Welding CNC-Touch sensing
- rajsekhar
- Thank you received: 12
09 Feb 2025 06:51 #321044
by rajsekhar
Welding CNC-Touch sensing was created by rajsekhar
Now, I am planning a CNC welding setup.
In my application, touch sensing with Mig-wire is a must. Now, I tested the continuity between torch tip and earth clamp, it is already a closed circuit inside the welding machine. Then how do touch sensing work?
Looking for help/ideas.
Anyone already using such setup??
- partec
- Thank you received: 27
09 Feb 2025 07:30 #321045
by partec
Replied by partec on topic Welding CNC-Touch sensing
- rajsekhar
09 Feb 2025 14:07 #321065
by rajsekhar
Replied by rajsekhar on topic Welding CNC-Touch sensing
Well, I went through the website.
But, I want to know about the exact hardware configuration. That is not given in the website.
- partec
10 Feb 2025 08:41 - 10 Feb 2025 08:54 #321144
by partec
forum.linuxcnc.org/show-your-stuff/49100...routines-for-probing
Maybe illustrate your system a little?
Last edit: 10 Feb 2025 08:54 by partec.
Time to create page: 0.230 seconds
