Mesa 7i97T + 7i84 + 7i78 configuration
1 year 8 months ago #322457 by JB-Motoring
Thanks PCW!!
I will try this in a few moments.
I will report, if it is working :)
BR
1 year 8 months ago #322574 by JB-Motoring
Okay,
I managed to get the encoders and Analog outputs working :)!
The next thing would be to get the io's working correctly.
I attached the corrected hal and ini- also the thing that comes from "halcmd show pin > all_linuxcnc_pins".
It feels like, I am missing some ios.
Is that correct? What about the sserial init. at the beginning of the .hal?
Thanks guys :)
1 year 8 months ago #322644 by Sziggy_NC
What io's do you think you are missing?
I notice that your digital in and digital out are empty. I had to use this to control my tool changer, pnumatic gripper, and to read spindle & tool changer sensors. It is how the O-code program can control the outputs and check the inputs.
I linked my door lock to some classic ladder pins.
Ex: "net door-open classicladder.0.in-01 => hm2_7i97.0.7i84.0.0.input-00"
The sserial seems like it might be right. Check to see if you can see the 7i84 pins in halshow. I had to expand pins > 7i97 > 0 > then I could seen the 7i84. If it doesn't work try replacing the XXXXX with zeros to become "sserial_port_0=00000000" It is what works for my 7i97T + 7i84 setup.
1 year 8 months ago #322664 by JB-Motoring
Maybe you can check the pinout here attached.
I will do some further tests now- coming from 2.8... and a 7i77, this stuff is quite "all new" now with ct ect. :D
Thanks guys!
BR
1 year 8 months ago #322715 by Sziggy_NC
I never updated my 7i97T firmware, so I won't be of any help with the pinout. If you are worried about not seeing the 7i84 io on that, don't be worried. The 7i84 just shows up in halshow once plugged in.
1 year 5 months ago #328353 by stenly
Hey there, JB-Motoring,
how did you manage to get the encoders in working order? Did you end up buying 5 IBV boxes? From past experiences EXE ones work better, but they are rather expensive. Or did you somehow directly connect them to the 7i97T card?
I have a similar machine I am looking to retrofit (DMU 50M, same encoders) and am wondering what hardware to buy.
Thanks.
Time to create page: 0.119 seconds
