[SOLVED]linuxcnc Latency test ambiguous results
28 Apr 2025 07:54 - 15 May 2025 09:46 #327214 by DarkPhoinix
I have run various tests with different commands to check the latency but I don't know if I'm doing things correctly:
stress --cpu 4 --io 4 --vm 4 --vm-bytes 1024M --timeout 120s
[code]chrt 99 ping -i .001 10.10.10.10 -c 40000000
with stress I get good results with all the cpus at maximum usage, instead with chrt even if the cpus are not busy I see disastrous latency.
what should I do (kernel parameters, kernel recompilation)? the PC is not good for LinuxCNC?
If I don't use hardware parallel port and use NVEM, does this latency matter for operation?
my hardware:
motherboard: P8H61/USB3 R2.0
CPU: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
VGA: VGA compatible controller: NVIDIA Corporation GF119 [GeForce GT 610] (rev a1) (Driver NOUVEAU)
Controller: NVEM V5
[/code]
Last edit: 15 May 2025 09:46 by DarkPhoinix.
28 Apr 2025 11:35 #327221 by PCW
Replied by PCW on topic linuxcnc Latency test ambiguous results
What was the result of the ping command?
The following user(s) said Thank You: DarkPhoinix
28 Apr 2025 12:04 #327224 by DarkPhoinix
Replied by DarkPhoinix on topic linuxcnc Latency test ambiguous results
You need result of all 40000000?
28 Apr 2025 12:31 #327226 by PCW
No, just the statistics reported at the end of:
ping -c 4 -i .2 10.10.10.10
sudo chrt 99 ping -i .001 -q -c  60000 10.10.10.10
The last command will run for 1 minute
28 Apr 2025 13:25 #327228 by DarkPhoinix
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=255 time=0.295 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=255 time=0.416 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=255 time=0.278 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=255 time=0.425 ms
--- 10.10.10.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 612ms
rtt min/avg/max/mdev = 0.278/0.353/0.425/0.067 ms
60000 packets transmitted, 59999 received, 0.00166667% packet loss, time 60751ms
rtt min/avg/max/mdev = 0.158/0.255/4.918/0.225 ms
28 Apr 2025 13:59 #327230 by PCW
Yeah, ~ 5 ms will be an issue
What is the Ethernet hardware?
If Realtek you likely need to install the DKMS driver
28 Apr 2025 14:40 - 28 Apr 2025 14:41 #327232 by DarkPhoinix
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 09)
I need search and compile him or only apt-get?
Last edit: 28 Apr 2025 14:41 by DarkPhoinix.
28 Apr 2025 14:47 #327233 by PCW
28 Apr 2025 17:12 #327242 by DarkPhoinix
I have a nvidia 610 video card, should I replace nouveau with the proprietary nvidia driver? (I already did it in theory)
28 Apr 2025 17:16 #327244 by PCW
I don't think the video is an issue as it would show up in the generic latency tests.
Time to create page: 0.230 seconds
