Stepper online A6 Servo motor as Spindle motor
25 Oct 2025 12:24 #337128 by Will_cnc
I have a Stepperonline 1000W servo motor with an EtherCAT servo drive, which I intend to use as a temporary spindle motor until I can upgrade to a higher-power unit.
Currently, I have three axes configured to work with Leadshine servo drives via EtherCAT.How can I configure this servo motor to function as a spindle motor?
Specifically, what needs to be added or modified in the following configuration files:
.INI
.HAL.
.XML
I’ve tried setting it up based on information from other forum posts, but I haven’t had much success so far.
25 Oct 2025 16:35 #337145 by Hakan
What have you tried? Which Leadshine drive model?
I am going to propose to use PV mode. It is similar to a vfd.
You just give a speed and the driver ramps up and down as needed.
I have not tried it myself, and I don't have a driver to try it so it is up to you.
I foresee that the cia402 component needs modification, it only handles csp and csv.
26 Oct 2025 11:46 - 26 Oct 2025 11:47 #337190 by Hakan
I *could* put my stepper drivers in PV mode. So I am making a modification to the cia402 component to (hopefully) make a stepper motor work as a spindle (how useful). Servo drives also.
Check back in few hours.
Last edit: 26 Oct 2025 11:47 by Hakan.
26 Oct 2025 16:26 #337218 by Hakan
Here is now a modified cia402 component together with a complete example on how to use PV (Profile Velcotiy) for an EtherCAT spindle drive.
github.com/MetalMusings/cia402pv
The following user(s) said Thank You: pommen
30 Oct 2025 10:38 - 30 Oct 2025 10:41 #337457 by Will_cnc
Replied by Will_cnc on topic Stepper online A6 Servo motor as Spindle motor
Hi Hakan thanks for your help  to configure the drive.
Unfortunately I am having no luck in getting it to work.
I have attached my files below do you mind having a look to see if there is anything obvious I am missing?
I am very new to linux so am struggling to work out when using the loadrt command in the .hal file  where the other  file is loading from?
Thanks Will
Last edit: 30 Oct 2025 10:41 by Will_cnc.
30 Oct 2025 10:40 #337458 by Will_cnc
.Hal file I am using
30 Oct 2025 10:45 #337459 by Hakan
Very difficult to say, you give me no clues.
You have to show the error messages from linuxcnc startup, that is the biggest help.
I kind of think you have not installed the component?
"sudo halcompile --install cia402pv.comp"
should put the component in the right place.
Anyway, I have to see the errors you get. A general description is not enough.
30 Oct 2025 11:00 #337462 by Will_cnc
cnc@raspberrypi:~$ sudo halcompile --install cia402pv.comp
File "/usr/bin/halcompile", line 1553, in <module>
main()
File "/usr/bin/halcompile", line 1523, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1363, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 434, in parse
f = open(filename).read()
FileNotFoundError: [Errno 2] No such file or directory: 'cia402pv.comp'
30 Oct 2025 11:01 #337463 by Will_cnc
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/probe_basic_dev'
Machine configuration file is 'EL8_machine.ini'
INIFILE=/home/cnc/linuxcnc/configs/probe_basic_dev/EL8_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=el8_homecomp
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
linuxcnc TPMOD=tpmod HOMEMOD=el8_homecomp EMCMOT=motmod
Found file(REL): ./hallib/EL8_machine.hal
Debug file information:
Note: Using POSIX realtime
cia402pv: dlopen: /usr/lib/linuxcnc/modules/cia402pv.so: cannot open shared object file: No such file or directory
./hallib/EL8_machine.hal:9: waitpid failed /usr/bin/rtapi_app cia402pv
./hallib/EL8_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./hallib/EL8_machine.hal:9: insmod for cia402pv failed, returned -1
2207
Stopping realtime threads
Unloading hal components
30 Oct 2025 12:04 #337475 by Hakan
Be in the directory were you have downloaded cia402pv.comp
and there do "sudo halcompile --install cia402pv.comp"
Easy to spot with the error messages, that helps a lot.
Time to create page: 0.457 seconds
