crashing at startup
- clayton2ndtry
- Thank you received: 5
21 Jun 2025 20:06 - 22 Jun 2025 19:38 #330656
by clayton2ndtry
crashing at startup was created by clayton2ndtry
It has worked perfectly for years. Suddenly, shortly after GUI appears:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.15
Machine configuration directory is '/home/clayton/linuxcnc/configs/by_machine.sherline.Sherline4Axis'
Machine configuration file is 'Sherline4Axis_inch.ini'
INIFILE=/home/clayton/linuxcnc/configs/by_machine.sherline.Sherline4Axis/Sherline4Axis_inch.ini
PARAMETER_FILE=stepper.var
TASK=milltask
HALUI=
DISPLAY=mini
Starting LinuxCNC...
Found file(REL): ./stepper_xyza.hal
Found file(REL): ./standard_pinout.hal
Starting DISPLAY program: mini
Can't issue MDI command when not homed
can't open none
task: 7606 cycles, min=0.000011, max=0.072272, avg=0.010010, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Removing NML shared memory segmentsDebug file information:
unable to realloc 2147381251 bytes
/usr/bin/linuxcnc: line 864: 20362 Aborted $LINUXCNC_TCL_DIR/$EMCDISPLAY.tcl -ini "$INIFILE" $EMCDISPLAYARGS
20317
20359
Stopping realtime threads
Unloading hal componentsKernel message information:
981] R8188EU: INFO indicate disassoc
[2037195.674251] R8188EU: INFO assoc success
[2037216.650871] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037216.658495] R8188EU: INFO indicate disassoc
[2037217.965893] R8188EU: INFO assoc success
[2037237.673242] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037237.680495] R8188EU: INFO indicate disassoc
[2037238.959023] R8188EU: INFO assoc success
[2037259.286369] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037259.299382] R8188EU: INFO indicate disassoc
[2037261.051633] R8188EU: INFO assoc success
[2037281.514753] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037281.522003] R8188EU: INFO indicate disassoc
[2037282.863403] R8188EU: INFO assoc success
[2037303.118753] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037303.127513] R8188EU: INFO indicate disassoc
[2037304.465029] R8188EU: INFO assoc success
[2037324.211525] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037324.218762] R8188EU: INFO indicate disassoc
[2037325.569025] R8188EU: INFO assoc success
[2037481.453793] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037481.461051] R8188EU: INFO indicate disassoc
[2037482.747678] R8188EU: INFO assoc success
[2037486.599543] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037486.606793] R8188EU: INFO indicate disassoc
[2037488.285436] R8188EU: INFO assoc success
[2037488.839790] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037488.847055] R8188EU: INFO indicate disassoc
[2037490.341934] R8188EU: INFO assoc success
[2037492.672302] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037492.679552] R8188EU: INFO indicate disassoc
[2037494.049432] R8188EU: INFO assoc success
[2037495.823808] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037495.831053] R8188EU: INFO indicate disassoc
[2037497.609186] R8188EU: INFO assoc success
[2037499.408424] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037499.415684] R8188EU: INFO indicate disassoc
[2037503.440811] R8188EU: INFO assoc success
[2037505.352932] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037505.360185] R8188EU: INFO indicate disassoc
[2037507.226435] R8188EU: INFO assoc success
[2037508.301927] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037508.309192] R8188EU: INFO indicate disassoc
[2037509.773440] R8188EU: INFO assoc success
[2037510.785928] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037510.793179] R8188EU: INFO indicate disassoc
[2037512.167564] R8188EU: INFO assoc success
[2037513.764050] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037513.771306] R8188EU: INFO indicate disassoc
[2037515.106565] R8188EU: INFO assoc success
[2037515.870303] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037515.877554] R8188EU: INFO indicate disassoc
[2037518.764188] R8188EU: INFO assoc success
[2037520.350687] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037520.357942] R8188EU: INFO indicate disassoc
[2037522.103439] R8188EU: INFO assoc success
[2037525.624434] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037525.631683] R8188EU: INFO indicate disassoc
[2037526.975199] R8188EU: INFO assoc success
[2037530.658436] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037530.665814] R8188EU: INFO indicate disassoc
[2037532.113444] R8188EU: INFO assoc success
[2037532.914307] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037532.921557] R8188EU: INFO indicate disassoc
[2037534.277066] R8188EU: INFO assoc success
[2037535.566679] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037535.573936] R8188EU: INFO indicate disassoc
[2037536.894572] R8188EU: INFO assoc success
[2037538.068805] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037538.076058] R8188EU: INFO indicate disassoc
[2037539.371459] R8188EU: INFO assoc success
[2037539.929942] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037539.937307] R8188EU: INFO indicate disassoc
[2037541.410821] R8188EU: INFO assoc success
[2037542.533439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037542.540688] R8188EU: INFO indicate disassoc
[2037543.890824] R8188EU: INFO assoc success
[2037544.517684] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037544.524937] R8188EU: INFO indicate disassoc
[2037546.208949] R8188EU: INFO assoc success
[2037547.293806] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037547.301187] R8188EU: INFO indicate disassoc
[2037548.703079] R8188EU: INFO assoc success
[2037549.173685] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037549.180934] R8188EU: INFO indicate disassoc
[2037550.507466] R8188EU: INFO assoc success
[2037551.055944] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037551.063313] R8188EU: INFO indicate disassoc
[2037552.415572] R8188EU: INFO assoc success
[2037552.868439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037552.875812] R8188EU: INFO indicate disassoc
[2037554.309571] R8188EU: INFO assoc success
[2037555.707444] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037555.714688] R8188EU: INFO indicate disassoc
[2037557.003952] R8188EU: INFO assoc success
[2037557.490188] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037557.497444] R8188EU: INFO indicate disassoc
[2037559.107967] R8188EU: INFO assoc success
[2037559.816066] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037559.823312] R8188EU: INFO indicate disassoc
[2037561.288706] R8188EU: INFO assoc success
[2037562.202068] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037562.209318] R8188EU: INFO indicate disassoc
[2037564.134696] R8188EU: INFO assoc success
[2037564.734940] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037564.742574] R8188EU: INFO indicate disassoc
[2037566.021952] R8188EU: INFO assoc success
[2037566.655322] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037566.662567] R8188EU: INFO indicate disassoc
[2037567.963454] R8188EU: INFO assoc success
[2037568.614564] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037568.621823] R8188EU: INFO indicate disassoc
[2037569.887451] R8188EU: INFO assoc success
[2037570.505059] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037570.512320] R8188EU: INFO indicate disassoc
[2037572.419074] R8188EU: INFO assoc success
[2037573.150441] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037573.157813] R8188EU: INFO indicate disassoc
[2037574.501078] R8188EU: INFO assoc success
[2037575.078696] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037575.085950] R8188EU: INFO indicate disassoc
[2037576.341450] R8188EU: INFO assoc success
[2037576.829192] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037576.836446] R8188EU: INFO indicate disassoc
[2037578.192581] R8188EU: INFO assoc success
[2037579.057318] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037579.064571] R8188EU: INFO indicate disassoc
[2037580.352457] R8188EU: INFO assoc success
[2037580.861936] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037580.869187] R8188EU: INFO indicate disassoc
[2037585.340579] R8188EU: INFO assoc success
[2037588.294445] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037588.301691] R8188EU: INFO indicate disassoc
[2037589.671702] R8188EU: INFO assoc success
[2037592.154193] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037592.161573] R8188EU: INFO indicate disassoc
[2037595.170708] R8188EU: INFO assoc success
[2037599.313070] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037599.320324] R8188EU: INFO indicate disassoc
[2037600.917085] R8188EU: INFO assoc success
[2037602.118949] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037602.126201] R8188EU: INFO indicate disassoc
[2037603.483086] R8188EU: INFO assoc success
[2037604.889067] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037604.896319] R8188EU: INFO indicate disassoc
[2037606.257453] R8188EU: INFO assoc success
[2037607.880322] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037607.887578] R8188EU: INFO indicate disassoc
[2037609.230458] R8188EU: INFO assoc success
[2037610.300831] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037610.308076] R8188EU: INFO indicate disassoc
[2037611.631457] R8188EU: INFO assoc success
[2037612.325573] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037612.332827] R8188EU: INFO indicate disassoc
[2037613.635706] R8188EU: INFO assoc success
[2037614.746472] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037614.753835] R8188EU: INFO indicate disassoc
[2037616.561458] R8188EU: INFO assoc success
[2037617.295945] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037617.303192] R8188EU: INFO indicate disassoc
[2037618.631839] R8188EU: INFO assoc success
[2037619.391825] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037619.399078] R8188EU: INFO indicate disassoc
[2037622.935585] R8188EU: INFO assoc success
[2037625.192328] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037625.199582] R8188EU: INFO indicate disassoc
[2037626.617717] R8188EU: INFO assoc success
[2037627.346202] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037627.353449] R8188EU: INFO indicate disassoc
[2037632.633096] R8188EU: INFO assoc success
[2037634.023956] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037634.031597] R8188EU: INFO indicate disassoc
[2037635.320462] R8188EU: INFO assoc success
[2037637.154828] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037637.162085] R8188EU: INFO indicate disassoc
[2037638.491715] R8188EU: INFO assoc success
[2037640.046205] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037640.053459] R8188EU: INFO indicate disassoc
[2037641.633470] R8188EU: INFO assoc success
[2037643.708327] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037643.715582] R8188EU: INFO indicate disassoc
[2037645.057464] R8188EU: INFO assoc success
[2037646.447591] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037646.454843] R8188EU: INFO indicate disassoc
[2037653.684032] R8188EU: INFO indicate disassoc
[2037660.306717] R8188EU: INFO assoc success
[2037667.461461] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037667.468714] R8188EU: INFO indicate disassoc
[2037668.848851] R8188EU: INFO assoc success
[2037672.852214] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037672.859466] R8188EU: INFO indicate disassoc
[2037674.145595] R8188EU: INFO assoc success
[2037677.162838] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037677.170091] R8188EU: INFO indicate disassoc
[2037678.430095] R8188EU: INFO assoc success
[2037686.090851] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037686.098093] R8188EU: INFO indicate disassoc
[2037687.549234] R8188EU: INFO assoc success
[2037700.020963] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037700.028218] R8188EU: INFO indicate disassoc
[2037702.920480] R8188EU: INFO assoc success
[2037710.148594] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037710.155848] R8188EU: INFO indicate disassoc
[2037711.501854] R8188EU: INFO assoc success
[2037726.638225] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037726.645478] R8188EU: INFO indicate disassoc
[2037732.777367] R8188EU: INFO assoc success
[2037735.874602] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037735.881859] R8188EU: INFO indicate disassoc
[2037737.209492] R8188EU: INFO assoc success
[2037747.828729] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037747.843359] R8188EU: INFO indicate disassoc
[2037749.589613] R8188EU: INFO assoc success
[2037770.007236] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037770.014490] R8188EU: INFO indicate disassoc
[2037771.339995] R8188EU: INFO assoc success
[2037784.805745] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037784.812985] R8188EU: INFO indicate disassoc
[2037786.337257] R8188EU: INFO assoc success
[2037790.396490] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037790.403748] R8188EU: INFO indicate disassoc
[2037791.697254] R8188EU: INFO assoc success
[2037794.138614] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037794.145866] R8188EU: INFO indicate disassoc
[2037795.491625] R8188EU: INFO assoc success
[2037806.263371] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037806.270620] R8188EU: INFO indicate disassoc
[2037807.571125] R8188EU: INFO assoc success
[2037875.827257] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037875.834511] R8188EU: INFO indicate disassoc
[2037877.184266] R8188EU: INFO assoc success
[2037893.272514] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037893.279894] R8188EU: INFO indicate disassoc
[2037895.093400] R8188EU: INFO assoc success
[2037898.585390] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037898.593398] R8188EU: INFO indicate disassoc
[2037900.022901] R8188EU: INFO assoc success
[2037913.111271] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037913.118521] R8188EU: INFO indicate disassoc
[2037914.465527] R8188EU: INFO assoc success
[2037965.118907] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037965.126155] R8188EU: INFO indicate disassoc
[2037966.381916] R8188EU: INFO assoc success
[2037969.816779] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2037969.824041] R8188EU: INFO indicate disassoc
[2037971.208162] R8188EU: INFO assoc success
[2037992.844669] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2037992.851912] R8188EU: INFO indicate disassoc
[2037994.254419] R8188EU: INFO assoc success
[2038014.451664] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038014.458917] R8188EU: INFO indicate disassoc
[2038015.849298] R8188EU: INFO assoc success
[2038036.302673] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038036.309922] R8188EU: INFO indicate disassoc
[2038037.694677] R8188EU: INFO assoc success
[2038055.742295] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038055.749676] R8188EU: INFO indicate disassoc
[2038057.727438] R8188EU: INFO assoc success
[2038059.903943] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038059.911191] R8188EU: INFO indicate disassoc
[2038061.812939] R8188EU: INFO assoc success
[2038084.610178] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038084.617432] R8188EU: INFO indicate disassoc
[2038085.887321] R8188EU: INFO assoc success
[2038095.260557] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038095.267809] R8188EU: INFO indicate disassoc
[2038096.542185] R8188EU: INFO assoc success
[2038100.374060] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038100.381315] R8188EU: INFO indicate disassoc
[2038101.874072] R8188EU: INFO assoc success
[2038115.748435] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038115.755689] R8188EU: INFO indicate disassoc
[2038119.351700] R8188EU: INFO assoc success
[2038209.748458] R8188EU: INFO sta recv deauth reason code(7) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2038209.760712] R8188EU: INFO indicate disassoc
[2038211.112468] R8188EU: INFO assoc success
[2038231.669715] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038231.676971] R8188EU: INFO indicate disassoc
[2038233.018095] R8188EU: INFO assoc success
[2038313.378854] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038313.386104] R8188EU: INFO indicate disassoc
[2038314.646363] R8188EU: INFO assoc success
[2038316.769107] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038316.776365] R8188EU: INFO indicate disassoc
[2038318.706115] R8188EU: INFO assoc success
[2038319.577236] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038319.584484] R8188EU: INFO indicate disassoc
[2038320.885368] R8188EU: INFO assoc success
[2038325.595859] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038325.603111] R8188EU: INFO indicate disassoc
[2038327.031871] R8188EU: INFO assoc success
[2038333.775121] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038333.782368] R8188EU: INFO indicate disassoc
[2038335.244748] R8188EU: INFO assoc success
[2038337.228614] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038337.235870] R8188EU: INFO indicate disassoc
[2038338.515872] R8188EU: INFO assoc success
[2038341.324360] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038341.331616] R8188EU: INFO indicate disassoc
[2038343.002625] R8188EU: INFO assoc success
[2038358.403370] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038358.410618] R8188EU: INFO indicate disassoc
[2038359.713629] R8188EU: INFO assoc success
[2038364.458615] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038364.465870] R8188EU: INFO indicate disassoc
[2038365.739129] R8188EU: INFO assoc success
[2038374.598872] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038374.606121] R8188EU: INFO indicate disassoc
[2038376.064625] R8188EU: INFO assoc success
[2038393.322246] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038393.329502] R8188EU: INFO indicate disassoc
[2038394.615377] R8188EU: INFO assoc success
[2038401.888748] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038401.896003] R8188EU: INFO indicate disassoc
[2038403.213514] R8188EU: INFO assoc success
[2038415.776750] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038415.784005] R8188EU: INFO indicate disassoc
[2038419.284887] R8188EU: INFO assoc success
[2038425.926004] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038425.933264] R8188EU: INFO indicate disassoc
[2038427.386767] R8188EU: INFO assoc success
[2038436.161383] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038436.168635] R8188EU: INFO indicate disassoc
[2038443.392049] R8188EU: INFO indicate disassoc
[2038450.894017] R8188EU: INFO assoc success
[2038450.907005] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038450.914260] R8188EU: INFO indicate disassoc
[2038454.195395] R8188EU: INFO assoc success
[2038456.608765] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038456.616022] R8188EU: INFO indicate disassoc
[2038458.300903] R8188EU: INFO assoc success
[2038458.311515] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038458.319637] R8188EU: INFO indicate disassoc
[2038461.563396] R8188EU: INFO assoc success
[2038461.573886] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:39:c4:e6
[2038461.582269] R8188EU: INFO indicate disassoc
[2038463.202028] R8188EU: INFO assoc success
[2038463.216513] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038463.223774] R8188EU: INFO indicate disassoc
[2038471.597646] R8188EU: INFO assoc success
[2038471.609138] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038471.616521] R8188EU: INFO indicate disassoc
[2038473.648899] R8188EU: INFO assoc success
[2038473.662518] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038473.669767] R8188EU: INFO indicate disassoc
[2038475.001773] R8188EU: INFO assoc success
[2038475.014018] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038475.021266] R8188EU: INFO indicate disassoc
[2038477.212027] R8188EU: INFO assoc success
[2038477.227014] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038477.234268] R8188EU: INFO indicate disassoc
[2038479.769788] R8188EU: INFO assoc success
[2038479.774391] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038479.787895] R8188EU: INFO indicate disassoc
[2038481.935526] R8188EU: INFO assoc success
[2038481.946768] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038481.954394] R8188EU: INFO indicate disassoc
[2038483.889903] R8188EU: INFO assoc success
[2038483.900272] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2038483.908894] R8188EU: INFO indicate disassoc
[2038491.688900] R8188EU: INFO assoc success
[2038499.912767] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038499.920532] R8188EU: INFO indicate disassoc
[2038501.222029] R8188EU: INFO assoc success
[2038502.232270] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038502.239526] R8188EU: INFO indicate disassoc
[2038503.573911] R8188EU: INFO assoc success
[2038506.395529] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038506.402776] R8188EU: INFO indicate disassoc
[2038507.659535] R8188EU: INFO assoc success
[2038508.785272] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038508.792526] R8188EU: INFO indicate disassoc
[2038510.236412] R8188EU: INFO assoc success
[2038516.550148] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038516.557528] R8188EU: INFO indicate disassoc
[2038518.322538] R8188EU: INFO assoc success
[2038534.150650] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038534.157907] R8188EU: INFO indicate disassoc
[2038536.003415] R8188EU: INFO assoc success
[2038562.148168] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2038562.158689] R8188EU: INFO indicate disassoc
[2038563.683418] R8188EU: INFO assoc success
[2038566.493666] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038566.500920] R8188EU: INFO indicate disassoc
[2038567.800681] R8188EU: INFO assoc success
[2038583.332545] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038583.339924] R8188EU: INFO indicate disassoc
[2038590.564023] R8188EU: INFO indicate disassoc
[2038597.270054] R8188EU: INFO assoc success
[2038613.650796] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038613.658051] R8188EU: INFO indicate disassoc
[2038615.010303] R8188EU: INFO assoc success
[2038624.780794] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038624.791427] R8188EU: INFO indicate disassoc
[2038626.152808] R8188EU: INFO assoc success
[2038639.521802] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038639.529055] R8188EU: INFO indicate disassoc
[2038640.987184] R8188EU: INFO assoc success
[2038644.490307] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038644.497556] R8188EU: INFO indicate disassoc
[2038646.200691] R8188EU: INFO assoc success
[2038655.601430] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038655.611440] R8188EU: INFO indicate disassoc
[2038657.975447] R8188EU: INFO assoc success
[2038791.301591] R8188EU: INFO sta recv deauth reason code(2) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2038791.308840] R8188EU: INFO indicate disassoc
[2038792.641970] R8188EU: INFO assoc success
[2038813.385215] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2038813.392469] R8188EU: INFO indicate disassoc
[2038821.304474] R8188EU: INFO assoc success
[2039176.300920] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039176.311430] R8188EU: INFO indicate disassoc
[2039182.652557] R8188EU: INFO assoc success
[2039199.013805] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039199.021055] R8188EU: INFO indicate disassoc
[2039200.288314] R8188EU: INFO assoc success
[2039234.459936] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039234.467188] R8188EU: INFO indicate disassoc
[2039235.991319] R8188EU: INFO assoc success
[2039239.304942] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039239.312190] R8188EU: INFO indicate disassoc
[2039240.644070] R8188EU: INFO assoc success
[2039241.133941] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039241.141189] R8188EU: INFO indicate disassoc
[2039242.475191] R8188EU: INFO assoc success
[2039244.690439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039244.697694] R8188EU: INFO indicate disassoc
[2039245.959943] R8188EU: INFO assoc success
[2039246.713815] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039246.721069] R8188EU: INFO indicate disassoc
[2039248.368948] R8188EU: INFO assoc success
[2039249.545189] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039249.552442] R8188EU: INFO indicate disassoc
[2039250.889077] R8188EU: INFO assoc success
[2039252.929571] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039252.936824] R8188EU: INFO indicate disassoc
[2039254.344829] R8188EU: INFO assoc success
[2039254.838065] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039254.845310] R8188EU: INFO indicate disassoc
[2039256.206823] R8188EU: INFO assoc success
[2039258.408324] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039258.415572] R8188EU: INFO indicate disassoc
[2039259.670697] R8188EU: INFO assoc success
[2039260.454820] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039260.462068] R8188EU: INFO indicate disassoc
[2039261.727324] R8188EU: INFO assoc success
[2039264.897439] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039264.904693] R8188EU: INFO indicate disassoc
[2039268.088052] R8188EU: INFO indicate disassoc
[2039270.852041] R8188EU: INFO indicate disassoc
[2039272.175072] R8188EU: INFO assoc success
[2039272.184694] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2039272.193694] R8188EU: INFO indicate disassoc
[2039274.998828] R8188EU: INFO assoc success
[2039275.011565] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2039275.018820] R8188EU: INFO indicate disassoc
[2039282.821455] R8188EU: INFO assoc success
[2039289.014080] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039289.021327] R8188EU: INFO indicate disassoc
[2039290.305335] R8188EU: INFO assoc success
[2039291.231703] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039291.238950] R8188EU: INFO indicate disassoc
[2039292.548713] R8188EU: INFO assoc success
[2039293.040577] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039293.047827] R8188EU: INFO indicate disassoc
[2039294.391458] R8188EU: INFO assoc success
[2039295.050572] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039295.057826] R8188EU: INFO indicate disassoc
[2039297.362707] R8188EU: INFO assoc success
[2039297.949075] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039297.956330] R8188EU: INFO indicate disassoc
[2039299.297957] R8188EU: INFO assoc success
[2039300.057826] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039300.065078] R8188EU: INFO indicate disassoc
[2039301.365335] R8188EU: INFO assoc success
[2039303.190826] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039303.198078] R8188EU: INFO indicate disassoc
[2039304.550584] R8188EU: INFO assoc success
[2039305.137199] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039305.144454] R8188EU: INFO indicate disassoc
[2039306.467959] R8188EU: INFO assoc success
[2039307.389199] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039307.396454] R8188EU: INFO indicate disassoc
[2039308.738332] R8188EU: INFO assoc success
[2039310.334577] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039310.341838] R8188EU: INFO indicate disassoc
[2039311.684459] R8188EU: INFO assoc success
[2039313.379453] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039313.386712] R8188EU: INFO indicate disassoc
[2039314.677840] R8188EU: INFO assoc success
[2039315.720703] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039315.727953] R8188EU: INFO indicate disassoc
[2039317.036219] R8188EU: INFO assoc success
[2039318.601839] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039318.609081] R8188EU: INFO indicate disassoc
[2039319.902460] R8188EU: INFO assoc success
[2039321.614954] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039321.622215] R8188EU: INFO indicate disassoc
[2039322.989463] R8188EU: INFO assoc success
[2039323.805335] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039323.812584] R8188EU: INFO indicate disassoc
[2039325.169837] R8188EU: INFO assoc success
[2039326.475097] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039326.482333] R8188EU: INFO indicate disassoc
[2039328.697344] R8188EU: INFO assoc success
[2039331.716337] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039331.723587] R8188EU: INFO indicate disassoc
[2039333.415221] R8188EU: INFO assoc success
[2039335.817458] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039335.824710] R8188EU: INFO indicate disassoc
[2039338.989226] R8188EU: INFO assoc success
[2039341.074090] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039341.081590] R8188EU: INFO indicate disassoc
[2039342.420216] R8188EU: INFO assoc success
[2039345.187840] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039345.195095] R8188EU: INFO indicate disassoc
[2039348.669595] R8188EU: INFO assoc success
[2039350.150710] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039350.157964] R8188EU: INFO indicate disassoc
[2039351.839593] R8188EU: INFO assoc success
[2039355.219083] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039355.227715] R8188EU: INFO indicate disassoc
[2039356.564848] R8188EU: INFO assoc success
[2039358.249973] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039358.257218] R8188EU: INFO indicate disassoc
[2039359.513473] R8188EU: INFO assoc success
[2039359.992588] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039360.000216] R8188EU: INFO indicate disassoc
[2039361.343353] R8188EU: INFO assoc success
[2039362.645719] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039362.652966] R8188EU: INFO indicate disassoc
[2039363.917105] R8188EU: INFO assoc success
[2039365.199334] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039365.206587] R8188EU: INFO indicate disassoc
[2039369.754728] R8188EU: INFO assoc success
[2039370.612091] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039370.619336] R8188EU: INFO indicate disassoc
[2039374.300044] R8188EU: INFO indicate disassoc
[2039376.574103] R8188EU: INFO assoc success
[2039376.585090] R8188EU: INFO ap recv disassoc reason code(34) sta:e8:d3:eb:2f:64:c6
[2039376.592968] R8188EU: INFO indicate disassoc
[2039384.412354] R8188EU: INFO assoc success
[2039385.807713] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039385.816225] R8188EU: INFO indicate disassoc
[2039387.173358] R8188EU: INFO assoc success
[2039388.271981] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039388.279226] R8188EU: INFO indicate disassoc
[2039389.619729] R8188EU: INFO assoc success
[2039390.113845] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039390.121100] R8188EU: INFO indicate disassoc
[2039391.444480] R8188EU: INFO assoc success
[2039392.290217] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039392.297469] R8188EU: INFO indicate disassoc
[2039393.620605] R8188EU: INFO assoc success
[2039395.565219] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039395.572469] R8188EU: INFO indicate disassoc
[2039396.899230] R8188EU: INFO assoc success
[2039397.653091] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039397.660344] R8188EU: INFO indicate disassoc
[2039402.297617] R8188EU: INFO assoc success
[2039406.076102] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039406.083355] R8188EU: INFO indicate disassoc
[2039407.340108] R8188EU: INFO assoc success
[2039408.047347] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039408.054612] R8188EU: INFO indicate disassoc
[2039409.412863] R8188EU: INFO assoc success
[2039411.073724] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039411.080973] R8188EU: INFO indicate disassoc
[2039412.388982] R8188EU: INFO assoc success
[2039413.148845] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039413.156096] R8188EU: INFO indicate disassoc
[2039414.500485] R8188EU: INFO assoc success
[2039416.331096] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039416.339605] R8188EU: INFO indicate disassoc
[2039418.292859] R8188EU: INFO assoc success
[2039421.426598] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039421.433849] R8188EU: INFO indicate disassoc
[2039422.696359] R8188EU: INFO assoc success
[2039423.718597] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039423.725852] R8188EU: INFO indicate disassoc
[2039425.061743] R8188EU: INFO assoc success
[2039426.664858] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039426.672108] R8188EU: INFO indicate disassoc
[2039430.982366] R8188EU: INFO assoc success
[2039431.608727] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039431.615982] R8188EU: INFO indicate disassoc
[2039432.933617] R8188EU: INFO assoc success
[2039433.943730] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039433.950983] R8188EU: INFO indicate disassoc
[2039435.290988] R8188EU: INFO assoc success
[2039436.355731] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039436.362975] R8188EU: INFO indicate disassoc
[2039437.648366] R8188EU: INFO assoc success
[2039438.684366] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039438.691609] R8188EU: INFO indicate disassoc
[2039440.009371] R8188EU: INFO assoc success
[2039440.776733] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039440.783984] R8188EU: INFO indicate disassoc
[2039443.508246] R8188EU: INFO assoc success
[2039444.234365] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039444.241616] R8188EU: INFO indicate disassoc
[2039445.549118] R8188EU: INFO assoc success
[2039446.083727] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039446.090983] R8188EU: INFO indicate disassoc
[2039447.367865] R8188EU: INFO assoc success
[2039448.470482] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039448.477731] R8188EU: INFO indicate disassoc
[2039449.753627] R8188EU: INFO assoc success
[2039450.384237] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039450.391482] R8188EU: INFO indicate disassoc
[2039451.678496] R8188EU: INFO assoc success
[2039452.150483] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039452.157737] R8188EU: INFO indicate disassoc
[2039453.414741] R8188EU: INFO assoc success
[2039454.074484] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039454.081738] R8188EU: INFO indicate disassoc
[2039455.371866] R8188EU: INFO assoc success
[2039455.956233] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039455.963482] R8188EU: INFO indicate disassoc
[2039459.334374] R8188EU: INFO assoc success
[2039460.304485] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039460.311862] R8188EU: INFO indicate disassoc
[2039461.608998] R8188EU: INFO assoc success
[2039462.173362] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039462.180614] R8188EU: INFO indicate disassoc
[2039469.412052] R8188EU: INFO indicate disassoc
[2039476.149124] R8188EU: INFO assoc success
[2039478.305116] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039478.312616] R8188EU: INFO indicate disassoc
[2039479.627248] R8188EU: INFO assoc success
[2039481.798862] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039481.806114] R8188EU: INFO indicate disassoc
[2039483.112372] R8188EU: INFO assoc success
[2039483.913992] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039483.925367] R8188EU: INFO indicate disassoc
[2039485.273124] R8188EU: INFO assoc success
[2039486.022611] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039486.029862] R8188EU: INFO indicate disassoc
[2039487.306497] R8188EU: INFO assoc success
[2039487.919736] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039487.926994] R8188EU: INFO indicate disassoc
[2039489.254006] R8188EU: INFO assoc success
[2039490.128743] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039490.135998] R8188EU: INFO indicate disassoc
[2039495.908129] R8188EU: INFO assoc success
[2039505.257596] R8188EU: INFO indicate disassoc
[2039506.381122] R8188EU: INFO indicate disassoc
[2039509.211757] R8188EU: INFO assoc success
[2039509.252744] R8188EU: INFO indicate disassoc
[2039515.268017] R8188EU: INFO indicate disassoc
[2039516.610756] R8188EU: INFO assoc success
[2039525.103638] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039525.110884] R8188EU: INFO indicate disassoc
[2039526.425632] R8188EU: INFO assoc success
[2039527.374628] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039527.381878] R8188EU: INFO indicate disassoc
[2039528.695640] R8188EU: INFO assoc success
[2039533.684876] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039533.692134] R8188EU: INFO indicate disassoc
[2039535.029134] R8188EU: INFO assoc success
[2039537.546129] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039537.553382] R8188EU: INFO indicate disassoc
[2039538.821760] R8188EU: INFO assoc success
[2039544.114252] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039544.121512] R8188EU: INFO indicate disassoc
[2039545.377391] R8188EU: INFO assoc success
[2039550.738255] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039550.745513] R8188EU: INFO indicate disassoc
[2039552.031265] R8188EU: INFO assoc success
[2039557.811389] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039557.818635] R8188EU: INFO indicate disassoc
[2039559.087890] R8188EU: INFO assoc success
[2039569.813385] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039569.820641] R8188EU: INFO indicate disassoc
[2039571.093891] R8188EU: INFO assoc success
[2039572.354511] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039572.361764] R8188EU: INFO indicate disassoc
[2039579.588021] R8188EU: INFO indicate disassoc
[2039586.242144] R8188EU: INFO assoc success
[2039587.281014] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039587.288262] R8188EU: INFO indicate disassoc
[2039588.909152] R8188EU: INFO assoc success
[2039601.026392] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039601.033650] R8188EU: INFO indicate disassoc
[2039602.824273] R8188EU: INFO assoc success
[2039617.649897] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039617.657149] R8188EU: INFO indicate disassoc
[2039619.006532] R8188EU: INFO assoc success
[2039626.451521] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039626.458782] R8188EU: INFO indicate disassoc
[2039627.792399] R8188EU: INFO assoc success
[2039641.812902] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039641.820155] R8188EU: INFO indicate disassoc
[2039643.170287] R8188EU: INFO assoc success
[2039667.181533] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039667.188785] R8188EU: INFO indicate disassoc
[2039668.451668] R8188EU: INFO assoc success
[2039672.469284] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039672.476544] R8188EU: INFO indicate disassoc
[2039673.788041] R8188EU: INFO assoc success
[2039675.526034] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039675.533287] R8188EU: INFO indicate disassoc
[2039676.958298] R8188EU: INFO assoc success
[2039693.337913] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2039693.345166] R8188EU: INFO indicate disassoc
[2039694.668045] R8188EU: INFO assoc success
[2039709.180040] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039709.187296] R8188EU: INFO indicate disassoc
[2039710.646801] R8188EU: INFO assoc success
[2039811.290440] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039811.298939] R8188EU: INFO indicate disassoc
[2039813.050097] R8188EU: INFO assoc success
[2039813.600317] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039813.607561] R8188EU: INFO indicate disassoc
[2039815.187067] R8188EU: INFO assoc success
[2039830.422317] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039830.429826] R8188EU: INFO indicate disassoc
[2039832.677845] R8188EU: INFO assoc success
[2039851.821452] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039851.829951] R8188EU: INFO indicate disassoc
[2039853.082841] R8188EU: INFO assoc success
[2039853.608582] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039853.615830] R8188EU: INFO indicate disassoc
[2039854.932241] R8188EU: INFO assoc success
[2039873.280979] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039873.288329] R8188EU: INFO indicate disassoc
[2039874.596730] R8188EU: INFO assoc success
[2039890.120463] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039890.128969] R8188EU: INFO indicate disassoc
[2039892.408103] R8188EU: INFO assoc success
[2039908.347082] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039908.354337] R8188EU: INFO indicate disassoc
[2039909.705476] R8188EU: INFO assoc success
[2039931.070970] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039931.078219] R8188EU: INFO indicate disassoc
[2039932.541994] R8188EU: INFO assoc success
[2039952.382989] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039952.390225] R8188EU: INFO indicate disassoc
[2039953.749985] R8188EU: INFO assoc success
[2039970.605595] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2039970.619478] R8188EU: INFO indicate disassoc
[2039972.076365] R8188EU: INFO assoc success
[2040056.214131] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2040056.222754] R8188EU: INFO indicate disassoc
[2040057.573753] R8188EU: INFO assoc success
[2040078.428629] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2040078.435880] R8188EU: INFO indicate disassoc
[2040079.996524] R8188EU: INFO assoc success
[2040099.632513] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2040099.639757] R8188EU: INFO indicate disassoc
[2040101.075886] R8188EU: INFO assoc success
[2040218.346797] R8188EU: INFO sta recv deauth reason code(7) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2040218.347772] R8188EU: INFO sta recv deauth reason code(7) sta:e8:d3:eb:39:c4:e6, ignore = 0
[2040218.354031] R8188EU: INFO indicate disassoc
[2040227.154938] R8188EU: INFO assoc success
[2041218.593384] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041218.600630] R8188EU: INFO indicate disassoc
[2041220.027882] R8188EU: INFO assoc success
[2041234.619629] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041234.626890] R8188EU: INFO indicate disassoc
[2041236.082388] R8188EU: INFO assoc success
[2041256.436884] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041256.444142] R8188EU: INFO indicate disassoc
[2041257.798394] R8188EU: INFO assoc success
[2041278.442886] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041278.450143] R8188EU: INFO indicate disassoc
[2041279.704020] R8188EU: INFO assoc success
[2041300.373777] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041300.381018] R8188EU: INFO indicate disassoc
[2041301.820282] R8188EU: INFO assoc success
[2041322.284778] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041322.292030] R8188EU: INFO indicate disassoc
[2041323.640908] R8188EU: INFO assoc success
[2041343.885654] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2041343.892905] R8188EU: INFO indicate disassoc
[2041345.249287] R8188EU: INFO assoc success
[2041364.966284] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2041364.973539] R8188EU: INFO indicate disassoc
[2041366.247793] R8188EU: INFO assoc success
[2041386.790421] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041386.797674] R8188EU: INFO indicate disassoc
[2041388.347930] R8188EU: INFO assoc success
[2041407.986796] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041407.994041] R8188EU: INFO indicate disassoc
[2041409.367926] R8188EU: INFO assoc success
[2041429.587301] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:39:c4:e6
[2041429.594679] R8188EU: INFO indicate disassoc
[2041430.954431] R8188EU: INFO assoc success
[2041450.588054] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041450.595313] R8188EU: INFO indicate disassoc
[2041451.966189] R8188EU: INFO assoc success
[2041472.292811] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2041472.300064] R8188EU: INFO indicate disassoc
[2041473.650065] R8188EU: INFO assoc success
[2043018.409152] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043018.416412] R8188EU: INFO indicate disassoc
[2043019.657666] R8188EU: INFO assoc success
[2043023.652036] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043023.659282] R8188EU: INFO indicate disassoc
[2043024.988913] R8188EU: INFO assoc success
[2043045.456034] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043045.463290] R8188EU: INFO indicate disassoc
[2043047.124292] R8188EU: INFO assoc success
[2043067.779798] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043067.787048] R8188EU: INFO indicate disassoc
[2043069.334922] R8188EU: INFO assoc success
[2043088.664548] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043088.671797] R8188EU: INFO indicate disassoc
[2043091.792021] R8188EU: INFO indicate disassoc
[2043094.560037] R8188EU: INFO indicate disassoc
[2043097.324039] R8188EU: INFO indicate disassoc
[2043100.088045] R8188EU: INFO indicate disassoc
[2043109.408032] R8188EU: INFO indicate disassoc
[2043112.172005] R8188EU: INFO indicate disassoc
[2043115.140041] R8188EU: INFO indicate disassoc
[2043117.904033] R8188EU: INFO indicate disassoc
[2043120.668033] R8188EU: INFO indicate disassoc
[2043128.538561] R8188EU: INFO assoc success
[2043134.974069] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043134.981308] R8188EU: INFO indicate disassoc
[2043136.320940] R8188EU: INFO assoc success
[2043137.405678] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043137.412939] R8188EU: INFO indicate disassoc
[2043138.772191] R8188EU: INFO assoc success
[2043142.407935] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043142.415184] R8188EU: INFO indicate disassoc
[2043143.689814] R8188EU: INFO assoc success
[2043170.780063] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043170.787315] R8188EU: INFO indicate disassoc
[2043172.190569] R8188EU: INFO assoc success
[2043186.025445] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043186.033071] R8188EU: INFO indicate disassoc
[2043187.317075] R8188EU: INFO assoc success
[2043192.389815] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043192.397071] R8188EU: INFO indicate disassoc
[2043194.064205] R8188EU: INFO assoc success
[2043208.155693] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043208.162953] R8188EU: INFO indicate disassoc
[2043209.633577] R8188EU: INFO assoc success
[2043226.999946] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043227.007207] R8188EU: INFO indicate disassoc
[2043228.479334] R8188EU: INFO assoc success
[2043242.257205] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043242.264456] R8188EU: INFO indicate disassoc
[2043243.731470] R8188EU: INFO assoc success
[2043248.702956] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043248.710207] R8188EU: INFO indicate disassoc
[2043249.977097] R8188EU: INFO assoc success
[2043268.161337] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043268.168587] R8188EU: INFO indicate disassoc
[2043269.415716] R8188EU: INFO assoc success
[2043283.399336] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043283.406596] R8188EU: INFO indicate disassoc
[2043284.773721] R8188EU: INFO assoc success
[2043297.968594] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043297.975846] R8188EU: INFO indicate disassoc
[2043299.330101] R8188EU: INFO assoc success
[2043314.855594] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043314.862847] R8188EU: INFO indicate disassoc
[2043316.339978] R8188EU: INFO assoc success
[2043336.671350] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043336.678605] R8188EU: INFO indicate disassoc
[2043338.047113] R8188EU: INFO assoc success
[2043358.379112] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043358.386483] R8188EU: INFO indicate disassoc
[2043359.728986] R8188EU: INFO assoc success
[2043380.406616] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043380.413862] R8188EU: INFO indicate disassoc
[2043381.772366] R8188EU: INFO assoc success
[2043402.430616] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043402.437860] R8188EU: INFO indicate disassoc
[2043403.766247] R8188EU: INFO assoc success
[2043424.022250] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043424.030121] R8188EU: INFO indicate disassoc
[2043425.492503] R8188EU: INFO assoc success
[2043449.712376] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043449.719759] R8188EU: INFO indicate disassoc
[2043451.282502] R8188EU: INFO assoc success
[2043471.015623] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2043471.031389] R8188EU: INFO indicate disassoc
[2043472.579758] R8188EU: INFO assoc success
[2044818.416307] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2044818.423556] R8188EU: INFO indicate disassoc
[2044820.151943] R8188EU: INFO assoc success
[2044823.748430] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2044823.755682] R8188EU: INFO indicate disassoc
[2044825.083193] R8188EU: INFO assoc success
[2044845.524685] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2044845.531938] R8188EU: INFO indicate disassoc
[2044846.886572] R8188EU: INFO assoc success
[2045280.098155] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2045280.105410] R8188EU: INFO indicate disassoc
[2045281.368669] R8188EU: INFO assoc success
[2045282.730030] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2045282.737283] R8188EU: INFO indicate disassoc
[2045284.040788] R8188EU: INFO assoc success
[2045284.938782] R8188EU: INFO ap recv disassoc reason code(1) sta:e8:d3:eb:2f:64:c6
[2045284.946043] R8188EU: INFO indicate disassoc
[2045286.331545] R8188EU: INFO assoc success
[2045346.206442] usb 8-6: USB disconnect, device number 9
[2045346.206703] R8188EU: INFO indicate disassoc
[2045372.136021] usb 8-4: new high-speed USB device number 10 using ehci_hcd
[2045372.268798] usb 8-4: New USB device found, idVendor=083a, idProduct=4505
[2045372.268802] usb 8-4: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2045372.268806] usb 8-4: Product: USB2.0 WLAN
[2045372.268809] usb 8-4: Manufacturer: SMC
[2045372.319910] cfg80211: Calling CRDA to update world regulatory domain
[2045372.390205] cfg80211: World regulatory domain updated:
[2045372.390208] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045372.390211] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045372.390213] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045372.390215] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045372.390217] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045372.390219] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045372.390221] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045372.390223] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045372.390225] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045372.460065] usb 8-4: reset high-speed USB device number 10 using ehci_hcd
[2045372.600981] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[2045372.601154] zd1211rw 8-4:1.0: phy0
[2045372.601341] usbcore: registered new interface driver zd1211rw
[2045372.660275] udevd[30670]: renamed network interface wlan0 to wlan1
[2045372.730553] zd1211rw 8-4:1.0: firmware version 4725
[2045372.770553] zd1211rw 8-4:1.0: zd1211b chip 083a:4505 v4810 high 00-13-f7 AL2230_RF pa0 g--NS
[2045372.772941] cfg80211: Calling CRDA for country: US
[2045372.776711] cfg80211: Regulatory domain changed to country: US
[2045372.776714] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045372.776716] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045372.776718] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045372.776721] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045372.776723] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045372.776725] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045372.776727] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045372.802071] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[2045390.152698] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045390.170944] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045390.372025] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2045390.378809] wlan1: authenticated
[2045390.388020] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045390.401694] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045390.402325] wlan1: associated
[2045390.402458] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[2045390.402510] cfg80211: Calling CRDA for country: US
[2045390.406159] cfg80211: Regulatory domain changed to country: US
[2045390.406162] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045390.406164] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045390.406166] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045390.406168] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045390.406171] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045390.406173] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045390.406176] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045395.525817] wlan1: deauthenticated from e8:d3:eb:2f:64:c6 (Reason: 15)
[2045395.535967] cfg80211: Calling CRDA to update world regulatory domain
[2045395.539772] cfg80211: World regulatory domain updated:
[2045395.539774] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045395.539777] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045395.539779] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045395.539781] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045395.539784] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045395.539786] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045395.539788] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045395.539790] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045395.539792] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045395.708437] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045395.717945] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045395.734559] wlan1: authenticated
[2045395.744054] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045395.775944] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045395.776576] wlan1: associated
[2045395.776729] cfg80211: Calling CRDA for country: US
[2045395.780368] cfg80211: Regulatory domain changed to country: US
[2045395.780371] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045395.780373] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045395.780376] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045395.780378] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045395.780380] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045395.780382] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045395.780384] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045400.924584] wlan1: deauthenticated from e8:d3:eb:39:c4:e6 (Reason: 15)
[2045400.934967] cfg80211: Calling CRDA to update world regulatory domain
[2045400.938755] cfg80211: World regulatory domain updated:
[2045400.938758] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045400.938760] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045400.938763] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045400.938765] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045400.938767] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045400.938769] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045400.938771] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045400.938773] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045400.938775] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045401.748579] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045401.766947] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045401.778200] wlan1: authenticated
[2045401.788040] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045401.815704] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045401.816323] wlan1: associated
[2045401.816451] cfg80211: Calling CRDA for country: US
[2045401.820164] cfg80211: Regulatory domain changed to country: US
[2045401.820167] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045401.820170] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045401.820172] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045401.820174] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045401.820176] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045401.820178] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045401.820186] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045406.940570] wlan1: deauthenticated from e8:d3:eb:2f:64:c6 (Reason: 15)
[2045406.950964] cfg80211: Calling CRDA to update world regulatory domain
[2045406.954887] cfg80211: World regulatory domain updated:
[2045406.954890] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045406.954892] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045406.954894] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045406.954897] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045406.954899] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045406.954901] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045406.954908] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045406.954910] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045406.954913] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045407.124401] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045407.133947] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045407.147066] wlan1: authenticated
[2045407.160028] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045407.176565] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045407.177196] wlan1: associated
[2045407.177345] cfg80211: Calling CRDA for country: US
[2045407.181113] cfg80211: Regulatory domain changed to country: US
[2045407.181115] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045407.181118] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045407.181125] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045407.181127] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045407.181130] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045407.181132] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045407.181134] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045412.294826] wlan1: deauthenticated from e8:d3:eb:39:c4:e6 (Reason: 15)
[2045412.304972] cfg80211: Calling CRDA to update world regulatory domain
[2045412.308647] cfg80211: World regulatory domain updated:
[2045412.308650] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045412.308652] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045412.308654] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045412.308656] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045412.308658] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045412.308661] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045412.308663] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045412.308665] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045412.308668] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045413.116392] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045413.134946] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045413.148069] wlan1: authenticated
[2045413.160042] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045413.178573] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045413.179365] wlan1: associated
[2045413.179476] cfg80211: Calling CRDA for country: US
[2045413.183059] cfg80211: Regulatory domain changed to country: US
[2045413.183062] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045413.183065] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045413.183067] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045413.183069] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045413.183071] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045413.183073] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045413.183075] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045415.002683] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2045415.018154] cfg80211: Calling CRDA to update world regulatory domain
[2045415.021804] cfg80211: World regulatory domain updated:
[2045415.021806] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045415.021809] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045415.021811] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045415.021813] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045415.021815] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045415.021817] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045415.021819] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045415.021821] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045415.021824] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045423.860348] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045423.878957] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045423.893446] wlan1: authenticated
[2045423.904055] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045423.919070] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045423.919878] wlan1: associated
[2045423.919982] cfg80211: Calling CRDA for country: US
[2045423.923603] cfg80211: Regulatory domain changed to country: US
[2045423.923606] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045423.923609] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045423.923611] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045423.923613] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045423.923615] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045423.923617] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045423.923620] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045456.789326] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045456.798959] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045456.817335] wlan1: authenticated
[2045456.828021] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045456.849953] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045456.850588] wlan1: associated
[2045908.175328] usb 8-4: USB disconnect, device number 10
[2045908.175627] wlan1: deauthenticating from e8:d3:eb:39:c4:e6 by local choice (reason=3)
[2045908.176056] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045908.176079] cfg80211: Calling CRDA to update world regulatory domain
[2045908.180116] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045908.184582] cfg80211: World regulatory domain updated:
[2045908.184585] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045908.184587] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045908.184589] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045908.184591] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045908.184594] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045908.184596] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045908.184598] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045908.184600] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045908.184603] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045926.164053] usb 8-4: new high-speed USB device number 11 using ehci_hcd
[2045926.296796] usb 8-4: New USB device found, idVendor=083a, idProduct=4505
[2045926.296805] usb 8-4: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2045926.296807] usb 8-4: Product: USB2.0 WLAN
[2045926.296809] usb 8-4: Manufacturer: SMC
[2045926.412023] usb 8-4: reset high-speed USB device number 11 using ehci_hcd
[2045926.544645] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[2045926.544816] zd1211rw 8-4:1.0: phy1
[2045926.560204] udevd[31029]: renamed network interface wlan0 to wlan1
[2045926.615678] zd1211rw 8-4:1.0: firmware version 4725
[2045926.655676] zd1211rw 8-4:1.0: zd1211b chip 083a:4505 v4810 high 00-13-f7 AL2230_RF pa0 g--NS
[2045926.658064] cfg80211: Calling CRDA for country: US
[2045926.661746] cfg80211: Regulatory domain changed to country: US
[2045926.661749] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045926.661751] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045926.661754] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045926.661756] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045926.661758] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045926.661760] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045926.661762] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045926.688269] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[2045928.152732] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045928.172056] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045928.283181] wlan1: authenticated
[2045928.296011] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045928.334813] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045928.335439] wlan1: associated
[2045928.335567] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[2045928.335618] cfg80211: Calling CRDA for country: US
[2045928.339472] cfg80211: Regulatory domain changed to country: US
[2045928.339475] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045928.339477] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045928.339479] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045928.339482] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045928.339484] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045928.339486] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045928.339488] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045949.257816] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2045949.267074] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2045949.347690] wlan1: authenticated
[2045949.360024] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2045949.369065] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=3)
[2045949.369699] wlan1: associated
[2045974.371714] usb 8-4: USB disconnect, device number 11
[2045974.372015] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2045974.380067] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045974.380096] cfg80211: Calling CRDA to update world regulatory domain
[2045974.384084] zd1211rw 8-4:1.0: error ioread32(CR_REG1): -19
[2045974.388588] cfg80211: World regulatory domain updated:
[2045974.388591] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045974.388593] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2045974.388596] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045974.388598] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2045974.388600] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045974.388602] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045974.388604] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2045974.388606] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2045974.388608] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2045980.108026] usb 8-4: new high-speed USB device number 12 using ehci_hcd
[2045980.240806] usb 8-4: New USB device found, idVendor=083a, idProduct=4505
[2045980.240809] usb 8-4: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2045980.240812] usb 8-4: Product: USB2.0 WLAN
[2045980.240814] usb 8-4: Manufacturer: SMC
[2045980.356035] usb 8-4: reset high-speed USB device number 12 using ehci_hcd
[2045980.488660] ieee80211 phy2: Selected rate control algorithm 'minstrel_ht'
[2045980.488858] zd1211rw 8-4:1.0: phy2
[2045980.504195] udevd[31234]: renamed network interface wlan0 to wlan1
[2045980.568683] zd1211rw 8-4:1.0: firmware version 4725
[2045980.608688] zd1211rw 8-4:1.0: zd1211b chip 083a:4505 v4810 high 00-13-f7 AL2230_RF pa0 g--NS
[2045980.611080] cfg80211: Calling CRDA for country: US
[2045980.614754] cfg80211: Regulatory domain changed to country: US
[2045980.614762] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045980.614764] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045980.614766] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045980.614769] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045980.614771] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045980.614773] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045980.614775] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2045980.644190] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[2045982.104728] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2045982.123077] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2045982.207070] wlan1: authenticated
[2045982.220010] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2045982.237328] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2045982.237952] wlan1: associated
[2045982.238087] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[2045982.238138] cfg80211: Calling CRDA for country: US
[2045982.242047] cfg80211: Regulatory domain changed to country: US
[2045982.242050] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2045982.242052] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2045982.242054] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045982.242056] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2045982.242058] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2045982.242061] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2045982.242063] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2046156.871602] udevd[3357]: starting version 175
[2046516.359316] RTAI[math]: unloaded.
[2046516.360451] SCHED releases registered named ALIEN PEDV$D
[2046516.364399] RTAI[malloc]: unloaded.
[2046516.464013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[2046516.465358] I-pipe: head domain RTAI unregistered.
[2046516.465390] RTAI[hal]: unmounted.
[2046522.239487] I-pipe: head domain RTAI registered.
[2046522.239491] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[2046522.239519] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[2046522.239522] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[2046522.239524] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[2046522.239527] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 18863000
[2046522.245156] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[2046522.245177] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[2046522.245181] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[2046522.245184] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[2046522.245186] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[2046522.250793] RTAI[math]: loaded.
[2046522.390899] config string '0x0378'
[2046561.294441] RTAI[math]: unloaded.
[2046561.295573] SCHED releases registered named ALIEN PEDV$D
[2046561.298290] RTAI[malloc]: unloaded.
[2046561.396012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[2046561.397370] I-pipe: head domain RTAI unregistered.
[2046561.397398] RTAI[hal]: unmounted.
[2046568.867886] I-pipe: head domain RTAI registered.
[2046568.867890] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[2046568.867913] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[2046568.867916] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[2046568.867918] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[2046568.867921] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 19077750
[2046568.873591] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[2046568.873612] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[2046568.873615] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[2046568.873618] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[2046568.873620] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[2046568.882958] RTAI[math]: loaded.
[2046569.027661] config string '0x0378'
[2111202.044479] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2111202.053602] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2111202.067229] wlan1: authenticated
[2111202.076018] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2111202.094998] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2111202.095592] wlan1: associated
[2111562.029170] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2111562.037684] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2111562.156427] wlan1: authenticated
[2111562.168027] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2111562.197807] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2111562.198549] wlan1: associated
[2114682.044502] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2114682.052360] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2114682.150622] wlan1: authenticated
[2114682.164060] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2114682.182496] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2114682.183130] wlan1: associated
[2114802.032519] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2114802.040283] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2114802.244014] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2114802.327659] wlan1: authenticated
[2114802.340043] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2114802.350025] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2114802.350655] wlan1: associated
[2203362.029874] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2203362.039129] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2203362.055504] wlan1: authenticated
[2203362.064035] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2203362.077126] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2203362.077924] wlan1: associated
[2203482.036390] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2203482.046140] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2203482.118772] wlan1: authenticated
[2203482.132024] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2203482.149406] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2203482.150033] wlan1: associated
[2204322.029968] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2204322.038357] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2204322.112593] wlan1: authenticated
[2204322.124044] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2204322.131851] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2204322.132660] wlan1: associated
[2204922.026227] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2204922.034479] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2204922.115098] wlan1: authenticated
[2204922.128017] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2204922.147349] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=4)
[2204922.148095] wlan1: associated
[2243204.528026] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2243204.540138] cfg80211: Calling CRDA to update world regulatory domain
[2243204.544258] cfg80211: World regulatory domain updated:
[2243204.544261] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243204.544264] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2243204.544266] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243204.544268] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243204.544270] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243204.544272] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243204.544275] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2243204.544277] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243204.544279] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2243204.712567] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243204.722008] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243204.924023] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 2/3)
[2243205.128027] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 3/3)
[2243205.332045] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243206.144582] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243206.163010] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243206.364021] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243206.568052] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243206.772036] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243206.944397] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243206.954010] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243207.156055] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243207.360043] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243207.564034] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243208.380584] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243208.398897] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243208.600038] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243208.804018] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243209.008051] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243209.820375] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243209.840015] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243210.044029] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243210.248016] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243210.452018] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243210.628377] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243210.638008] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243210.840013] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243211.044009] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243211.248060] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243212.064437] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243212.082001] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243212.284052] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243212.488029] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243212.692040] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243212.872422] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243212.882002] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243213.084046] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243213.288013] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243213.492056] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243214.312441] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243214.331001] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243214.532057] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243214.736037] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243214.940044] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243220.832614] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243220.851022] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243221.019509] wlan1: authenticated
[2243221.032024] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2243221.236058] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2243221.440045] wlan1: associate with e8:d3:eb:2f:64:c6 (try 3/3)
[2243221.644033] wlan1: association with e8:d3:eb:2f:64:c6 timed out
[2243221.820517] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243221.850010] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243222.052023] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243222.256057] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243222.460042] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243223.276567] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243223.295011] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243223.496015] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243223.700037] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243223.904031] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243224.076373] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243224.085012] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243224.288056] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243224.492018] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243224.696011] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243225.512508] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243225.531024] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243225.732033] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243225.936018] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243226.140015] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243226.316370] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243226.326018] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 1/3)
[2243226.528028] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 2/3)
[2243226.732019] wlan1: direct probe to e8:d3:eb:2f:64:c6 (try 3/3)
[2243226.936008] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243227.752594] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243227.771017] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243227.972022] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243228.176036] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243228.380041] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243228.556455] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243228.566019] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243228.768046] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243228.854383] wlan1: authenticated
[2243228.868043] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2243228.876260] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=1)
[2243228.876874] wlan1: associated
[2243228.877019] cfg80211: Calling CRDA for country: US
[2243228.880965] cfg80211: Regulatory domain changed to country: US
[2243228.880968] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243228.880970] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2243228.880972] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243228.880975] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243228.880977] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2243228.880979] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2243228.880981] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2243228.889640] wlan1: disassociated from e8:d3:eb:2f:64:c6 (Reason: 34)
[2243228.899035] cfg80211: Calling CRDA to update world regulatory domain
[2243228.899060] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2243228.902350] cfg80211: World regulatory domain updated:
[2243228.902352] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243228.902355] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2243228.902357] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243228.902359] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2243228.902361] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243228.902363] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243228.902366] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2243228.902368] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2243228.902370] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2243229.712523] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243229.730997] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243229.932027] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243230.136020] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243230.340045] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243230.516317] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243230.526021] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243230.728031] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243230.932036] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243231.136059] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243231.952416] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243231.971018] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243232.055628] wlan1: authenticated
[2243232.068020] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2243232.272051] wlan1: associate with e8:d3:eb:39:c4:e6 (try 2/3)
[2243232.476048] wlan1: associate with e8:d3:eb:39:c4:e6 (try 3/3)
[2243232.680012] wlan1: association with e8:d3:eb:39:c4:e6 timed out
[2243232.856407] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243232.866019] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243233.068054] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243233.272018] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243233.476041] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243234.292572] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243234.311020] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243234.512014] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243234.716032] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243234.920045] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243235.736694] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243235.755016] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243235.956052] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243236.160037] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243236.364026] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243236.540350] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243236.550011] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243236.562883] wlan1: authenticated
[2243236.576034] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2243236.780011] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2243236.984012] wlan1: associate with e8:d3:eb:2f:64:c6 (try 3/3)
[2243237.188040] wlan1: association with e8:d3:eb:2f:64:c6 timed out
[2243238.004544] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243238.021005] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243238.224039] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 2/3)
[2243238.428042] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 3/3)
[2243238.632016] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243238.808430] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243238.818016] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243239.020056] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243239.224056] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243239.428021] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243240.244350] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243240.263017] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243240.464023] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243240.668059] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243240.872026] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243241.048410] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243241.058021] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243241.260029] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243241.464031] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243241.668026] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243242.484445] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243242.503013] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243242.704044] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243242.908032] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243243.112046] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243243.932359] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243243.951028] wlan1: direct probe to e8:d3:eb:39:c4:e6 (try 1/3)
[2243244.152039] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 2/3)
[2243244.356032] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 3/3)
[2243244.560014] wlan1: authentication with e8:d3:eb:39:c4:e6 timed out
[2243244.736465] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2243244.766020] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2243244.968051] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2243245.172053] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2243245.376012] wlan1: authentication with e8:d3:eb:2f:64:c6 timed out
[2243666.728484] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2243666.747113] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2243666.753731] wlan1: authenticated
[2243666.764042] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2243666.781102] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2243666.781926] wlan1: associated
[2243666.782028] cfg80211: Calling CRDA for country: US
[2243666.785634] cfg80211: Regulatory domain changed to country: US
[2243666.785637] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2243666.785639] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2243666.785642] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243666.785644] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2243666.785646] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2243666.785648] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2243666.785650] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2276962.030140] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2276962.038535] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2276962.050767] wlan1: authenticated
[2276962.060010] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2276962.264035] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2276962.278521] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2276962.279442] wlan1: associated
[2277082.025929] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2277082.034555] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2277082.130057] wlan1: authenticated
[2277082.140032] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2277082.146672] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2277082.147349] wlan1: associated
[2283463.488046] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2283463.492113] cfg80211: Calling CRDA to update world regulatory domain
[2283463.495954] cfg80211: World regulatory domain updated:
[2283463.495957] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2283463.495959] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2283463.495961] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2283463.495970] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2283463.495972] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2283463.495974] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2283463.495976] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2283463.495979] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2283463.495981] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2283463.660426] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2283463.669975] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2283463.739725] wlan1: authenticated
[2283463.752058] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2283463.760728] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2283463.761351] wlan1: associated
[2283463.761500] cfg80211: Calling CRDA for country: US
[2283463.765042] cfg80211: Regulatory domain changed to country: US
[2283463.765045] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2283463.765047] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2283463.765049] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2283463.765051] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2283463.765053] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2283463.765056] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2283463.765058] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2292166.808039] hub 2-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
[2292166.808045] usb 2-1: USB disconnect, device number 2
[2292167.056036] usb 2-1: new low-speed USB device number 4 using uhci_hcd
[2292167.233795] usb 2-1: New USB device found, idVendor=046d, idProduct=c31c
[2292167.233799] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2292167.233803] usb 2-1: Product: USB Keyboard
[2292167.233806] usb 2-1: Manufacturer: Logitech
[2292167.268286] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1:1.0/input/input8
[2292167.268402] generic-usb 0003:046D:C31C.0004: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1a.0-1/input0
[2292167.316857] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb2/2-1/2-1:1.1/input/input9
[2292167.316980] generic-usb 0003:046D:C31C.0005: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1a.0-1/input1
[2292167.317036] hub 2-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[2292167.317039] usb 2-2: USB disconnect, device number 3
[2292167.564040] usb 2-2: new low-speed USB device number 5 using uhci_hcd
[2292167.739796] usb 2-2: New USB device found, idVendor=046d, idProduct=c00e
[2292167.739801] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2292167.739804] usb 2-2: Product: USB-PS/2 Optical Mouse
[2292167.739807] usb 2-2: Manufacturer: Logitech
[2292167.756223] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb2/2-2/2-2:1.0/input/input10
[2292167.756335] generic-usb 0003:046D:C00E.0006: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1a.0-2/input0
[2292177.616062] hub 2-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
[2292177.616069] usb 2-2: USB disconnect, device number 5
[2292177.868024] usb 2-2: new low-speed USB device number 6 using uhci_hcd
[2292178.043801] usb 2-2: New USB device found, idVendor=046d, idProduct=c00e
[2292178.043806] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[2292178.043809] usb 2-2: Product: USB-PS/2 Optical Mouse
[2292178.043812] usb 2-2: Manufacturer: Logitech
[2292178.060179] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb2/2-2/2-2:1.0/input/input11
[2292178.060300] generic-usb 0003:046D:C00E.0007: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1a.0-2/input0
[2292535.504059] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:2f:64:c6 after 500ms, disconnecting.
[2292535.516133] cfg80211: Calling CRDA to update world regulatory domain
[2292535.520167] cfg80211: World regulatory domain updated:
[2292535.520171] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2292535.520173] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2292535.520175] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2292535.520177] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2292535.520179] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2292535.520182] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2292535.520184] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2292535.520186] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2292535.520188] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2292536.316462] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2292536.334974] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2292536.421989] wlan1: authenticated
[2292536.432057] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2292536.441982] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2292536.442742] wlan1: associated
[2292536.442891] cfg80211: Calling CRDA for country: US
[2292536.446722] cfg80211: Regulatory domain changed to country: US
[2292536.446725] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2292536.446727] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2292536.446729] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2292536.446731] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2292536.446733] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2292536.446736] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2292536.446738] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2294362.025138] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2294362.033388] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2294362.113886] wlan1: authenticated
[2294362.124025] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2294362.134016] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2294362.134929] wlan1: associated
[2294482.024793] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2294482.033280] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2294482.120539] wlan1: authenticated
[2294482.132054] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2294482.142294] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2294482.143094] wlan1: associated
[2295442.025258] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2295442.033498] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2295442.120759] wlan1: authenticated
[2295442.132037] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2295442.147248] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2295442.148155] wlan1: associated
[2295562.024896] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2295562.033664] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2295562.106903] wlan1: authenticated
[2295562.120024] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2295562.130529] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2295562.131323] wlan1: associated
[2298126.504016] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2298126.516142] cfg80211: Calling CRDA to update world regulatory domain
[2298126.519741] cfg80211: World regulatory domain updated:
[2298126.519744] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298126.519746] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2298126.519749] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.519751] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.519753] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.519755] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.519757] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2298126.519760] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.519762] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2298126.688506] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2298126.698232] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2298126.783726] wlan1: authenticated
[2298126.796018] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2298126.807100] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2298126.807856] wlan1: associated
[2298126.808002] cfg80211: Calling CRDA for country: US
[2298126.811810] cfg80211: Regulatory domain changed to country: US
[2298126.811812] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298126.811815] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2298126.811817] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298126.811819] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298126.811821] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2298126.811823] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2298126.811825] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2298126.823720] wlan1: disassociated from e8:d3:eb:2f:64:c6 (Reason: 34)
[2298126.838282] wlan1: deauthenticating from e8:d3:eb:2f:64:c6 by local choice (reason=3)
[2298126.838826] cfg80211: Calling CRDA to update world regulatory domain
[2298126.842358] cfg80211: World regulatory domain updated:
[2298126.842361] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298126.842363] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2298126.842366] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.842368] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2298126.842370] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.842372] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.842374] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2298126.842376] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2298126.842378] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2298127.652513] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2298127.671233] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2298127.800727] wlan1: authenticated
[2298127.812034] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2298127.822984] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2298127.823480] wlan1: associated
[2298127.823635] cfg80211: Calling CRDA for country: US
[2298127.827434] cfg80211: Regulatory domain changed to country: US
[2298127.827437] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2298127.827439] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2298127.827442] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298127.827444] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2298127.827446] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2298127.827448] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2298127.827450] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2300375.492023] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:39:c4:e6 after 500ms, disconnecting.
[2300375.496119] cfg80211: Calling CRDA to update world regulatory domain
[2300375.500114] cfg80211: World regulatory domain updated:
[2300375.500116] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2300375.500119] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2300375.500126] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2300375.500128] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2300375.500130] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2300375.500132] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2300375.500135] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2300375.500137] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2300375.500139] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2300375.668572] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2300375.697730] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2300375.711230] wlan1: authenticated
[2300375.724044] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2300375.749599] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2300375.750230] wlan1: associated
[2300375.750391] cfg80211: Calling CRDA for country: US
[2300375.754311] cfg80211: Regulatory domain changed to country: US
[2300375.754313] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2300375.754316] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2300375.754318] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2300375.754320] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2300375.754327] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2300375.754329] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2300375.754331] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2477025.492033] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:2f:64:c6 after 500ms, disconnecting.
[2477025.500139] cfg80211: Calling CRDA to update world regulatory domain
[2477025.504181] cfg80211: World regulatory domain updated:
[2477025.504184] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477025.504186] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2477025.504188] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477025.504196] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477025.504198] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477025.504200] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477025.504202] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2477025.504204] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477025.504206] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2477026.312456] wlan1: authenticate with e8:d3:eb:2f:64:c6
[2477026.331087] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 1/3)
[2477026.532009] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 2/3)
[2477026.736018] wlan1: send auth to e8:d3:eb:2f:64:c6 (try 3/3)
[2477026.743074] wlan1: authenticated
[2477026.756033] wlan1: associate with e8:d3:eb:2f:64:c6 (try 1/3)
[2477026.960030] wlan1: associate with e8:d3:eb:2f:64:c6 (try 2/3)
[2477026.972458] wlan1: RX AssocResp from e8:d3:eb:2f:64:c6 (capab=0x1431 status=0 aid=2)
[2477026.973080] wlan1: associated
[2477026.973250] cfg80211: Calling CRDA for country: US
[2477026.977150] cfg80211: Regulatory domain changed to country: US
[2477026.977152] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477026.977155] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2477026.977157] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477026.977159] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477026.977161] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2477026.977163] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2477026.977165] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[2477030.488035] ieee80211 phy2: wlan1: No probe response from AP e8:d3:eb:2f:64:c6 after 500ms, disconnecting.
[2477030.492166] cfg80211: Calling CRDA to update world regulatory domain
[2477030.495789] cfg80211: World regulatory domain updated:
[2477030.495792] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477030.495794] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[2477030.495796] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477030.495818] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[2477030.495821] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477030.495823] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477030.495825] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[2477030.495827] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[2477030.495829] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[2477030.664501] wlan1: authenticate with e8:d3:eb:39:c4:e6
[2477030.674081] wlan1: send auth to e8:d3:eb:39:c4:e6 (try 1/3)
[2477030.694699] wlan1: authenticated
[2477030.708044] wlan1: associate with e8:d3:eb:39:c4:e6 (try 1/3)
[2477030.724964] wlan1: RX AssocResp from e8:d3:eb:39:c4:e6 (capab=0x1431 status=0 aid=3)
[2477030.725566] wlan1: associated
[2477030.725718] cfg80211: Calling CRDA for country: US
[2477030.729670] cfg80211: Regulatory domain changed to country: US
[2477030.729673] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[2477030.729676] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[2477030.729678] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477030.729680] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[2477030.729682] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[2477030.729684] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[2477030.729686] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[3340618.762095] RTAI[math]: unloaded.
[3340618.763300] SCHED releases registered named ALIEN PEDV$D
[3340618.766522] RTAI[malloc]: unloaded.
[3340618.864015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[3340618.865430] I-pipe: head domain RTAI unregistered.
[3340618.865462] RTAI[hal]: unmounted.
[3340619.885416] I-pipe: head domain RTAI registered.
[3340619.885420] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[3340619.885444] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[3340619.885447] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[3340619.885449] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[3340619.885452] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 20620750
[3340619.890832] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[3340619.890854] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[3340619.890857] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[3340619.890860] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[3340619.890862] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[3340619.894433] RTAI[math]: loaded.
[3340620.036236] config string '0x0378'
[3607191.444433] RTAI[math]: unloaded.
[3607191.445571] SCHED releases registered named ALIEN PEDV$D
[3607191.449526] RTAI[malloc]: unloaded.
[3607191.548017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[3607191.549457] I-pipe: head domain RTAI unregistered.
[3607191.549484] RTAI[hal]: unmounted.
[3607320.082119] I-pipe: head domain RTAI registered.
[3607320.082123] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[3607320.082145] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[3607320.082148] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[3607320.082151] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[3607320.082153] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 20743250
[3607320.089029] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[3607320.089059] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[3607320.089062] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[3607320.089065] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[3607320.089067] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[3607320.098444] RTAI[math]: loaded.
[3607320.140064] config string '0x0378'
[3934796.915873] RTAI[math]: unloaded.
[3934796.917014] SCHED releases registered named ALIEN PEDV$D
[3934796.920898] RTAI[malloc]: unloaded.
[3934797.020011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[3934797.021383] I-pipe: head domain RTAI unregistered.
[3934797.021411] RTAI[hal]: unmounted.
[3934805.583052] I-pipe: head domain RTAI registered.
[3934805.583056] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[3934805.583085] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[3934805.583088] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[3934805.583090] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[3934805.583093] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 18193500
[3934805.588909] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[3934805.588930] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[3934805.588933] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[3934805.588936] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[3934805.588938] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[3934805.595064] RTAI[math]: loaded.
[3934805.737646] config string '0x0378'
[4106504.834648] RTAI[math]: unloaded.
[4106504.835833] SCHED releases registered named ALIEN PEDV$D
[4106504.843438] RTAI[malloc]: unloaded.
[4106504.940013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4106504.941574] I-pipe: head domain RTAI unregistered.
[4106504.941605] RTAI[hal]: unmounted.
[4106514.290616] I-pipe: head domain RTAI registered.
[4106514.290620] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[4106514.290650] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[4106514.290652] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[4106514.290655] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[4106514.290657] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 15936000
[4106514.296464] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[4106514.296487] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[4106514.296490] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[4106514.296493] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[4106514.296495] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[4106514.300529] RTAI[math]: loaded.
[4106514.443270] config string '0x0378'
[4207596.220889] RTAI[math]: unloaded.
[4207596.222112] SCHED releases registered named ALIEN PEDV$D
[4207596.232358] RTAI[malloc]: unloaded.
[4207596.332013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4207596.333445] I-pipe: head domain RTAI unregistered.
[4207596.333472] RTAI[hal]: unmounted.
[4207613.565028] I-pipe: head domain RTAI registered.
[4207613.565033] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[4207613.565063] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[4207613.565065] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[4207613.565068] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[4207613.565070] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 20746250
[4207613.592805] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[4207613.592825] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[4207613.592829] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[4207613.592831] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[4207613.592833] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[4207613.602947] RTAI[math]: loaded.
[4207613.766267] config string '0x0378'
[4207650.424856] RTAI[math]: unloaded.
[4207650.425999] SCHED releases registered named ALIEN PEDV$D
[4207650.427956] RTAI[malloc]: unloaded.
[4207650.524014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4207650.525454] I-pipe: head domain RTAI unregistered.
[4207650.525482] RTAI[hal]: unmounted.
[4207673.837567] I-pipe: head domain RTAI registered.
[4207673.837571] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[4207673.837595] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[4207673.837598] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 20779541, CLK_FREQ 2992603000, CPU_FREQ 2992603000
[4207673.837601] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[4207673.837603] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 20779541, 20779541, 64379500
[4207673.865463] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[4207673.865482] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[4207673.865486] RTAI[sched]: hard timer type/freq = APIC/20779541(Hz); default timing: oneshot; linear timed lists.
[4207673.865489] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992603000 hz.
[4207673.865491] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[4207673.871400] RTAI[math]: loaded.
[4207674.055558] config string '0x0378'
[4207753.585243] spurious APIC interrupt on CPU#1, should never happen.
[4207753.588077] RTAI[math]: unloaded.
[4207753.589387] SCHED releases registered named ALIEN PEDV$D
[4207753.598345] RTAI[malloc]: unloaded.
[4207753.696515] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[4207753.698265] I-pipe: head domain RTAI unregistered.
[4207753.698292] RTAI[hal]: unmounted.
Last edit: 22 Jun 2025 19:38 by andypugh. Reason: Added "code" tags
- Hakan
- Thank you received: 454
22 Jun 2025 06:09 #330674
by Hakan
Replied by Hakan on topic crashing at startup
This is what caught my eyeMaybe the hardware has past its best before date?
- Thank you received: 7488
22 Jun 2025 12:56 #330687
Replied by tommylight on topic crashing at startup
Older versions of LinuxCNC require LAPIC to run, a quick way to check is by editing the GRUB line at boot by adding LAPIC after nosplash.
- clayton2ndtry
- Thank you received: 5
22 Jun 2025 14:45 #330695
by clayton2ndtry
Replied by clayton2ndtry on topic crashing at startup
GRUB_CMDLINE_LINUXCNC_DEFAULT="lapic quiet rootdelay=5"
I do not see "nosplash" anywhere in /etc/default/grub.
Also this has worked perfectly on this hardware for years until yesterday,
- clayton2ndtry
22 Jun 2025 14:59 #330697
by clayton2ndtry
www.suse.com/security/cve/CVE-2023-52993.html says this is a Linux kernel vunerability. Might the latest version of linuxCNC fix this?
- clayton2ndtry
22 Jun 2025 15:08 #330698
by clayton2ndtry
forum.linuxcnc.org/9-installing-linuxcnc/28861-startup-error shows this as an error in the HAL section of the ini file, but the instructions there from 2016 do not match my ini file.
- clayton2ndtry
22 Jun 2025 15:17 #330701
by clayton2ndtry
More curiously, this is not really at startup. It is only when I open a file in Auto.
Manual and MDI commands work fine. Weirder and weirder. It seems specific to one file. It is 2.1 GB. This is probably an error in the program that generates so this failure may only be a curiosity.
- clayton2ndtry
22 Jun 2025 15:22 #330702
by clayton2ndtry
It just gets weirder. When I tried to attach the malefactor, it claimed it was 2.1GB. When I do an ls -l, it is 24168 bytes.
Time to create page: 0.602 seconds
