PWM with a 7i96 and 7i85
03 Feb 2025 23:01 - 03 Feb 2025 23:03 #320543 by jtrantow
PWM with a 7i96 and 7i85 was created by jtrantow
I'm running a 7i96 with a 7i85 for my lathe(steppers and linear encoders) using 7i96_7i85ssdid.bit I have been using LCNC pwmgen and I'd like to switch to the Mesa pwmgen before I spend time tuning the spindle VFD pid further. (I use the stepgen.00.index-enable pin for homing)
I loadrt [HM2](DRIVER) board_ip=[HM2](ADDRESS) config="num_encoders=3 num_pwmgens=1 num_stepgens=4 sserial_port_0=00xxxx" I'm using TB3 ENC 0, ENC 1, ENC2 on the 7i85 and TB1 STEP 0, STEP 1, STEP 2, STEP 3 on the 7i96.This all works with the LCNC pwmgen driving ssr.00.out-02.
I added the mesa pwmgen and I can run the mesa pwmgen in parallel but I can't find the pwmgen signal coming out the Mesa board.
I was expecting to see the PWM output on the TB2 STEP4 (TB2-02, TP2-03) connector but I do not see a PWM gen signal?
7i96_7i85ssdid.pin from readhmid reports there is a PWM module in the firmware (and I can see the pwmgen pins in HALMeter and HALShow) but I can't figure out the pwm signal connector?
LCNCpins.txt doesn't show the PWM assignment either?
LatheSpindle.hal has my relevant HAL connections.
Any help would be appreciated.
Last edit: 03 Feb 2025 23:03 by jtrantow.
03 Feb 2025 23:42 #320545 by PCW
Replied by PCW on topic PWM with a 7i96 and 7i85
First, it Looks like that configuration is for a 7I85S rather than 7I85
 and second it look like custom firmware that has a mistake
(a PWM module instantiated but no pins brought out)
A configuration including a PWMgen should have a P in the name
I can make a proper configuration in a day or so if you wish
Do you have a 7I85 or 7I85S?
04 Feb 2025 00:29 #320548 by jtrantow
Replied by jtrantow on topic PWM with a 7i96 and 7i85
I have a 7i85 and I've been using this firmware (without using pwm) for quite a while. The three encoders are on the 7i85. Not certain how it worked but it did.
I would appreciate a new version with PWM when you get the time. (I do need the index-enable for this config.)
I use 7i92 PWM for my router laser so I should be ok if the pin gets exposed.
11 Feb 2025 04:29 #321207 by jtrantow
Could I please get firmware for the 7i92 + 7i85 with the index-enable signals and a PWMgen? I've got the control box lying out on the floor until I can get the new firmware going. Thanks!
11 Feb 2025 15:29 - 11 Feb 2025 17:37 #321240 by PCW
7I85 or 7I85S?
Not sure what you mean by index enable.
(all configurations with encoders have an index enable pin)
 Edit: I looked back and you are using step/dir index and a 7I85
(even though the firmware you are using is for a 7I85S)
As far as a PWM output goes, it probably belongs on a free 7I96S
STEP/DIR output, Is that OK?
 This means two PWMgens on the 7I96S (PWMgen 0 for the built in analog and
PWMgen 1 for the PWM on the step/dir pins)
Last edit: 11 Feb 2025 17:37 by PCW.
11 Feb 2025 17:10 #321248 by jtrantow
Sorry I wasn't clear.
I'm looking for 7i96+7i85 firmware.
As of a year ago, see "Install Advice (HOME_USE_INDEX with stepper using an encoder)", the default firmware didn't supply the stepgen index-enable pin.
I need firmware that supports HOME_USE_INDEX and a PWM pin for a VFD.
11 Feb 2025 17:38 #321250 by PCW
Is there some reason you are not using the built in analog out on the 7I96S for the VFD?
11 Feb 2025 18:24 #321258 by jtrantow
I have a 7i96. Is analog out available on a 7i96?
11 Feb 2025 19:16 - 11 Feb 2025 19:16 #321266 by PCW
No, somehow I thought you had a 7I96S.
So is a 7I96 + 7I85 with one 7I96 stepgen (chan 4) replaced with PWM/DIR
and stepgen/encoder index on the 7I85 what you need?
Last edit: 11 Feb 2025 19:16 by PCW.
11 Feb 2025 21:56 - 11 Feb 2025 21:57 #321286 by PCW
7I96 + 7I85 configuration with step/dir index on 7I85
and PWM on STEP04 pin. DIR04 pin is left as GPIO
so it can be used as enable, direction, or whatever.
File Name: 7i96p1_7i85dsdi.zip
File Size:124 KB
Last edit: 11 Feb 2025 21:57 by PCW.
Time to create page: 0.124 seconds
