THat's what I did today:Before you make any decisions, you've got to sort out power
This is what I came up with. I can easily send 240V single phase on a 30amp circuit. That plus a 750kvA 32V boost guarded by a 30amp breaker on 10AWG should supply me with enough power for all the drives as they are right now. That's $200bucks for the transformer plus some scrap wire lying around. I want to get the movement of the machine sorted out while the swivel head takes its time to get here on a boat. I believe I'll need an analog mesa card for this setup. The swivel head will have Yaskawa brushless servos. For these, and the rotaries, I will just run them on step/dir drivers. They can be another 20amp 220V circuit. That leaves me with 30amp - 40amp 220 single phase to feed a spindle. Thats a 6-hp spindle - much more than I need. I'll run the raspi off a power bank in case it overloads the system.Single-phase to the machine, and use 220vac step/dir drives and a 220 vac single-phase-in, 3-phase-out VFD for your spindle.
On a 10-20KW machine, that has absolutely no effect! Raspi uses about 5-10W at most, insignificant in the scale of things.I'll run the raspi off a power bank in case it overloads the system.
Probably not. I have yet to see a 480 volt vfd that will run without errors on 240 volts. When I have to run a 480V VFD on 240V, and replacing it is too hard, I use a big step-up transformer. Which tends to cost as much as a new VFD.The VFD takes 3 phase power at 360 to 480. I was wondering if I could just supply 220V power 3 phase to the VFD and have it power a 220V 3 phase spindle.
