Stepper online A6 Servo motor as Spindle motor
30 Oct 2025 12:25 #337480 by Will_cnc
Replied by Will_cnc on topic Stepper online A6 Servo motor as Spindle motor
Hi Hakan
Thanks for the help I have configured to the directory now, but have a new error message ?
30 Oct 2025 12:30 #337481 by Will_cnc
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/probe_basic_dev'
Machine configuration file is 'EL8_machine.ini'
INIFILE=/home/cnc/linuxcnc/configs/probe_basic_dev/EL8_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=el8_homecomp
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
linuxcnc TPMOD=tpmod HOMEMOD=el8_homecomp EMCMOT=motmod
Found file(REL): ./hallib/EL8_machine.hal
Debug file information:
Note: Using POSIX realtime
HAL: ERROR: function 'cia402pv.Spindle.read-all' not found
./hallib/EL8_machine.hal:18: addf failed
2439
Stopping realtime threads
Unloading hal components
30 Oct 2025 12:58 #337483 by Hakan
Hmm, did you by any chance comment out the loadrt cia402pv line?
30 Oct 2025 13:22 #337484 by Will_cnc
Doesn't appear to be commented out in the Hal file ?
30 Oct 2025 13:26 #337485 by Will_cnc
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcec
#loadusr -W hal_manualtoolchange
loadrt cia402 count=4
#loadrt mult2
#loadrt mult2 count=4 etc for multiple instances
loadrt cia402pv names=cia402pv.Spindle
30 Oct 2025 15:10 #337491 by Hakan
But there must be a reason that linuxcnc won't find it.
It looks okay in your files.
Response is exactly like it is commented out.
I tested to comment out the loadrt line and got exactly this
Found file(REL): ./cia402pv.hal
./cia402pv.hal:27: addf failed
I also tested to mis-spell cia402pv.Spindl in the loadrt line and got the same error.
Also mis-spelling on the addf line give the same error.
There is some mis-spelling between the loadrt and the addf lines
but I don't see what it is.
From the output messages this is the hal file linuxcnc uses
That's the one you showed, right?
I don't know. Can you retype those two lines?
30 Oct 2025 18:23 #337501 by Will_cnc
I have changed the loadrt line slightly  and receive a different error ?
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.6
VERSION=1.1
TPMOD=
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
2975
30 Oct 2025 19:20 #337511 by Hakan
It's like cia402pv isn't loaded.
Try a new thing. The halrun utility, load the cia402pv component manually.
% halrun
halcmd: loadrt cia402pv names=cia402pv.Spindle
halcmd: show all
This hopefully should work and produce a long list of pins and functions.
30 Oct 2025 19:38 #337515 by Will_cnc
cnc@raspberrypi:~$ % halrun
halcmd: show all
bash: fg: %: no such job
bash: halcmd:: command not found
bash: Note:: command not found
cnc@raspberrypi:~$ halrun
halcmd: show all
Loaded HAL Components:
ID Type Name PID State
4 RT cia402pv ready
2 User halcmd2602 2602 ready
Component Pins:
Owner Type Dir Value Name
4 float IN 0 cia402pv.Spindle.acceleration
4 u32 OUT 0x00000000 cia402pv.Spindle.controlword
4 float IN 0 cia402pv.Spindle.deceleration
4 s32 OUT 0 cia402pv.Spindle.drv-acceleration
4 s32 IN 0 cia402pv.Spindle.drv-actual-position
4 s32 IN 0 cia402pv.Spindle.drv-actual-velocity
4 s32 OUT 0 cia402pv.Spindle.drv-deceleration
4 bit OUT FALSE cia402pv.Spindle.drv-fault
4 s32 OUT 0 cia402pv.Spindle.drv-quickstop-deceleration
4 s32 OUT 0 cia402pv.Spindle.drv-target-position
4 s32 OUT 0 cia402pv.Spindle.drv-target-velocity
4 bit IN FALSE cia402pv.Spindle.enable
4 bit IN FALSE cia402pv.Spindle.fault-reset
4 bit I/O FALSE cia402pv.Spindle.home
4 s32 OUT 0 cia402pv.Spindle.opmode
4 bit OUT FALSE cia402pv.Spindle.opmode-cyclic-position
4 bit OUT FALSE cia402pv.Spindle.opmode-cyclic-velocity
4 s32 IN 0 cia402pv.Spindle.opmode-display
4 bit OUT FALSE cia402pv.Spindle.opmode-homing
4 bit OUT FALSE cia402pv.Spindle.opmode-no-mode
4 bit OUT FALSE cia402pv.Spindle.opmode-profile-velocity
4 float IN 0 cia402pv.Spindle.pos-cmd
4 float OUT 0 cia402pv.Spindle.pos-fb
4 float IN 0 cia402pv.Spindle.quickstop-acceleration
4 s32 OUT 0 cia402pv.Spindle.read-all.time
4 bit IN FALSE cia402pv.Spindle.run
4 bit OUT FALSE cia402pv.Spindle.stat-at-speed
4 bit OUT FALSE cia402pv.Spindle.stat-fault
4 bit OUT FALSE cia402pv.Spindle.stat-homed
4 bit OUT FALSE cia402pv.Spindle.stat-homing
4 bit OUT FALSE cia402pv.Spindle.stat-op-enabled
4 bit OUT FALSE cia402pv.Spindle.stat-quick-stop
4 bit OUT FALSE cia402pv.Spindle.stat-quick-stop-valid
4 bit OUT FALSE cia402pv.Spindle.stat-remote
4 bit OUT FALSE cia402pv.Spindle.stat-switched-on
4 bit OUT FALSE cia402pv.Spindle.stat-switchon-disabled
4 bit OUT FALSE cia402pv.Spindle.stat-switchon-ready
4 bit OUT FALSE cia402pv.Spindle.stat-target-reached
4 bit OUT FALSE cia402pv.Spindle.stat-voltage-enabled
4 bit OUT FALSE cia402pv.Spindle.stat-warning
4 bit OUT FALSE cia402pv.Spindle.stat-zero-speed
4 u32 IN 0x00000000 cia402pv.Spindle.statusword
4 float IN 0 cia402pv.Spindle.velocity-cmd
4 float OUT 0 cia402pv.Spindle.velocity-fb
4 s32 OUT 0 cia402pv.Spindle.write-all.time
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
Parameters:
4 bit RW TRUE cia402pv.Spindle.auto-fault-reset
4 bit RW TRUE cia402pv.Spindle.csp-mode
4 float RW 1 cia402pv.Spindle.pos-scale
4 bit RW FALSE cia402pv.Spindle.pv-mode
4 s32 RW 0 cia402pv.Spindle.read-all.tmax
4 bit RO FALSE cia402pv.Spindle.read-all.tmax-increased
4 float RW 1 cia402pv.Spindle.velo-scale
4 s32 RW 0 cia402pv.Spindle.write-all.tmax
4 bit RO FALSE cia402pv.Spindle.write-all.tmax-increased
Parameter Aliases:
Alias Original Name
Exported Functions:
Owner CodeAddr Arg FP Users Name
00004 7fff005c2a20 7fff005f0120 YES 0 cia402pv.Spindle.read-all
00004 7fff005c1e04 7fff005f0120 YES 0 cia402pv.Spindle.write-all
Realtime Threads:
Period FP Name ( Time, Max-Time )
halcmd: Note: Using POSIX realtime
cnc@raspberrypi:~$
30 Oct 2025 20:16 #337520 by Hakan
That looks perfectly fine.
 What's the problem when this is called inside your hal file?
Let's try that. Add the line
show all
after the
line. It should show many more pins, also the cia402pv pins.
The following user(s) said Thank You: Will_cnc
Time to create page: 0.278 seconds
