is 40V enough for DM556?
- Thank you received: 4150
04 Feb 2025 18:54 #320635
is 40V enough for DM556? was created by rodw
The DM556 will be fine at 57 volts AC
I have drivers rated or 65v AC and have run them at 64V and had to pay attention to other parameters as that was so close to the max.
So next time I ran them at 60v AC and then finally found the manufacturers specs which I think said 55 volts was recommended!
As far as DM556 goes, 40 volts is probably OK too. It is possible to calculate the maximum voltage to achieve specific performance. A friend developed a spreadsheet that does this. In a recent design for 2 amp Sanyo denki steppers, it only required 38 volts to achieve 60m/min rapids and 5 m/s/s accelleration on a 29kg gantry. But that was after some trial and error with gearbox ratios and pinion diameter to get to the sweet spot.
- Thank you received: 7488
04 Feb 2025 19:44 #320643
Replied by tommylight on topic is 40V enough for DM556?
40VDC is enough
57VAC is enough
Start wiring stuff, build the machine, make chips,...
57VAC is enough
05 Feb 2025 14:48 #320751
Connect ground only to box/chasis and to shielded cables.
Amps should be enough, move on.
Transformers can handle a lot of abuse, small overloads are no problem at all. After you power everything and have it running for 10-15 minutes, do check if it is heating from time to time, and even if it gets hot after and hour or two of work, as long as you can keep your palm on it, it is OK.
Human hand will have issues above 50 degree C, at 80 it burns like hell, and you will always know if the temp has gotten over 100 as your skin will remain attached to whatever you are touching, and fingers will turn shiny!
NO!Should I connect one transformer lead to ground (the plug is 3-prong, the chassis is grounded steel)?
- unknown
- Thank you received: 323
05 Feb 2025 15:33 #320758
by unknown
Replied by unknown on topic is 40V enough for DM556?
Soldering Iron or Wood Burner temps will melt skin. Had a friend when I was 9 or 10 who picked up his mum's Wood Burner Iron. Old Greg was a built different to everyone else. Pretty sure when he was working on a trawler he just pulled the tuna in with his bare hands, bet he would of tried to bite the heads off a few as well.
Time to create page: 0.132 seconds
