Need help setting up XYYZA for stepper motors
- Thank you received: 7488
28 Mar 2025 01:14 #325129
Replied by tommylight on topic Need help setting up XYYZA for stepper motors
Parallel port pin 16, not 016.
- Routerworks
- Thank you received: 14
28 Mar 2025 14:23 #325164
by Routerworks
Replied by Routerworks on topic Need help setting up XYYZA for stepper motors
Many thanks to both. Good catch 16, 17 not 016, 017. That eliminated that problem then it said pin 16 was already in use. I ommitted the "spindle out pin 16 and 17" then it worked.
4th Axis Mill opened up.
Can't find control for the A axis and some of the other directional keys have been switched around. Where would I correct them.
Mandy, Many, Many thanks,
Routerworks
Routerworks
- Routerworks
28 Mar 2025 22:39 #325200
by Routerworks
Ok, this must be the end of the road for this topic. I'll try a new topic as I don't even see the A axis on the screen.
Anyhow, I want to thank everyone again for your help as it was a good learning experience for me.
Regards,
Routerworks
Regards,
Routerworks
28 Mar 2025 23:29 #325204
Upload the current files.
Just to be sure, that is a 4 axis/ 5 joints machine where Y axis is tandem?
- Routerworks
28 Mar 2025 23:35 #325206
by Routerworks
Yes. The 3 axis setup works fine.
Joints
0=X
1=Y
2=Y
3=Z
Joints
0=X
1=Y
2=Y
3=Z
- Routerworks
28 Mar 2025 23:57 #325207
by Routerworks
It might be working but I don't know what keys will rotate it on screen. the setup has changed what keys affect each axis.
- Routerworks
29 Mar 2025 00:31 #325211
by Routerworks
When I us the A axis jog it does move the "cone" A axis. It only goes from 0 to -6 which looks like the settings for the Z axis in inches instead of degrees.
Getting there, appreciate your help. Almost there.
29 Mar 2025 00:34 #325212
Files?
- Routerworks
29 Mar 2025 00:41 #325213
by Routerworks
Thank you. Here they are.
29 Mar 2025 00:56 #325216
From the ini file:should be JOINT and should be 5
and...............
Why so many
DISPLAY_JOINT = 4
DISPLAY_JOINT_NAME = A
[GEOMETRY]
AXIS_A_JOINT = 4
AXIS_A_TYPE = ROTARY
AXIS_A_LENGTH = 30
[TRAJ]
COORDINATES = X Y Y Z A
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 36
MAX_LINEAR_VELOCITY = 4.00
AXIS_A_JOINT = 4
I have no idea how this is starting, to many things that should not be there.
The ONLY things to change, after adding the 4th axis, are Display if it does not show how you want in the GUI, and TRAJ section.
JOUNT = 4and...............
Why so many
DISPLAY_JOINT = 4
[GEOMETRY]
AXIS_A_JOINT = 4
AXIS_A_LENGTH = 30
[TRAJ]
LINEAR_UNITS = inch
AXIS_A_JOINT = 4
Time to create page: 0.235 seconds
