7i76eu connection issues
05 Oct 2025 05:31 #335839 by Ayden25
7i76eu connection issues was created by Ayden25
I switched w13 and w14 as the instructions declare and I am still getting 127.0.0.1 in either default and eprom.At any rate I am getting a error on boot www.facebook.com/share/p/1BkDAYUf7Q/Fb post with the image of my error. I changed the ip of the pc to match the 127.0.0.1 to match what people are doing with 10.10.10.10 but still no luck any thoughts cant find any eu specific info or a 7i76eu specific profile on linux cnc.
05 Oct 2025 06:12 #335841 by unknown
Replied by unknown on topic 7i76eu connection issues
Not entirely clear about what you are trying to say.
Please attach any images to your post. So until you attach an image I can't comment on the boot issue.
You shouldn't be assigning 127.0.0.1 to any interface that requires traffic to go to another computer or device on a network. That address is traditionally used for "internal use only". Or the "local host".
The IP of your computer and the IP of the mesa card must not be the same. It's like having 2 houses on the same street having the same number.
10.10.10 could be considered the street name, the last number is the house number.
Pick ,say 10.10.10.11 for your PC.
05 Oct 2025 06:51 #335844 by Ayden25
Replied by Ayden25 on topic 7i76eu connection issues
Thanks for the quick response
Okay I must have misread what others were saying it seemed like a wrong practice to run the same ip for two devices on the network.
I'd like to post a pic but the file size limit is to low here.
Hm2_eth: rtapi_app_main: Network is unreachable (-101)
That's the error I am getting
Still I'm not shure why I'm not getting different ip addresses from the mesa card regardless of jumper location.
05 Oct 2025 07:26 - 05 Oct 2025 07:27 #335845 by rodw
Replied by rodw on topic 7i76eu connection issues
Clearly you are not understanding the basics of networking. Please watch my 7i76e video. Networking is covered about 17 minutes in from memory.
Last edit: 05 Oct 2025 07:27 by rodw.
05 Oct 2025 08:33 #335849 by unknown
You can always reduce the size of the image.
05 Oct 2025 15:18 #335863 by Ayden25
Alright, I have done some further digging here and realized I'm a jackass lmao. I have the cr11 led on which according to the manual is a feild io falt. I have been reading the wrong ip address I'm not establishing connection to the card I am assuming due to these power issues.
I am powering the card with 12v which according to there documentation is acceptable. I am getting 12v where I should be everything seems to be a go there. The jumper for setting feild i/o as vin input is in the correct position. I have unplugged everything unessisary from the card.
05 Oct 2025 15:49 #335864 by Ayden25
Okay I looked around and saw that the card should run without feild power all together. I have setup a static ip for 10.10.10.1/24
I can ping 10.10.10.10 with success but if I run up addr it still isnt visible. Maybe that's usual. Still on the linux cnc end of things with the updated 10.10.10.10 address for the card I am still getting it as unreachable
05 Oct 2025 16:45 #335869 by PCW
Replied by PCW on topic 7i76eu connection issues
Having a field I/O fault is normal until LinuxCNC is running
(if nothing else, there will be a watchdog fault)
What does the command
ip a
return?
05 Oct 2025 17:17 #335872 by Ayden25
cnc@CNC:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 18:a9:05:29:cb:8b brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global enp0s25
inet6 fe80::1aa9:5ff:fe29:cb8b/64 scope link
05 Oct 2025 21:15 #335880 by PCW
What does
mesaflash --device ethernet --addr 10.10.10.10 --readhmid
report?
Time to create page: 0.109 seconds
