Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
- dunnitagain
14 Jun 2025 23:26 #330288
by dunnitagain
Replied by dunnitagain on topic Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
I wonder how the were inserted? Thank You , I will try it tommorrow.
- dunnitagain
15 Jun 2025 13:34 #330307
by dunnitagain
I cleaned up the lines , but It still wont load . In the file explorer, it looks like I have 2 different .ini files. Is there a way to properly clean up this mess , without starting over? Machine has direct drive steppers , and DRO Scales for position feedback , Tool probe also. I hate to try and reset all pins and parameters.
- dunnitagain
15 Jun 2025 14:54 #330309
by dunnitagain
I went to the file system
home/ jetmill1 / emc2 / configs / jetmill1 /
there seems to be several .ini files in that folder.
could it be looking at the wrong config file?
- dunnitagain
15 Jun 2025 15:24 #330313
by dunnitagain
i also have and error in the debug ,
'/usr/realtime-2.6.32-122-rtai/modules/emc2/hal_ppmc.ko'
:-1 operation not permitted
jetmill1_load.hal:8:exit value 1
20 Jun 2025 20:01 #330593
Replied by andypugh on topic Linuxcnc 2.4.5 with Ubuntu 10.04 , Terminated with Error!
This problem has been seen at least once before. Maybe there is some help in this thread: forum.linuxcnc.org/38-general-linuxcnc-q...t-module-error#68736
- dunnitagain
25 Jun 2025 00:23 #330832
by dunnitagain
Thank You , I have had other things happening , ill try and work on it this weekend.
Time to create page: 0.183 seconds
