How to set current machine position manually?
9 months 2 weeks ago #341417 by rodw
set machine for immediate homing, move to position with hand wheels, home all
Try it.
9 months 1 week ago - 9 months 1 week ago #341641 by timo
Just questions that come to mind (i did not do research on it)
a) How do they probably do it on my "store bought" milling machine? No need to home it. The beast knows where it is after it is powered on.
b) Can the home position be defined in the center of the machine travel? That would make the request easy. The axis can be homed at the position that was reached and the G54 can be "touched off".
c) Can the machine be homed normally, then after disabling the motors moving it around and keep track of the position? Provided some feedback is available e.g. rotary encoder on the hand wheel, or linear encoders?
(that would allow to use the Linux similar to a normal DRO, when the motors are disabled.)
This kind of tracking without motors might be also interesting to teach a machine.
Last edit: 9 months 1 week ago by timo.
9 months 1 week ago #341642 by tommylight
Absolute encoders.
Yes, even with normal encoder or without them, must have home switches.
It will home normally at axis ends, and move to wherever you would like it to be home.
Yes, all that can be done.
Teaching should also be possible without encoders, jogging the machine to required positions and saving coordinates.
The following user(s) said Thank You: timo
Time to create page: 0.219 seconds
