Need help with CNC machine build up
1 year 7 months ago #324486 by BX-CNC
lspci -v
sudo cat /proc/ioports | grep parport
ls /dev/parport*
these commands
user@linuxcnc:~$ sudo cat /proc/ioports | grep parport
[sudo] password for user:
Sorry, try again.
user@linuxcnc:~$ ls /dev/parport*
ls: cannot access '/dev/parport*': No such file or directory
This is what i get after enter the password, nothing happen
1 year 7 months ago - 1 year 7 months ago #324487 by ContinenteCNC
lspci -v
ls /dev/parport*
these commands
Sorry, try again.
It seems you don't have a parallel port at all.
Are you using an old computer with onboard parallel port or a new computer with PCI card?
Last edit: 1 year 7 months ago by ContinenteCNC.
1 year 7 months ago #324488 by BX-CNC
lspci -v
ls /dev/parport*
these commands
Sorry, try again.
Are you using an old computer with onboard parallel port or did you have to add a PCI card?
I have a old PC donated by school and I have a parallel port connected to PC with a USB adapter. Since this PC doesnt have a parallel port connection.
1 year 7 months ago #324491 by BX-CNC
lspci -v
ls /dev/parport*
these commands
Sorry, try again.
and I did try using the parallel port tester but i got this
user@linuxcnc:~$ halrun -I -f ptest.hal
Could not open command file 'ptest.hal'
halcmd:
1 year 7 months ago #324492 by BX-CNC
lspci -v
ls /dev/parport*
these commands
Sorry, try again.
This is the connection. Parallel port from bob, port to usb adapter, adapter to pc
1 year 7 months ago - 1 year 7 months ago #324493 by ContinenteCNC
These USB adapters won't work.
You have to buy PCI card adapter with Sunix, Netmos or Moschip chipset. Avoid any WCH chipsets.
Time to create page: 0.066 seconds
