more update. i haven't posted here must because the discord forum usually helps me with understanding something claude is making up and I'd say I've gotten to the point where the machine is commissioned. half of the problems was just about electrical connections so, note to future self, don't use splices. just wait a day for a new wire to show up and spend that extra 20 bucks.
so a 5axis retrofit is very doable, but:
(a) pay close attention to the physical properties of the machine. It's very use dependent. If you are carving foam, a direct drive or belt reduction is probably ok, and this actually makes a DIY solution for the physical build quite tenable. I think wood would be fine too if you are carving. For joinery, the precision will most certainly call for a harmonic drive (as in my use case). this means (A) weight, and (
the weight is about 300mm away from the Z axis guide. There is really no away around this. This then means that your gantry will either need to be fixed, or the there is some counterweight, or, "built like they used to be" (as in my case). I also think Z axis clearance is crucial. Have at least 18in.
That's it really. The rest is kinda sorta a load of wiring because the extra axis adds a lot of wires. Happy to take questions if there are any, but I think I'm safely migrating towards calibration, gui setup, and hopefully, making parts and prospering soon after. so glad I chose this over the other controllers
