Spindle Pulses Lost in System
- 10K
- Thank you received: 33
31 Jan 2025 21:20 #320259
by 10K
Replied by 10K on topic Spindle Pulses Lost in System
The counts are all negative, that is they get more negative when the spindle is turning. Same for the RPM. I have an entry in my postgui that flips it:
setp scale.0.gain 60
setp lowpass.0.gain 0.010000
net spindle-velocity-feedback-rps => lowpass.0.in
net spindle-fb-filtered-rps lowpass.0.out => abs.0.in
net spindle-fb-filtered-abs-rps abs.0.out => scale.0.in
net spindle-fb-filtered-abs-rpm scale.0.out => gmoccapy.spindle_feedback_barPlease Log in or Create an account to join the conversation.
- Thank you received: 5330
31 Jan 2025 23:07 #320266
Replied by PCW on topic Spindle Pulses Lost in System
That fixes the display, but doesn't allow spindle synchronized motion.
The way to fix this is to set the encoder scale to -180
- 10K
01 Feb 2025 15:18 #320327
by 10K
Yes, changing the sign on the scale flips over the following PINs:
(all begin with hm2_7i92.0.encoder.00.)
position
velocity-rpm
velocity
the change has no effect on:
count
rawcounts
As it turned out, I fixed it another way. I had the ESD button connected to the encoder-B DB-25 P11 (14) input. I moved the ESD to my BOB #2 and left no input for encoder-B. This flipped the encoder.00 inputs to all positive and I was able to leave the encoder scale at +180..
Now I can thread again, so problem solved! Thanks for the help!
position
velocity-rpm
velocity
count
rawcounts
Time to create page: 0.075 seconds
