7i92t 7i77 problem
29 Dec 2024 17:19 #317628 by PCW
Replied by PCW on topic 7i92t 7i77 problem
Are the 7I77 encoder jumpers set to match the encoder type?
(differential or single ended)
29 Dec 2024 17:31 #317630 by RK
Replied by RK on topic 7i92t 7i77 problem
Voltage looks good as well. Getting 4.9 volts at encoders and 23.9 volts at vin.
29 Dec 2024 17:34 #317631 by PCW
Are the encoders differential or single ended and is the 7I77 jumpered to match?
29 Dec 2024 17:54 #317633 by RK
PCW your a life saver!!
This project got shelved for a long time and I forgot about the jumpers. I see I only set the first axis. After setting the others I now have function. Thank you very much.
29 Dec 2024 20:38 #317640 by PCW
Ha! should have asked about the encoder mode first...
Time to create page: 0.098 seconds
