Path to source code LCNC
- zz912
- Thank you received: 98
18 Feb 2025 20:11 #321941
by zz912
Path to source code LCNC was created by zz912
I am working on Pull Request for PncConf
forum.linuxcnc.org/gmoccapy/55011-lcnc-2...-g43?start=10#320344
My modification works, but they use absolute pah:
I need way to find "realtive" path in source code. It must work in RIP instalation and package instalation.
I would like ask you for help.
shutil.copytree('/home/zdenek/linuxcnc/linuxcnc-master/src/emc/usr_intf/pncconf/python', dirpython) I need way to find "realtive" path in source code. It must work in RIP instalation and package instalation.
04 Mar 2025 16:07 #323152
Replied by andypugh on topic Path to source code LCNC
Python can find the path to the running code with the __file__ system variable.
Depending on the code in question you might want to use sys.argv[0] instead.
In both cases you probably need to use the Python path manipulation functions to assemble the required path.
The following user(s) said Thank You: zz912
- zz912
08 Mar 2025 10:14 - 08 Mar 2025 10:42 #323504
by zz912
It's even used right here:
github.com/LinuxCNC/linuxcnc/blob/1c72d4...cconf/pncconf.py#L33
Now I have enough information to implement my original plan.
Create new files in the linuxcnc/src/emc/usr_intf/pncconf folder and then copy them to the new LCNC configuration using pncconf.
However, @Aciera came up with a better idea.
He doesn't want to create new files in the linuxcnc/src/emc/usr_intf/pncconf folder.
He wants to use the original data from the configs/sim/gmoccapy folder.
The advantage is that there will be no unnecessary duplicate data in the source files.
The problem is that I don't know how to define this path cleanly: configs/sim/gmoccapy
This path is different for RIP installation and different for package installation.
github.com/LinuxCNC/linuxcnc/blob/40fe3e...rc/configure.ac#L702
github.com/LinuxCNC/linuxcnc/blob/40fe3e...rc/configure.ac#L724
I think this might solve my problem, but I don't know how.
Replied by zz912 on topic Path to source code LCNC
I know it now."Python can find the path to the running code with the __file__ system variable."
stackoverflow.com help me with it. It is not problem for me."In both cases you probably need to use the Python path manipulation functions to assemble the required path."
Last edit: 08 Mar 2025 10:42 by zz912.
Time to create page: 0.082 seconds
