isolcpus idiot's guide?
- Jonathan_H
05 Sep 2025 11:37 - 05 Sep 2025 11:38 #334485
by Jonathan_H
isolcpus idiot's guide? was created by Jonathan_H
I have LinuxCNC running on a Lenovo m710q with a Realtek NIC.
I regularly get an error saying the servo thread is probably too fast, but the thread is set to 1khz and this post suggests that the hardward I am running should be able to manage a stable 2kHz servo thread
forum.linuxcnc.org/18-computer/56231-get...h-pc-and-mesa#329327
I have gone into the BIOS and turned off all the features that you are told to turn off.
From that thread and a couple of others, it seems that perhaps the solution lies in Isolcpus, however I'm rather unclear as to what I need to set where. I gather that it is a configuration setting to remove a cpu core from the scheduler, but are then how do I get what I want to run on that core on there?
Is there an idiot's guide anywhere?
Jonathan
Jonathan
Last edit: 05 Sep 2025 11:38 by Jonathan_H.
- Online
- Thank you received: 5326
05 Sep 2025 15:32 - 05 Sep 2025 15:34 #334498
Replied by PCW on topic isolcpus idiot's guide?
To change isolcpus you edit /etc/default/grub as root
Something like:
xed admin:///etc/default/grub
or
sudo xed /etc/default/grub
and then in the grub file change this line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
To something like:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=3 idle=poll"
(3 assuming you have a 4 core CPU)
When you have saved your changes, you run:
sudo update-grub
and then reboot
Also with RealTek MACs it's likely that you will need to replace the normal RealTek
Ethernet driver with the DKMS version (search the forum for DKMS)
One additional step to improve Ethernet latency is to pin the Ethernet interrupt
to the last (real-time) CPU
To get an idea of Ethernet latency, you can run this command:
sudo chrt 99 ping -i .001 -q -c 60000 (card_ip_address)
This will run for 1 minute and then print statistics
(card_ip_address) is the motions control cards IP address
Something like:
or
To something like:
sudo update-grub
and then reboot
Last edit: 05 Sep 2025 15:34 by PCW. Reason: forgot update-grub
Time to create page: 0.097 seconds
