New member from Germany - CNC retrofit of a Leinen FM1
10 Aug 2025 12:23 #333151 by Hartwig
Dear members,
I would like to say hello and introduce myself.  I'm a 66 years old Chemist and since 2 years retired from the industry. I am living in the northwest of Germany, near to the Dutch border and the city of Münster. One of my hobbies are old watchmaker machine tools.
I am grown up in an analog environment. I can not program any computer language (but I have a son, who is capable).
I understand pretty well electrics & electro-mechanical matters. I understand electronic circuits up to a level of using components with a maximum of four soldering feet (eg. bridge rectifiers).
All other components, like IC or even EPROM are a "mystery" to me.
I own a small coordinate milling- and drilling-machine. A Leinen FM1, which is equipped with controls from the mid 80s of the last century.
It uses Heidenhain glass scales on the x-, y- and z-axis and ESCAP 12 V DC Tacho-Servomotors for the movements of these axes.
The indication of position and the positioning to a set coordinate is done by a Heidenhain TNC113 unit, connected with an analog control panel. Furthermore there is a dividing unit with a rotary axis, served by a Heidenhain rotary encoder.
The unit is fully functional. But I`m fearing electric defects in the control panel, without having in hand any documentation of the board layouts, the circuits and the connections. If, after 40 years, a capacitor or a diode would become defective, I would be lost. If needed, the Heidenhain TNC113 can be still repaired by specialists, but a repair is very expensive.
My idea is now, to buy 4 Heidenhain EXE610 on the second hand market and connect them to a newly built LINUX CNC.unit. Could somebody be so kind and advise me, which boards I would need to buy for:
- the INPUTs from the four Heidenhain EXEs
- the INPUTs from the five DC motor tachos (4 from the axes and 1 from the spindle)
- the OUTPUTs to the DC Motors amplifiers/controllers(I have already a second set of amplifiers for the spindle motor of 66 V and the axes drive motors of 12 V).
- some other INPUTs (digital and analog) like limit switches on the axes, emergency switch-off etc., potentiometers
- some other OUTPUTs for indicator lamps/LED
What is the target of this excercise:
- preserve the existing controls in original condition
- plug-in of the existing connectors/interfaces (between the machine and the control panel) to a new CNC unit
- the new CNC unit does not need to be highly sophisticated. I would be happy with a program, which activates the 4 axes in sequential mode. I would guess, that high precision, when running several axis simultaniously, would be impossible to realise with DC Tacho-Servos.
Any feedback is highly appreciated.
Thanks a lot and best regards
Hartwig
10 Aug 2025 15:53 #333170 by andypugh
You _probably_ don't need to take the tachos to LinuxCNC.
Typically the tachos connect only to the servo drives to feed back velocity, and the analogue voltage input from the controller sends a velocity command based on position feedback from the glass scales.
The Leinien FM1 looks like a lovely little thing.
An all-in-one solution from Mesa would be: store.mesanet.com/index.php?route=produc...id=397&search=analog
But there might be cheaper options (for example 6i24 + 7i33TA) but the 7i97T ethernet option will work with just about any supported computer, including the Raspberry Pi.
Other options exist. EtherCAT, Pico PPMC for example.
One of the LinuxCNC developers lives in Münster, I think.
The following user(s) said Thank You: Hartwig
10 Aug 2025 16:49 #333175 by Hartwig
Hi Andy,
thanks a lot for your response. I will try it and buy the recommended MESA Board.
Yes, you are right, the tacho signal can be connected directly to the DC motor amplifier. I have only one amplifier for the 3 axes. So I can run them only in sequence.
I hope, I will find out how to interpret the inputs (TTL ?) from the Heidenhain EXEs.
Is there any chance to get connected to the LinuxCNC developer in Münster?
Best regards
Hartwig
10 Aug 2025 16:53 #333176 by andypugh
Is this one of those systems that can only move one axis at a time?
11 Aug 2025 07:02 #333199 by RotarySMP
I have two ebay bought used  EXE's on my mill. 602D/5-F  and 602/1-F.  I never did figure out Heidenhains model numbering, so I ended up with one providing 1µm resolution, and the other only 5µm.
How I wired them up is here:
www.forum.linuxcnc.org/12-milling/33035-...0e?start=1340#152364
Those Leinen FM 1 are lovely machines. Please add pictures to your thread. Lots and lots of pictures :)
Cheers,
Mark
11 Aug 2025 11:50 #333210 by Hartwig
Hi Mark,
here I'm adding some pictures. The spindles accept 8 mm Watchmaker collets from Boley & Leinen and G.Boley, Unfortunately Schaublin B8 does not fit because of the too narrow slot on the shaft of the collets.
Best regards
Hartwig
11 Aug 2025 12:03 #333213 by Hartwig
Here two pictures of the PCB board, which receives all the signals from the Heidenhain TNC113.
Clearly a prototype and it would be extremely difficult to perform a re-engineering and create the circuit diagram.
Best regards
Hartwig
The following user(s) said Thank You: COFHAL
12 Aug 2025 11:17 #333271 by andypugh
Is it this one?
www.instagram.com/furniturenmarkt/p/CKTauBwrZ-F
Which claims that it might be the only one?
The circuit board is odd, in that it seems to have only one connection.
Do you have any pictures of the inside of the control cabinet? I would not be surprised to find that you already own some EXE units, in that cabinet.
12 Aug 2025 12:42 #333273 by Aciera
Service Manual for the TNC113:
product.heidenhain.de/JPBC/image/FILEBAS...C/599239-00-a-02.pdf
As far as I'm aware the glassscales directly plug into the TNC113. I rather doubt that you are going to find any EXE units in there.
12 Aug 2025 20:23 #333294 by Hartwig
Hi Andy,
yes it is that machine, It is not the only machine, it is the only prototype of the NC version..
My information is, that over serveral years less than a total of 20 units of all versions were built and sold.
There were 3 versions available
- a manual version (can be seen on on lathes.co.uk)
- a NC version like mine with combined servo-drives and handwheels
- a CNC version with a Siemens control,unit an without handwheels (there ios one on Ebay in Germany - can be fpund under "Prätecma")
Best regards
Hartwig
Time to create page: 0.307 seconds
