Need help with CNC machine build up
1 year 7 months ago #324474 by BX-CNC
lspci -v
sudo cat /proc/ioports | grep parport
ls /dev/parport*
these commands
1 year 7 months ago #324475 by ContinenteCNC
So should I unused all the other pins?
If you are testing only one motor, no need to use others.
I believe you have to change P1 to Enable, instead of E-stop.
1 year 7 months ago #324476 by ContinenteCNC
lspci -v
ls /dev/parport*
these commands
Go to "Applications" (upper left corner), then "Terminal Emulator"
Copy the first line, paste in terminal, press enter. Then copy the result or take a picture.
Do it for the remaning commands. One by one.
1 year 7 months ago #324477 by BX-CNC
This is the only enable I found
1 year 7 months ago - 1 year 7 months ago #324478 by ContinenteCNC
Is this your driver?
Last edit: 1 year 7 months ago by ContinenteCNC.
1 year 7 months ago #324479 by BX-CNC
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
Subsystem: Dell Core Processor DMI
Flags: fast devsel
Capabilities: <access denied>
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
Subsystem: Dell Core Processor PCI Express Root Port 1
Flags: bus master, fast devsel, latency 0, IRQ 29
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: f8000000-fbcfffff [size=61M] [32-bit]
Prefetchable memory behind bridge: c0000000-dfffffff [size=512M] [32-bit]
Kernel driver in use: pcieport
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
Subsystem: Device 0028:0027
Flags: fast devsel
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
Flags: fast devsel
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
Flags: fast devsel
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
Flags: fast devsel
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
Flags: fast devsel
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
Flags: fast devsel
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
Subsystem: Dell 5 Series/3400 Series Chipset HECI Controller
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at f7fffc00 (64-bit, non-prefetchable)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06) (prog-if 20 [EHCI])
Subsystem: Dell 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f7c00000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
Subsystem: Dell 5 Series/3400 Series Chipset High Definition Audio
Flags: bus master, fast devsel, latency 0, IRQ 33
Memory at f7ff8000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06) (prog-if 00 [Normal decode])
Subsystem: Dell 5 Series/3400 Series Chipset PCI Express Root Port 1
Flags: bus master, fast devsel, latency 0, IRQ 17
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 1000-1fff [size=4K] [16-bit]
Memory behind bridge: fbd00000-fbdfffff [size=1M] [32-bit]
Prefetchable memory behind bridge: be000000-be1fffff [size=2M] [32-bit]
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7a00000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a6) (prog-if 01 [Subtractive decode])
Subsystem: Dell 82801 PCI Bridge
Bus: primary=00, secondary=03, subordinate=03, sec-latency=32
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: fbe00000-fbffffff [size=2M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
00:1f.0 ISA bridge: Intel Corporation H57 Chipset LPC Interface Controller (rev 06)
Subsystem: Dell H57 Chipset LPC Interface Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06) (prog-if 01 [AHCI 1.0])
Subsystem: Dell 5 Series/3400 Series Chipset 6 port SATA AHCI Controller
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 30
I/O ports at cc00
I/O ports at c880
I/O ports at c800
I/O ports at c480
I/O ports at c400
Memory at f7800000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
Subsystem: Dell 5 Series/3400 Series Chipset SMBus Controller
Flags: medium devsel, IRQ 18
Memory at f7fff800 (64-bit, non-prefetchable)
I/O ports at 0400
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation G96CGL [Quadro FX 580] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation G96CGL [Quadro FX 580]
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=512M]
Memory at f8000000 (64-bit, non-prefetchable) [size=32M]
I/O ports at dc00
Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: nouveau
Kernel modules: nouveau
02:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetLink BCM57780 Gigabit Ethernet PCIe (rev 01)
Subsystem: Dell NetLink BCM57780 Gigabit Ethernet PCIe
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at fbdf0000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: tg3
Kernel modules: tg3
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
Flags: bus master, medium devsel, latency 64, IRQ 16
I/O ports at e800
Memory at fbe00000 (32-bit, non-prefetchable)
Kernel driver in use: 8139too
Kernel modules: 8139cp, 8139too
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers (rev 04)
Subsystem: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 04)
Subsystem: Intel Corporation Core Processor QuickPath Architecture System Address Decoder
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 04)
Subsystem: Intel Corporation Core Processor QPI Link 0
Kernel driver in use: i7core_edac
Kernel modules: i7core_edac
ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 04)
Subsystem: Intel Corporation Core Processor QPI Physical 0
ff:03.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller
ff:03.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder
ff:03.4 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Test Registers
ff:04.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers
ff:04.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers
ff:04.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers
ff:04.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers
ff:05.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers
ff:05.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers
ff:05.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers
ff:05.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers
This is result after enter the first line
Time to create page: 0.073 seconds
