Gantry oxyfuel / plasma type machine from scratch
22 Jul 2026 02:50 #347945 by rodw
Hi RodW, many thanks for answering. Seems you are telling me to use an EtherCAT Beckhoff module for the THC ?
Should I be using only Beckhoff modules or can I go with any other producer, there is a lot of stuff out there. I was evaluating Triomotion modules for motion controll, IO and Analog IO. The Flexslice series (www.triomotion.com/public/products/flexsliceExpansion.php). Seems they should work with LinuxCNC.
Linux-CNC is the Ethercat master. You just need ethercat slaves. Have a look at the Beckhoff EK1100 and the many various modules that attach to it. Many of these modules have native support in LinuxCNC. There may be other brands of modules available but you would need to write the driver and you'd need to be sure they have 500v or so over voltage protection in case something goes wrong. Beckhoff and Mesa have that.
The following user(s) said Thank You: saxa
22 Jul 2026 03:11 #347948 by NWE
Can you share more details on what are you looking for to use for the retrofit ?
I have not yet started shopping for servos for my machine, but I plan to use ethercat servo drives. I'm thinking likely Stepperonline or Lichuan or Delta brand. For I/O I expect to use Mesa or Beckhoff EK1100 with EL1809 and EL2409. I've used both in multiple projects without any problems that I can remember.
If connecting multiple encoders I nearly always use Mesa because Beckhoff encoder counters are so much more expensive.
For slow cheap I/O I used to not like modbus, but tried it some more recently and am pleased how it is performing. This would not do for limit or homing switches, for those you'll want ethercat or Mesa for sure.
The following user(s) said Thank You: rodw, saxa
22 Jul 2026 03:37 #347949 by rodw
Thats interesting. I never thought of this either. If you look at this diagram in the docs. it clearly shows what can be run in non-real time mode
linuxcnc.org/docs/stable/html/code/code-...rchitecture_overview
So spindle, coolant and auxillary devices could be modbus and I can see modbus I/O modules locally for < AUD $50 for 16 inputs and 16 outputs. I'm might also play with some now there is good modbus support in hal
22 Jul 2026 11:13 #347954 by tuxcnc
I wrote about Modbus, because Ethercat I/O is expensive.
Configuration Mesa+Ethercat is more expensive and you need two network ports (some mini computers are enough powerfull but you can't add any cards).
Modbus need only USB port.
You can find cheap Modbus I/O cards on Aliexpress (for example 4 analog and 4 digital inputs less than 10 US dollars).
Of course Modbus is slow so suitable for slow signals.
22 Jul 2026 18:26 #347963 by saxa
Yes you should leave them out, as noted above the only usable way for DMM drives is in Position mode as they have a delay in position signal outputs.
Also the encoder input will be used for THCAD if you want plasma.
By "leave them out" I meant to not connect them at all. But then how the linuxcnc will know where it is at certain point ? I will probably loose a part of precision with not connecting the encoders feedback.
Yes there is, Mesa 7i85 or 7i85S should have 4 encoder inputs.
I see this card has a DB25 connector to connect it to the computer I suppose, or does it gets connected to the
7i96s ? Sorry for dumb questions.
Is the DMM Dyn4 encoder output supported by the Mesa 7i85 ?
No, not per se, but LinuxCNC can be programmed as you need it, so a simple G04 P1800 will make the machine wait for 30 minutes at the first cut to preheat the material.
Same for outputs and solenoids, everything can be automated and even add a side panel with settings and buttons and stuff.
OK for this, I will take a look better on it once I install it in a virtual machine.
22 Jul 2026 18:30 #347964 by saxa
I took a look at the EK1100 and various modules, thanks. I also checked the Isolation of TrioMotion FlexiSlice coupler P366 and they state it as 1 kV. So this should be ok.
23 Jul 2026 03:30 #347972 by tommylight
Replied by tommylight on topic Gantry oxyfuel / plasma type machine from scratch
Yes, do not connect the encoder output from DMM drives to Mesa board, see below
7i96s ?
It gets connected to Mesa board, and yes it looks like parallel port, and yes there are adapters that connect to Mesa 7i96S (and other Mesa boards) that work as parallel port but at much, much higher pulse speeds, and no 7i85 can not be used with a normal parallel port.
Yes it is, and yes it works fine, technically, in reality the DMM drives have some strange latency/delay issues that make them useless for real time feedback.
But they do work fine (from what i read here) when used as normal stepper drives with step/dir control, and yes the precision will be out of LinuxCNC reach, but if the drives are tuned properly that should not be an issue.
23 Jul 2026 03:32 #347973 by tommylight
Oh yeah, no need for virtual machines, this is Linux, so download the ISO, write it to USB using Balena Etcher or DD or image writer on Linux, boot from it in Live mode, test as much as you like, reboot and remove USB, it does not write nor change anything to existing hard drive.
And also you can actually run machines while in Live mode.
23 Jul 2026 11:22 #347989 by saxa
Many thanks Tommylight, seems all clear to me about the mesa boards and encoders.
I will take a look on the mesa website to see how i get all this different boards connected. So, if I got it correctly I need 2 mesa boards the 7i96S and the 7i85S which get connected together. That should work for me.
I will try to take a look on that DMM delay you are talking to. Also because I want to make this machine to work in our shop and I do not care if there is a slight new cost to add to make it go well and precise. I was even thinking of buying the DYN5 servo drives to have EtherCAT if needed. Altogh I prefer to use what I already have, the DYN4, but if needed I can also buy other servos and drives. Then I can always use these DMM ones for something else.
As for the virtual machine, its just more practical to me to make tests and get used to linuxcnc during my work time with my laptop. Later I will set up an dedicated computer. The idea is to buy a new industrial PC for use with the machine.
24 Jul 2026 08:26 #348024 by rodw
LinuxCNC will run on VirtualBox and so on and this is handy to do basic testing and configuration. There is a limit on what can be done on a sim without real hardware.
Time to create page: 0.271 seconds
