Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
- dunnitagain
09 Jun 2025 23:57 #330060
by dunnitagain
Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error! was created by dunnitagain
Hello , Newb here. Just bought 2 , very nice Bridgeport and Jet mill retrofits , with Microkentics Steppers and PICO Universal Stepper cards , from the estate of a friend. Machines are very nicely built.
They sat idle since 2013, the Cmos batteries were dead . Ive been working on the .ini file of the Jet mill , to correct the homing sequence.
Everything was great , fixed the Z Axis homing . Powered down the control to plug the A axis in . Now on power up , it will not load Linuxcnc 2.4.5.
Is there a way to decode the error message , to see what i need to change, to return functionality ?
The computers are bare bones machines, no network capabilities , just USB.
Where can I look , or were do I Start ?
- Thank you received: 7488
10 Jun 2025 00:40 #330061
Replied by tommylight on topic Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Post the error logs here so we can have a look.
Especially the Debug part...
10 Jun 2025 14:32 #330087
Replied by andypugh on topic Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
That's a pretty ancient LinuxCNC version, but getting it going as it used to work as a first step makes sense prior to any attempts to update.
The Pico USC is still supported as far as I know.
forum.linuxcnc.org/27-driver-boards/14977-pico-systems-faq
If you post questions in the driver-boards section there is a fair chance that the manufacturer will see them.
- dunnitagain
11 Jun 2025 00:43 #330113
by dunnitagain
Replied by dunnitagain on topic Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Great ! i have to figure out how to load the error files to a USB Stick .
The builder was a bit of a Conspiracy theorist... he had everything locked down.
- dunnitagain
11 Jun 2025 00:45 #330114
by dunnitagain
Thank You Andy, Im sure it was my fault, just to old and Technologically inferior to comprehend.
- JT
- Thank you received: 593
11 Jun 2025 22:38 #330180
by JT
Replied by JT on topic Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
Just so you know I run Ubuntu 10.04 on my CHNC lathe with no issues and no reason to upgrade. Oh and I'm running LinuxCNC 2.7.15.
Posting the actual error message would help.
JT
JT
12 Jun 2025 17:31 #330219
It's not ideal, but we can work with photos of the error log on the screen.Great ! i have to figure out how to load the error files to a USB Stick .
- dunnitagain
14 Jun 2025 20:34 #330284
by dunnitagain
Were are the error files located ? var/ Error ? This ubuntu is very unfamiliar to me .
- dunnitagain
14 Jun 2025 22:55 - 14 Jun 2025 23:01 #330286
by dunnitagain
This is the .ini that I modified while working on the Z Axis Homing .
Last edit: 14 Jun 2025 23:01 by dunnitagain. Reason: forgot
14 Jun 2025 23:13 #330287
[TRAJ}Axis XAxis YDelete .ini from those lines.
MAX_ACCELERATION = 20.0.iniMAX_LIMIT = 23.651.iniP = 20.iniPlease Log in or Create an account to join the conversation.
Time to create page: 0.157 seconds
