Y axis A slave help request
- Quarter20
13 Jul 2025 01:48 #331746
by Quarter20
Y axis A slave help request was created by Quarter20
My machine is using the Y and A motors off a parallel port breakout board. I went thru the step config wizard and set up X, Y, and Z configuration and included the A motor pins while doing so. Im really not sure how to proceed as I need Y and A to both home at the same time? Does anyone have a solution for this application?
Thanks in advance for your help and support!
Quarter20
Quarter20
- Thank you received: 5329
13 Jul 2025 02:47 #331748
Replied by PCW on topic Y axis A slave help request
The following user(s) said Thank You: Quarter20
- Thank you received: 7488
13 Jul 2025 02:53 #331750
Replied by tommylight on topic Y axis A slave help request
What version of LinuxCNC?
Does it have "tandem N axis" as a choice?
Use that if possible, there are no slaves in LinuxCNC.
Just checked and 2.10 has those choices.
13 Jul 2025 03:13 #331752
Ahh, that may be a master only option for stepconf and not in 2.9.4
If stepconf is standalone (I think it is) you should be able to just use the latest:
( rename to stepconf and chmod +x stepconf )
- Quarter20
18 Jul 2025 18:56 #331995
by Quarter20
Replied by Quarter20 on topic Y axis A slave help request
Thanks for your help I was able to find the tandem axis for Y. I am still not sure how I will get both joints to home at the same time?
- Quarter20
18 Jul 2025 19:00 #331996
by Quarter20
When you say the latest, do you mean a newer version than the 2.9.4? I just downloaded it a week ago, do you have a suggestion where to get a newer version? Thanks for your help.
18 Jul 2025 19:34 #331998
The stepconf in 2.9.4 does support gantries (tandem axis)
- timo
- Thank you received: 61
19 Jul 2025 12:50 #332010
by timo
Replied by timo on topic Y axis A slave help request
Is it just about homing sequences? Or do you need to keep a fixed ratio for the axis?
- Quarter20
19 Jul 2025 20:12 #332034
by Quarter20
My Router has a motor on each side of the Y axis running a 16mm ball screw fixed to each side of the gantry (Motors Y and A). The motors will always be required to jog and home together in synchronicity. If I try to home or jog either of them, the gantry will rack. When I get an error for trying to jog either axis it says : " Cannot jog joint because home sequence is synchronized". Is there a way to jog Synchronized? Is that a setting in my step config I have overlooked? Should I be doing an XYZA type of step config vs, the XYZ step config choice? Thanks again for your help and support. I am going to dig into the documentation further.
19 Jul 2025 22:51 - 19 Jul 2025 23:07 #332042
Jogging a joint is not allowed (because it will rack the gantry)
You can jog the Y axis but only after homing is complete.
So if you don't have dual homing switches you need to setup immediate homing
Also unless you have a rotary A axis, there should be no mention of A anywhere
It would be a lot less confusing to refer to the Y Axis as Y and Y1
Last edit: 19 Jul 2025 23:07 by PCW.
Time to create page: 0.168 seconds
