Best practice for installing custom Python packages in LinuxCNC?
14 May 2025 13:54 - 14 May 2025 13:56 #328446 by workshop54
Hi all,
I’ve developed a custom Python package — and not just a loose .py file, but a real multi-module package, complete with pyproject.toml, unit tests, internal structure, and even a __str__ for logging prettiness. Yes, I know, it’s total overkill for something that just drives the lubrication pump… but hey, it’s fun
The code I wrote can be found here if anyone is interested: github.com/johanvergeer/maho-mh400e-conf...ree/main/lubrication
Now I want to use this package from a Python script that’s launched via loadusr in my machine config.
Some context:
  • The script uses linuxcnc, hal, and qtvcp modules.
  • LinuxCNC runs on the global system Python interpreter as far as I can see, which means my package has to be available outside of any virtual environment.
  • Installing with pip install . into the global Python environment technically works, but it’s strongly discouraged on modern Debian-based systems due to PEP 668. I’ve already seen Poetry try to uninstall half of /usr/lib/python3
  • Virtualenvs don’t help much either, since they can’t see LinuxCNC’s compiled modules.
  • Adding my repo folder to sys.path is possible, but feels like duct tape.
So… what’s the best practice here?
  • Is it acceptable to install your own packages into something like /usr/lib/python3/dist-packages/?
  • Is there an officially recommended way to include custom Python packages that need to be imported across multiple files or used in different HAL components?
Or am I simply in “here be dragons” territory and should stick to a bunch of flat .py files with global state?
Any advice or patterns you use would be greatly appreciated!
Cheers,
Johan
Last edit: 14 May 2025 13:56 by workshop54.
14 May 2025 14:34 #328459 by workshop54
Fully agreed — if LinuxCNC ever gets a proper Java API, I’ll gladly throw my Python into the chip tray
Until then, I’ll just keep pretending my Python package has structure and discipline… while knowing deep down it’s all held together by logging statements and good intentions
14 May 2025 14:47 #328463 by tommylight
If you want to move away from Python, try "Ruby on Rails".
Going from Python to Java is absolutely moving backwards.
15 May 2025 11:31 #328504 by JT
Why not just build a deb and install your package?
github.com/jethornton/simple-deb
github.com/jethornton/simple-pyqt5-deb
Or if you're using Flex GUI you can just add it to your ini and it gets imported.
gnipsel.com/linuxcnc/flexgui/python.html
JT
19 May 2025 12:38 #328740 by rodw
Python does not even have switch statements!
It does now since 3.10
www.reddit.com/r/pythontips/comments/122...s_switch_statements/
Personally I much prefer python over php and Java but C I am much more comfortable with.
It just annoys me that Python can do things in 100 lines that would take 1000 in C
24 May 2025 10:15 #329040 by rodw
Coding is not about speed, it's about the journey.
Its really about progrmming  defensively so you can enjoy the journey.
24 May 2025 13:09 #329044 by tommylight
You can have both, try Assembly !
Time to create page: 0.129 seconds
