.10.10 --device=ETHER --rpo 0x1000
000192FF
1 year 10 months ago #317623 by RK
This is the result for the 7i92t unplugged from the 7i77.
0001FFFF
Time to create page: 0.271 seconds
