need help with ethercat vs mesa
5 months 6 days ago #346665 by spumco
I also heard about mesa-ethercat combo but it sounds complex with no real benefit. Something you try just because you can I feel. It would probably make sense for me to see what kind of modules I need for ethercat and look how much thats going to cost.
OP-
The benefit is that Mesa hardware is inexpensive and easy - especially for the 'pricey' types of IO (encoder, analog).
Once you price out the ethercat IO modules, you might price out a Mesa FPGA board and appropriate daughterboard(s) and find it'd be cheaper to go with Mesa for IO.
I suspect for your modest IO needs it won't make much difference, but for an IO-intense machine an Ethercat + Mesa combo becomes attractive.
As far as complexity... every LCNC machine - including Ethercat based - needs a HAL file.  Both Ethercat and Mesa services are started in the HAL file, and pins are assigned like normal.
Not trying to convince you of anything in particular, just letting you know options are available.
5 months 6 days ago #346666 by greenRainbow
I did a calculation:
with 4 ethercat sto servos, beckhoff ek1100(interface), el1809 (16inputs), el2809(16outputs),el4102(vdf control) im getting ~50€ more expensive than mesa + 4 cables.
If I ditch the beckhoff and handle i/o by the servo drives im more limited in machine control and vfd has to be set manually. Spindle control could be added later when I need more i/o for toolchanger anyways.
Basicly a drive i/o system instead of a centered i/o.
Thats why I have difficult times deciding stuff like that, I have two in my eyes equal options. Sto would only come in when using ethercat tho, so theres that.
5 months 5 days ago #346683 by rodw
You can use RS485 Modbus to control your VFD so its not really a problem until you come to the encoder if its needed. Threadmills are a lot easier than rigid tapping.
5 months 5 days ago #346688 by timo
I thought it would make sense because the Mesa card was already purchased and paid for. ... it seemed not final what was missing.
Admittedly two network adapters probably complicates things.
When you just want to eat pickles and cake without getting "the look", being half pregnant does the trick.
Greetings Timo
5 months 5 days ago #346690 by greenRainbow
I think I will go ethercat and sell the mesa.
I completly ignored the fact my vfd works with rs485, thanks for the reminder to check.
Leaves only the decision on drive i/o vs central i/o. I found some deals on the beckhoff parts
ek1100, el1809, el2809
are those the right ones?
I will be using 8 24v end sensors pnp nc.
Many thanks again.
Time to create page: 0.082 seconds
