Developing a Raspberry Pi Pico-based I/O Board for LinuxCNC
- atrex77
- Thank you received: 24
13 Mar 2025 11:10 #323820
by atrex77
Developing a Raspberry Pi Pico-based I/O Board for LinuxCNC was created by atrex77
Hi everyone,I've started developing an I/O board using the Raspberry Pi Pico. The prototype will feature 8x 24V outputs and 16x 24V inputs, communicating over Ethernet UDP with a real-time HAL driver. If everything works well, I plan to develop additional boards with step generation, analog outputs, and encoder inputs.At the moment, things are still evolving—I'm currently having the first batch of 5 PCBs manufactured and have already ordered the necessary components. Communication between the Pico and the real-time HAL is already working. :)I'll keep you updated as the project progresses!
The following user(s) said Thank You: Todd Zuercher, tommylight, elovalvo
- atrex77
14 Mar 2025 14:36 #323928
by atrex77
Replied by atrex77 on topic Developing a Raspberry Pi Pico-based I/O Board for LinuxCNC
Hi everyone,
I recently ran a benchmark test on my LinuxCNC setup to measure the data request speed, and I thought I’d share the results with you all. I’d love to hear your thoughts or any suggestions for further optimization!
The setup was connected as follows: [Linux 4.19.0-27-rt-amd (core i5) PC (3 byte send 5 byte receive)] -> [switch (TL-SG1005D)] -> [W5100S-Pico]. This was a non-realtime throughput measurement, and the result I got was a stable 2500 requests/second, which I think is pretty solid. I’m curious about your experiences—has anyone else done similar benchmarks, and what do you think of this performance?
Thanks in advance for your input!
- atrex77
14 Mar 2025 19:46 #323954
by atrex77
14 Mar 2025 21:15 #323959
Replied by andypugh on topic Developing a Raspberry Pi Pico-based I/O Board for LinuxCNC
Looks promising. Many LinuxCNC hardware interfaces run at 1kHz, and that works fine for most purposes.
Are you using the PIOs to handle the communications? Maybe there are gains to be made there?
Does the Pi-Pico handle UDP natively?
- atrex77
14 Mar 2025 21:42 #323961
by atrex77
actually not using PIO now, the UDP data transfer runs on core0 and all io handling runs on the second core, i use the W5100s-evb-pico for the project with the wiznet library (using arduino ide) (for PIO testing i make a frequency generator (later stepgen) and send velocity from 1 of linuxcnc joint to it, it makes 2Mhz signal but dont have a fancy scope to find its jittering. Shock settled on my face, and a small smile appeared at the corner of my mouth when I saw the signal on the scope.
- atrex77
14 Mar 2025 21:47 #323962
by atrex77
i dont think all functions are able to handled with one pico, i have more time now for testing because the first PCB-s are only shipped on mar.23 and the components is in the coming week.
- atrex77
14 Mar 2025 21:56 #323963
by atrex77
i do not post it but i compiled my benchmark to windows also with nearly same results, so the pico is the bottleneck here.
- atrex77
14 Mar 2025 23:40 #323971
by atrex77
i have options to push the poll rate even further with PIO&DMA + using the W5100s interrupt pin.I won't be bored for a few days.
- unknown
- Thank you received: 323
15 Mar 2025 02:46 #323979
by unknown
Replied by unknown on topic Developing a Raspberry Pi Pico-based I/O Board for LinuxCNC
I think Scotta did some work with the Pico. Might be worth a look.
github.com/scottalford75/Remora-RP2040-W5500
- atrex77
26 Mar 2025 13:10 - 26 Mar 2025 13:11 #324962
by atrex77
Update: I'm making progress toward my goal. Here's a new screenshot of the burst transfer rate. I've moved away from Arduino IDE and switched to using the Pico-SDK and VS Code for coding. Added serial terminal to the code to set the IP address later without coding, the Pico now uses DMA and Burst SPI data transfer instead of byte-by-byte transfer. I don’t think I can push the transfer rate any further. Unfortunately, neither the PCB nor the components have arrived yet, so I can’t proceed with the I/O. In the meantime, I’ve started experimenting with the step generator.
Last edit: 26 Mar 2025 13:11 by atrex77.
Time to create page: 0.197 seconds
