linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
18 Nov 2025 13:46 #338614 by Beovoxo
Hi all can anyone tell me where to find "linuxcnc_2.9.4-amd64.hybrid.iso" cheksum?
is it
amd64 (PC)
md5sum: 1815aceaac0e7861747aa34d61846e79
sha256sum: 08b3f59233e47c91cf1c9a85c41df48542c97b134efefa7446d3060c9a3e644b
" ?? :) have a nice day all
18 Nov 2025 17:11 #338638 by Beovoxo
Replied by Beovoxo on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
i have tied 3 times but i now think some of my faults are regarding www.forum.linuxcnc.org/9-installing-linu...cnc-in-november-2025
and so :)
18 Nov 2025 20:10 #338652 by unknown
Replied by unknown on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
I just created this from a known good download. Just remove the .txt bit of the download to check.
File Name: linuxcnc_2....md5.txt
File Size:0 KB
Make sure to download from here:
www.linuxcnc.org/iso/
As this is the official site and the safest option.
The following user(s) said Thank You: Beovoxo
18 Nov 2025 22:25 - 18 Nov 2025 22:26 #338662 by Beovoxo
Tried first reinstall 2.9.4, that did not help. then i installed "linuxcnc_2.9.3-amd64.hybrid" same problems as before+ expkey signature not valid due to age, but that's ok ish.. . I think there are a "update" being loaded on install or right after that bugs it. .
one thing i don't get also is when i installed 2.9.7 first time it showed Debian 13 with "red theme" ??
...... :) i think i will put the install on pause for some days because i am going insane lol .. :) thx for helping :)
Last edit: 18 Nov 2025 22:26 by Beovoxo.
18 Nov 2025 22:48 #338663 by Beovoxo
thank you :) I decided to take a few days brake on this reinstall.. "note to myself dont touch things that work lol"
  • Moderator
  • Moderator
18 Nov 2025 22:52 #338664 by tommylight
Replied by tommylight on topic linuxcnc_2.9.4-amd64.hybrid.iso cheksum?
Give this a try
forum.linuxcnc.org/9-installing-linuxcnc...an-edition-6?start=0
or if you are OK with 2.10 version dating nearly a year back, try this
forum.linuxcnc.org/9-installing-linuxcnc...-1-linuxcnc-2-10-iso
20 Nov 2025 13:55 #338798 by Beovoxo
Hi all, i tested again today with a fresh download of  2.9.4 from the main page. And now i am stuck as all the other ones are at, the missing "amdpgu fault".
Was there a solution on that fault ?, i cant decipher if there was one, on all the other forum posts with that fault.
ibb.co/G4FrwL3t
If there is not a solution i will try the "mint" Tommylight uploaded :)
20 Nov 2025 16:47 #338803 by unknown
You can search Debian install amdgpu fault via Google or you can try the text installer.
  • Moderator
  • Moderator
20 Nov 2025 17:14 #338810 by tommylight
Is that "missing amd gpu firmware something or another"?
That is not a fault, just a warning about missing firmwares for older GPU's.
21 Nov 2025 04:31 #338851 by unknown
Not the best suggestion if the user wants to be able to upgrade to 2.9 or 2.10.
Unless a user specifically wants to use the parallel or has an ancient PC it may not be the best suggestion .
It would also be worth noting that Debian wheezy is end of life, updates haven't been available for a few years. Also wheezy had Python2 so the upgrade path for Linuxcnc is rather limited.
So when recommending the Debian Wheezy ISO it would be best to mention these facts.
Time to create page: 0.191 seconds
