Mesa7i96s and Postep60-250?
- melayate
27 Oct 2025 03:13 #337263
by melayate
Replied by melayate on topic Mesa7i96s and Postep60-250?
sorry for the confusion, i have 6 drives powered by 2 power supplies. each power supply is powering 3 drives. my machine setup is 5 axis with the X (gantry) has a tandem, total of 6 axis.
- Thank you received: 5329
27 Oct 2025 14:51 #337281
Replied by PCW on topic Mesa7i96s and Postep60-250?
Did you check that you have 0V at the enables when LinuxCNC is on the power-on and EStop released state?
How are you checking motion? With normal homing setup (with home switches),
you will not be able to jog until the machine is homed.
If the enables are at 0V, anther sanity check to do is to jog in either direction
and check that the DIR pin changes polarity.
Time to create page: 0.096 seconds
