Need help setting up XYYZA for stepper motors
27 Mar 2025 15:42 #325070 by Routerworks
I need help setting dual Y, X, Z and A axis .  A is rotation.  The config wizard won't set up YY with A axis.  I have a functional XYYZ program that I copied the additional Y axis  ini and hal file components from and added to an XYZA file I was able to configure in config wizard.  Maybe someone can see what I am missing as I get all kinds of errors.  The Dual Y Axis Mill works fine.
thanks in advance for any help.
Routerworks
27 Mar 2025 15:45 #325071 by Routerworks
Replied by Routerworks on topic Need help setting up XYYZA for stepper motors
Here are the A asix files
File Name: 4ThAxisDua...3-27.txt
File Size:5 KB
File Size:3 KB
27 Mar 2025 16:24 #325074 by PCW
What are the errors?
27 Mar 2025 17:53 #325080 by Routerworks
Here is the error report.  Had to take pictures.  Working on pc windows.  Linuxcnc is on separate pc no wifi.
Thanks in advance
27 Mar 2025 17:54 #325081 by Routerworks
Here is the lower half of the report
27 Mar 2025 17:59 #325082 by Routerworks
27 Mar 2025 18:12 - 27 Mar 2025 18:21 #325083 by PCW
setp stepgen.4.position-scale [JOINT_4]SCALE
setp stepgen.4.steplen 1
setp stepgen.4.stepspace 0
setp stepgen.4.dirhold 40000
setp stepgen.4.dirsetup 40000
setp stepgen.4.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.4.motor-pos-cmd => stepgen.4.position-cmd
net zpos-fb stepgen.4.position-fb => joint.4.motor-pos-fb
net zstep <= stepgen.4.step
net zdir <= stepgen.4.dir
net zenable joint.3.amp-enable-out => stepgen.4.enable
net estop-out => iocontrol.0.emc-enable-in
The red text probably should be:
setp stepgen.4.maxaccel [JOINT_4]STEPGEN_MAXACCEL
net apos-cmd joint.4.motor-pos-cmd => stepgen.4.position-cmd
net apos-fb stepgen.4.position-fb => joint.4.motor-pos-fb
net astep <= stepgen.4.step
net adir <= stepgen.4.dir
net aenable joint.4.amp-enable-out => stepgen.4.enable
Note that you also need to connect the astep and adir signals to the appropriate
parallel port pins similar to this (z highlighted ):
setp parport.0.pin-01-out-invert 1
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net y0step => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net y0dir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net y1step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net y1dir => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
Last edit: 27 Mar 2025 18:21 by PCW.
27 Mar 2025 20:18 #325102 by Routerworks
Many thanks, I will give this a try and report back.
27 Mar 2025 23:09 #325125 by Routerworks
Here is the result after changes.
27 Mar 2025 23:46 #325126 by PCW
That's an odd error as a parallel port in mode "out" should have pin 16
Can you comment out any line that causes an error, launch LinuxCNC
and then in a terminal type:
halcmd show pin parport
and show the results here
Time to create page: 0.504 seconds
