linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
22 Nov 2025 08:05 #338952 by rodw
Replied by rodw on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Well a slightly newer version could work too.
Try whatever came right before "Bookworm", see if it's old enough.
Thats the thing. The LinuxCNC version before Bookworm was on a Wheezy ISO. There was no linuxcnc version released on Bullseye (5.10 kernel) which precedes Bookworm. We don't want to hear Ubuntu being suggested. That's bad advice (as is using Wheezy which is akin to suggesting people drive a Model T Ford)
22 Nov 2025 12:43 #338969 by unknown
Replied by unknown on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
I still stand by my removed comment.
And I'm very sorry to say but you admins are weak and spineless to allow this buffoon to carry on the way he does.
It's a shame the CoC doesn't cover giving advice to members that is completely useless, a waste of time and potentially to the point of causing harm.
But no, the main point is not to hurt anyone feelings or to cause offense.
Who is going to have the intensal fortitude and read Langdon's the riot act. I tried in the beginning to guide him in the right direction but he would appear not to care.
You admins need to take action, I'm sick to effing death in having to make his posts an issue in the hope something will be done to rectify his behaviour. Until then I will keep raising this issue, or you can just ban me. I don't care much, Ive lost faith in every single one on the Admins on this site. You aren't doing a single thing to protect other forum members, especially new ones from his nonsense. At this juncture you all disgust me.
22 Nov 2025 12:50 #338971 by Aciera
Replied by Aciera on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Like so many times before when you noisily left this forum just to reappear a few days later under a different login.
The following user(s) said Thank You: unknown
22 Nov 2025 21:55 #338998 by unknown
At least some honesty.
23 Nov 2025 10:59 - 23 Nov 2025 11:01 #339039 by michaeln
Replied by michaeln on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Last edit: 23 Nov 2025 11:01 by michaeln.
23 Nov 2025 11:02 - 23 Nov 2025 11:04 #339041 by michaeln
Hello,
your problem is not the amdgpu.
That is the "normal" raspi-firmware-bug. Please use: sudo dpkg -P raspi-firmware
I think the amdgpu error message you can ignore. I have the same on my old amd-test-pc
Hi all, i tested again today with a fresh download of  2.9.4 from the main page. And now i am stuck as all the other ones are at, the missing "amdpgu fault".
Was there a solution on that fault ?, i cant decipher if there was one, on all the other forum posts with that fault.
ibb.co/G4FrwL3t
If there is not a solution i will try the "mint" Tommylight uploaded :)
Last edit: 23 Nov 2025 11:04 by michaeln.
The following user(s) said Thank You: Beovoxo
  • Moderator
  • Moderator
23 Nov 2025 16:40 #339061 by tommylight
23 Nov 2025 19:59 #339086 by snowgoer540
Replied by snowgoer540 on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
I can only speak for myself, but I just recognize him for the bored high school student that he is. I feel bad for new people but imagine they quickly realize his replies are virtually useless and very likely the regurgitation of misguided ChatGPT responses.
I stand by my previous advice to not feed the under-bridge dwelling creatures, and ignore him until he moves on, gets himself banned, or discovers better things to do with his time. But it’s a bit pointless for us to block him as he, like you, will probably just make a new username and start over. Trust me, it’s been discussed.
You have something he does not, which is the ability to contribute meaningfully to this community (I remember the Beaglebrainz ISO’s very well). So I ask you to just ignore him, let his mindless comments stand for themselves, and don’t let it affect your integrity.
The following user(s) said Thank You: tommylight, Clive S, Beovoxo, unknown
23 Nov 2025 22:30 #339093 by Beovoxo
Replied by Beovoxo on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
i got it working :) i installed again after xx reinstall and did the install without internet cable connected, and choose english as my native ""UTC -8 GB""", and then i didn't sudo update after install.
I then rebooted and connected network and run sudo update and installed it .. "ethercat setup and all things works" :):):):):)
23 Nov 2025 22:36 #339095 by Beovoxo
THX all i was going insane on all the problems i had :) also because i have been running anything before with no problems. .. I did learn dont update anything that works lol :)... i am quiet sure that some of the problems i had was either bad image or software fault :)
Time to create page: 0.240 seconds
