[SOLVED]linuxcnc Latency test ambiguous results
- DarkPhoinix
- Thank you received: 6
02 May 2025 10:50 #327491
by DarkPhoinix
Is it working? I don't understand what cat /proc/interrupts does maybe there are old values before the switch to core 3?
Replied by DarkPhoinix on topic linuxcnc Latency test ambiguous results
while true; do cat /proc/interrupts | grep enp3s0; sleep 1; done
26: 0 0 123 5373 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5416 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5464 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5512 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5560 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5608 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5656 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5704 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5752 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5812 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5872 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5920 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 5968 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6016 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6064 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6112 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6173 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6221 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6269 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6317 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6365 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6413 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6461 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6509 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6569 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6641 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6689 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6737 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6785 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6833 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6912 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 6960 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 7008 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 7070 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 7118 IR-PCI-MSI 1572864-edge enp3s0
26: 0 0 123 7166 IR-PCI-MSI 1572864-edge enp3s0Please Log in or Create an account to join the conversation.
- Thank you received: 5330
02 May 2025 14:38 #327506
Replied by PCW on topic linuxcnc Latency test ambiguous results
That looks like its working since you are only getting interrupts on CPU 3
(CPU 2 interrupt count is not changing)
The following user(s) said Thank You: DarkPhoinix
- DarkPhoinix
02 May 2025 22:32 #327568
by DarkPhoinix
thank you very much! now all I have to do is run the stepper and I can gain some experience with linuxcnc.
- DarkPhoinix
03 May 2025 18:41 #327625
by DarkPhoinix
- DarkPhoinix
07 May 2025 10:48 - 07 May 2025 13:19 #327937
by DarkPhoinix
Next i upload the DMA txt version for mi NVEMV5 RT1052 the problem is back and now need only 5 videos 4k without rustdek opened to see junction error!
I don't know what else to do. Except look for a motherboard that has video output.
Or maybe buy new hardware?
No activity
5 youtube video 4k windows
5 youtube video 4k windows and rustdesk connection
No activity
Last edit: 07 May 2025 13:19 by DarkPhoinix.
- DarkPhoinix
08 May 2025 11:58 - 08 May 2025 12:00 #327986
by DarkPhoinix
I've tried everything:
in the ini I put:kernel parameters:
it doesn't work, I get improvements and delays in the error but while using YouTube sooner or later the job fails.
I'm understanding that LinuxCNC only works with specific hardware systems and it's not possible to use it everywhere. I have also tried 3 completely different hardware setups, and the other 2 have impressive latencies.
One of which is new hardware with integrated video card, Alder Lake N95 CPU, and 16GB of RAM.
So the question is: what hardware supports LinuxCNC? What hardware should a user buy who wants to use LinuxCNC?
in the ini I put:
#SERVO_PERIOD = 1000000
SERVO_PERIOD = 2600000
#SERVO_PERIOD = 700000
#SERVO_PERIOD = 777777
#SERVO_PERIOD = 1000000#GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=2,3 r8168.EEE=0 pcie_aspm=off nohz_full=2,3 acpi_irq_nobalance noirqbalance irqaffinity=0 processor.max_cstate=0 intel_idle.max_cstate=1"
#WORKS WELL#GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=2,3 r8168.EEE=0 pcie_aspm=off nohz_full=2,3"
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=2,3 r8168.EEE=0 pcie_aspm=off nohz_full=2,3 acpi_irq_nobalance noirqbalance irqaffinity=0 processor.max_cstate=0 intel_idle.max_cstate=1 radeon.dpm=0 idle=poll"
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=2,3 r8168.EEE=0 pcie_aspm=off nohz_full=2,3 acpi_irq_nobalance noirqbalance irqaffinity=0,1 processor.max_cstate=0 intel_idle.max_cstate=1 radeon.dpm=0 idle=poll"
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=2,3 r8168.EEE=0 pcie_aspm=off nohz_full=2,3 acpi_irq_nobalance noirqbalance irqaffinity=0,1 processor.max_cstate=0 intel_idle.max_cstate=1 idle=in"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=2,3 r8168.EEE=0 pcie_aspm=off nohz_full=2,3 irqaffinity=0,1 processor.max_cstate=0 intel_idle.max_cstate=1 idle=poll"it doesn't work, I get improvements and delays in the error but while using YouTube sooner or later the job fails.
Last edit: 08 May 2025 12:00 by DarkPhoinix.
- DarkPhoinix
08 May 2025 12:18 - 08 May 2025 12:21 #327987
by DarkPhoinix
Last edit: 08 May 2025 12:21 by DarkPhoinix.
- DarkPhoinix
08 May 2025 17:08 #328017
by DarkPhoinix
Thanks,
intel adaptive thermal monitor need set disable? i dont want burn CPU!
- DarkPhoinix
08 May 2025 18:31 - 08 May 2025 18:33 #328024
by DarkPhoinix
deleted
Last edit: 08 May 2025 18:33 by DarkPhoinix.
- DarkPhoinix
15 May 2025 14:46 #328514
by DarkPhoinix
Today i try a new MB with HDMI exit! The youtube video test is DUMP!
Try stress test + glxgear for your system dont lose time!
Time to create page: 0.361 seconds
