Is there any way to use Pncconf Wizard to set up 7i97T with 7i73 pendant board?
29 Nov 2025 14:11 #339423 by Tinker
I have been trying to get my 7i97T to work with a 7i73 so I can use an MPG and a few other local input buttons. I've tried Mesa CT but it will not work with the 7i73, no option to flash that card. So I tried Pncconf and it does not build a good file for the 7i97T. I tried the board discover option and it appears to work but when i actually try to launch the build file it give me a bunch of errors on the 7i73. If I change the I/O of the error pin to not used it just errors out on the next pin... Another issue that is also related and why I'm attempting to use the Pncconf is that I need to install a tool setter and touch probe. Pncconf would be the way to go but i cant get it to work with me. Has any one run into this before?
29 Nov 2025 15:40 #339426 by PCW
There is an experimental version of pncconf (for LinuxCNC 2.10 only) that supports the 7I97T in this thread:
forum.linuxcnc.org/plasmac/55286-servo-d...ofit?start=10#331289
Note that there is no specific firmware needed to support the 7I73
There's also a sample 7I97T configuration to which  7I73 support could be added:
File Name: basic7i97_...1-29.zip
File Size:4 KB
To list 7i73 pin and parameter names:
halcmd show all | grep 7i73
while LinuxCNC is running
The following user(s) said Thank You: Tinker
29 Nov 2025 16:16 #339434 by Tinker
I really don't even need to use the 7i73, all I am really trying to do is add a probe input and set up this MPG for my 7i97T. I really don't know how to add custom components to hal and ini files from scratch. I will admit that I do need to read up on the process...
29 Nov 2025 16:32 #339437 by PCW
Adding a simple probe input does not require adding any components, basically just
making some connections in the hal file, something like:
 net probe hm2_7i97.inmux.00.input-15 =>  motion.probe-input
 or perhaps
net probe hm2_7i97.inmux.00.input-15-not =>  motion.probe-input
depending on the probe polarity.
Adding a MPG will typically require at least one components as a mux component
is often used to select between jog increments.
Searching the forum for MPG will finds a number of MPG implementations and hal file examples.
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
29 Nov 2025 21:12 #339454 by rodw
Or you could've read the docs.
linuxcnc.org/docs/stable/html/examples/mpg.html
skip using the encoder and use the mesa MPG terminals
