Keyboard Jogging Problems!!!.
  • spumco
  • Platinum Member
  • Platinum Member
08 Jun 2026 13:13 #346972 by spumco
Replied by spumco on topic Keyboard Jogging Problems!!!.
 I've seen some other people posting similar issues, did these problems start with the switch to GTK3 or might it be closer connected to the switch to Preempt RT or a later Debian version?
I'm not really competent to determine exactly what's going on, but I did look through old GH issues - and there are a number of similar reports over the years.  They go back to 2.7.
However, there may be two (or more) underlying problems which present the same - more or less - undesired behavior.
I get the sense that one of the scenarios involves switching tabs or otherwise changing window focus during a continuous jog.  At the very least, something other than just pressing/releasing a keyboard key is happening.
The other scenario is what the OP reports - no change in window focus, no pop-ups, nothing but a continuous jog even though the key is released.
The two scenarios may not have anything to do with each other beyond the end result.
My suggestion for the OP would be to turn off keyboard auto-repeat in Debian settings and see if the problem continues.  If the problem goes away this may point to a Debian change rather than an LCNC change.
The following user(s) said Thank You: tommylight, maxi177
  • snowgoer540
  • snowgoer540's Avatar
  • Moderator
  • Moderator
10 Jun 2026 09:53 #347015 by snowgoer540
Replied by snowgoer540 on topic Keyboard Jogging Problems!!!.
This sounds like an autorepeat issue I've experienced in the past.
To test if it is, open a terminal window, and enter the following command:
xset -r
Launch LinuxCNC and jog around. If the problem goes away, that's the issue and we can come up with a more permanent solution.
To turn autorepeat back on:
xset r
Did this yield any results yet?
  • Todd Zuercher
  • Todd Zuercher's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Jun 2026 10:53 #347016 by Todd Zuercher
Replied by Todd Zuercher on topic Keyboard Jogging Problems!!!.
I have not visited the facility where the machine is located yet to test it out.
12 Jun 2026 22:07 #347049 by +Jan+
Replied by +Jan+ on topic Keyboard Jogging Problems!!!.
I hade the same issue with GladeVCP an Jogging already years ago. I was not able to fix it permanent: forum.linuxcnc.org/21-axis/33925-glade-p...is-blocks-arrow-keys
It made me finally give up with GladeVCP and "downgrade" to a good old PYVCP sidepanel.
Best wishes
Jan
  • Moderator
  • Moderator
13 Jun 2026 00:59 #347050 by tommylight
Replied by tommylight on topic Keyboard Jogging Problems!!!.
I vaguely recall back some 10 or more years when i was doing VCP panels for everything, i read somewhere here that GladeVCP will ignore inputs if not selected or "in focus" so i never ever used it.
If i press ESC, i want the machine to stop, i do not care if "in focus" or not, it HAS to stop.
The following user(s) said Thank You: NWE
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
30 Jun 2026 21:16 #347426 by Todd Zuercher
I was able to work on the machine having the jogging problems today. I forgot/ran out of time to try the fix on it. But I was able to notice a situation that seems to always cause the sticking problem. Any time that there is an alarm or pop-up message window left open at the bottom right corner of the screen, the jog keys will stick.
  • Moderator
  • Moderator
30 Jun 2026 21:58 #347429 by tommylight
Can you please test the same conditions, but without using glade?
Thank you.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
03 Jul 2026 02:40 #347477 by Todd Zuercher
Not soon. I'm on vacation with the family for the next week. I'll try to remember to do some testing when I get back.
  • Moderator
  • Moderator
03 Jul 2026 12:28 #347480 by tommylight
Enjoy your vacation.
Time to create page: 0.261 seconds
