- Thank you received: 5
Package linuxcnc is not available, but is referred to by another pacakge. This may mean that the package is missing, has been obsoleted, or is only availabe from another source.
E: Package 'linuxcnc has no installation candidate.
E: Conflicting values set for option Signed-by regarding source httyps://www.linuxcnc.or/ bookworm: /etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg != /usr/share/keyrings/linuxcnc.gpg
E: The list of sources could not be read.
Installing LinuxCNC
You might want to consider installating the docs package for your language
And also the linux-cnc-uspace-dev package
sudo apt-get install linuxcnc-doc-[en/'fr/de/ja/es/ru/da/hu/s1]
sudo apt-get install linux-dev
I'm not sure if I did this next, or it was somewhere else on the way.
Code:sudo apt-get update sudo apt-get dist-upgrade
Next I updated /etc/apt/sources.list.d/linuxcnc-uspace.list adding 2.9_rt tosudo apt-get purge linuxcnc-uspace
sudo apt-get purge linuxcnc-doc*
(Note I think this is what the linuxcnc-install.sh script called out in the directions is supposed to do, but instead it adds a linuxcnc.list to the sources.list.d, which causes a conflict with what is in linuxcnc-uspace.list and means that apt and the Synaptic Manager stop working.)deb [arch=amd64,arm64 signed-by=/etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg] www.linuxcnc.org/ bookworm base 2.9_uspace 2.9-rt
deb-src [arch=amd64,arm64 signed-by=/etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg] www.linuxcnc.org/ bookworm base 2.9_uspace 2.9-rt
Next I installed the real time kernel:sudo apt-get update
Note: You have to put in the version number. You can tab to find the right one to finish the line. It should have rtai.sudo apt-get linux-image-5.4.258-rtai-amd64
Here I don't think I needed the version number, but if you get an error you can try that.sudo apt-get install rtai-modules
sudo apt-get install linux-headers-5.4.258-rtai-amd64
The reward for all this... It looks like my min/max base thread latency is about the same as the preempt_rt version.sudo apt-get install linuxcnc
